Sammy HLP and the 688 - anyone? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #91 of 172 Old 12-05-2004, 02:31 AM
LeeG23's Avatar
Well that wasn't a very helpful letter!
I also have the 5063 - and my HDMI discrete code DOES NOT work (see above posts). Also, the remote for the TV doesn't have buttons for each input so there's no way to "teach" the harmony. I have set mine up to cycle through active inputs - it works great.
Lee
After a decade of dreaming...building my first front projection home theater!!
LeeG23 is offline
post #92 of 172 Old 12-05-2004, 08:00 AM
Morbo's Avatar
Lee,
Try the HDMI discrete on this site:
http://www.remotecentral.com/cgi-bin...hread.cgi?1863
Like I said, my HDMI worked right out of the box so I'm thinking that Samsung's changing codes for some reason.
So... Humans have easily injured knees... My race will find this information very useful indeed! Muhuhahahaha!
Morbo is offline
post #93 of 172 Old 12-05-2004, 02:28 PM
LeeG23's Avatar
Thanks for the input-
I checked that site, and unfortunately it seems the HDMI issue has not been worked out -
"Needless to say, many these codes, when translated into Pronto form using the supplied spreadsheet do not work. Specifically, the HDMI, DVI, and RF codes do nothing. "
As I said, I have the "cycling through the inputs" thing working, and its unusual that I have to change inputs much - it's usually stuck on the HDTivo unless we watch a movie - so I plan to leave well enough alone.
Thanks for the input -
Lee
LeeG23 is offline
post #94 of 172 Old 12-05-2004, 10:24 PM
dennya's Avatar
Morbo,
Which of the listed model versions did you use to get the HDMI working?
dennya is offline
post #95 of 172 Old 12-06-2004, 08:34 AM
Morbo's Avatar
HLP5063W
Morbo is offline
post #96 of 172 Old 12-06-2004, 09:19 AM
jaime2221's Avatar
I seem to recall reading somewhere that HDMI would not appear to be selected unless there was an active signal on that input.
I have HLP5663 and it does not switch to HDMI, but I don't have a signal on that input either... so I assume operation is correct.
Can anyone confirm this?
Mankind has a perfect record in aviation; we have never left one up there!
jaime2221 is offline
post #97 of 172 Old 12-06-2004, 10:20 AM
LeeG23's Avatar
That is true, the TV will only cycle to active inputs - if you do not have something plugged into the HDMI port, it will not appear, this is correctly functioning.
Lee
LeeG23 is offline
post #98 of 172 Old 12-07-2004, 09:17 AM
mskdbandit's Avatar
Which of these remotes should I get (659 v 688)? I'm slowly starting to update each component and with each new thing, adds 1 more remote.
Although I've upgraded my TV and DVD player (HLP5063 and HD-841 respectively), I still use a VCR and get HD signals through the local cable company. I also have an older Sony receiver which needs to be updated soon.
If I decide to get a dish and DVR, is one remote better equipped to handle that more than the other? Harmony's site claims that the 688 is perfect for DVRs but wanted to hear what others had to say.
mskdbandit is offline
post #99 of 172 Old 12-07-2004, 10:03 AM
LeeG23's Avatar
If you are interested in DVR controls I would not limit yourself to the 659 or 688. Read up on the 676 and 680 - people seem to love these for DVRs. I have the 680, and I am a TiVo addict - it works great. Not as nice a button layout as the 'original' tivo remote, but it works perfect once you get used to it, and it controls all of my components nicely.
Lee
LeeG23 is offline
post #100 of 172 Old 12-07-2004, 12:30 PM
Morbo's Avatar
This may be the case when hunting through inputs but I can tune the disconnected HDMI directly with a discrete on my 659.
As for DVRs on the higher-end Harmonys. I have a DirecTivo and don't have any issues with my 659. Granted, the 680 probably makes that experience a bit easier but I couldn't justify spending the extra money on the 680.
Morbo is offline
post #101 of 172 Old 12-07-2004, 03:35 PM
LeeG23's Avatar
Yeah, a while back there was a bigger discrepancy in price.
Now, buy.com has the 680:
http://www.buy.com/retail/product.as...0&loc=101&sp=1
for $127, and the 659 for $117 - for $10, the 680 may better fit the bill for a dvr-
Lee
LeeG23 is offline
post #102 of 172 Old 12-10-2004, 04:40 PM
bkushin's Avatar
Just wanted to publicly thank the tech support folks at Harmony. The bad news is I've called them several times - the good news is they've been GREAT every time! Courteous, knowledgable, great attitude, etc.. - everything you want/need in a tech support organization.
On my call with them today, we finally determined that my problem all along has been incorrectly mapped discrete codes. For example, the code to switch to InputComponent 1 really switches you to Component 2. I know some are having HDMI problems - there are at least 2 HDMI codes in their Samsung database - you need to use HDMI 1 & it should work fine - does on my HLP4674 anyway. I had to sit with the tech (on the phone) and step through all the input commands to determine the correct ones. He then mapped them correclty in my config. file & now everything works perfectly!
Anyway, just wanted to give kudos to Harmony's tech support - I wish all vendors supported their products this well - and this is only a $150 (or less) product!! BTW, it's a Harmony 659...
Barry
Oh, another tip: Use PowerToggle to turn it on/off - the discrete codes for on/off don't work correctly...
bkushin is offline
post #103 of 172 Old 12-10-2004, 04:42 PM
edalzell's Avatar
I too have had to call Harmony 3 times. Each time my system worked better than before.
Great support! And they're Canadian (at least the support is!!), which is nice.
http://www.theDalzells.org - Where We Live
edalzell is offline
post #104 of 172 Old 12-14-2004, 11:53 AM
zlindsay328's Avatar
i was considering one of these remotes as well. Is there a discrete to turn the internal mute function on/off which is burried in the audio menu? Unfortunatley, my wife prefers watching TV without the surround sound unless we are watching DVDs.
zlindsay328 is offline
post #105 of 172 Old 12-15-2004, 09:31 AM
Morbo's Avatar
Nope, but there might be a receiver DSP mode for stereo only. What kind of receiver is it? I'll punch it into my harmony profile and see if there's a stereo mode discrete.
Morbo is offline
post #106 of 172 Old 12-16-2004, 01:38 PM
Thats too bad...would have been nice to be able to toggle the TV's internal mute on/off with the harmony. After a quick look around the Onkyo website, i believe i have the Onkyo TX-SR501.
Now that you mention it, I believe the receiver stores in memory its settings on each source, so I might be able to play with that and come up with something if not.
post #107 of 172 Old 12-16-2004, 03:24 PM
Morbo's Avatar
Harmony can only blast codes for what the TV will acknowledge so its not really their fault. Hell, Samsung's own remote doesn't even have discrete input buttons (absurd!) so its a credit to Harmony that they were able to put them into the HLP codeset. FYI, I checked and there is a command called "Stereo" in the file for that Onkyo. So theoretically you could program the harmony to put the receiver into a stereo soundfield when the wife watches TV. Even better, you can have an activity for her and one for you for watching TV. Yours puts it into a surround mode and she gets stereo. Now that I think about it, I should do that.
The only sound input that I have going into my HLP5063 is from my DirecTivo so I get the results that you are describing. It takes me a little bit of work if I want the DD sound on some of my DirecTV programming but its better me do the work and not the wife :-)
Morbo is offline
post #108 of 172 Old 12-16-2004, 08:21 PM
mismatched's Avatar
OK
I went thru this thread kinda fast. I have a Sammy HLP5674 and a comcast-mediated Moto 6412 HD DVR and Denon receiver and DVD player and have been looking into a Harmony because I cannot justify a $1000 Pronto and am not a programming whiz. What is the bottomline here. Harmony will soon have the settings for the 74s?? Second related ? Do I go with a 688 which supposedly is DVR friendly or a 768 which has less buttons (and the scroll wheel) and can be programmed (which I guess I can learn how to do??!!)
mismatched
mismatched is offline
post #109 of 172 Old 12-16-2004, 08:25 PM
mismatched's Avatar
Lee
so why dont I hear anything about the 688 model in this thread?? too new? too expensive?
And I thought we were not supposed to list prices in these forums???
mismatched
post #110 of 172 Old 12-20-2004, 10:43 AM
mismatched's Avatar
I am going to stick around this forum as I just got a 680 remote for the following system:
Sammy 5674
Denon AVR 3805
Denon 2910 DVD
Moto 6421 STB
anyone having luck with similar setups ?? I would like to receive advice
thanks
mismatched
post #111 of 172 Old 12-20-2004, 12:27 PM
Morbo's Avatar
Is it not working with your setup?
Morbo is offline
post #112 of 172 Old 12-20-2004, 12:54 PM
LeeG23's Avatar
mismatched
I believe the 688 actually came out before the 680 - the 688 came out from Harmony before logitech bought them. The 676/680 then came out as a pair.
If prices are not allowed, my bad, mods please delete-
thanks,
Lee
LeeG23 is offline
post #113 of 172 Old 12-20-2004, 01:35 PM
AnthonyP's Avatar
Lee is right, the 688 is older
745, 768/748, 659, 688, 676/680
at least for the 6xx they came out almost a year appart
AnthonyP is offline
post #114 of 172 Old 12-20-2004, 01:45 PM
mismatched's Avatar
The 680 arrives today. At Remotecentral.com there are some threads on the 680 and the newer Sammy DLPs and there seemed to be some recurrent problems like having discrete ON work properly. hopefully the people at Harmony will solve this problem and update their website software to deal with the new Sammys. They are beautiful sets and Harmony should want the xx74 owners' business!
m
post #115 of 172 Old 12-20-2004, 09:05 PM
edalzell's Avatar
I have a HLP4663W, Marantz 6300, Motorola DCT2500 (I think), and Samsung 841 DVD player. All of these are controlled perfectly by my Harmony 676. I has taken some time with their help staff (who are great) and some time learning my original remotes.
I am confident that if you call Harmony, they will be able to get everything working properly.
edalzell is offline
post #116 of 172 Old 12-21-2004, 07:59 AM
mismatched's Avatar
So my problems initially are (see my components above in this forum) :
1) When I choose play DVD or watch TV everything goes on except the Samsung HL-P5674W. I recall reading somewhere that this is a feature of this new model Samsung, something about power adjustment by the Harmony to send a stronger signal??? I can't recall where or if I read this. (mid 50's problem!).
I tried using Help and it asked is your TV on and I responded No and then it asked is it on now and I said no , etc.!!
Ok, now I have the TV turned on with its own remote and the TV input is still set to HDMI (DVD player input that is). I press help and it asked me all these ?s about whether the Receiver, TV and STB are on and I say yes. Then it asked my whether the TV is on DVI input and I say no. And then it asks is it now? and I say no , etc. So I had to use my TV remote to switch source/input to DVI (STB).
again I recall reading about this somewhere??
Should I just call Harmony??
thanks, mismatched (again)
post #117 of 172 Old 12-21-2004, 08:37 AM
Morbo's Avatar
Have you had the Harmony learn the power toggle from your samsung remote?
Couldn't hurt to call Harmony, their e-mail support is also very responsive BTW.
Morbo is offline
post #118 of 172 Old 12-21-2004, 09:51 AM
mismatched's Avatar
Morbo
Good question and suggestion. I will have to read the manual to first to see about how you learn this baby something. Also have to figure out the "last" command for going to the last channel watched. considering how little I have played with it I am satisfied.
M
post #119 of 172 Old 12-25-2004, 04:58 PM
ntaylor's Avatar
The 680 is controlling my HLP 4663 perfectly except the discrete DVI input doesn't work. I've tried it on "input DVI," "input DVI 1," and "input DVI 2," none of which work. Of course the remote doesn't have the discrete code so I can't teach it. Tech support was great yesterday, but being as that they're now closed, I'm wondering if anyone here has some wisdom. Thanks.
ntaylor is offline
post #120 of 172 Old 12-25-2004, 10:10 PM
ntaylor's Avatar
Upon further inquiry, looks like it isn't the 680, but the Samsung. My firmware is 1033 and this thread indicates that it might be a problem with the set. Anyone here who can do the discrete DVI input for a later model HLP xx63, your input would be much appreciated.
ntaylor is offline
Closed Thread Remote Control Area
