"Replace" remote on Harmony? 880 to Ultimate One? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-20-2017, 03:12 PM - Thread Starter
jayoldschool's Avatar
Quoted: 14 Post(s)
Decided to pick up an Ultimate One to replace my dead 880. Using the 7.7.0 software. Replace Remote doesn't work. When I plug in the USB, the new One is not recognized. Am I out of luck? Is there a work around to import my devices and settings from the 880? Lots of work on customizations...
jayoldschool is offline
post #2 of 5 Old 09-20-2017, 03:36 PM
mbarland's Avatar
Quoted: 16 Post(s)
Can't go smoothly from those old generation remotes to the newer ones.
mbarland is online now
post #3 of 5 Old 09-20-2017, 04:30 PM - Thread Starter
Quoted: 14 Post(s)
Got it! Installed the new software, it accessed my old account, and copied everything perfectly. All I did was try and sign in with my old Harmony login, a popup came up and told me that my account was the old one and asked if I wanted to import. Easy!
Zero issues going from a 15 year old 880 to the Harmony Ultimate One.
post #4 of 5 Old 09-21-2017, 12:45 PM
mbarland's Avatar
Quoted: 16 Post(s)
They must have updated that. It's been several years, but when I went from an 890 to a 900, I started from scratch. Sorry for the bad info.
post #5 of 5 Old 09-21-2017, 05:00 PM - Thread Starter
Quoted: 14 Post(s)
No worries, I've been on the trailing edge for a long time. I refused to replace my 880s, I just didn't like the layout of the newer ones. 24 hours in with the Ultimate One, I'm pretty happy. The DVR function buttons are in a bad location at the top, but I'll survive.
Reply Remote Control Area
