Controlling a fan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-16-2005, 09:37 AM - Thread Starter
johnnyt's Avatar
Hi,
I have a fan that has a remote control that controls power/speed/oscillation, etc. The fan is a Holmes Blizzard. My MX-500 will not learn the signals from this remote. Is there something about the signal for this fan that makes it 'unlearnable'?
I am hoping that the Harmony 680 I have on order will have better luck.
Am I out of luck?
John
Panny PT-50LC13
Pioneer VSX-1015TX
Athena WS-100s + S-center II + E10/N24II surr.
PB12 sub
SA 8300HD (HD DVR)
Toshiba SD4900 DVD
H-680 remote
johnnyt is offline
post #2 of 4 Old 09-16-2005, 10:01 AM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
If the Fan is RF, no remote will be able to learn it. Can you control the fan without line-of-site?
Edmund is online now
post #3 of 4 Old 09-16-2005, 10:03 AM - Thread Starter
johnnyt's Avatar
Seems to not work unless the fan's remote is pointed at the fan. So I'm guessing it's IR. Any way to confirm this?
Panny PT-50LC13
Pioneer VSX-1015TX
PB12 sub
SA 8300HD (HD DVR)
Toshiba SD4900 DVD
H-680 remote
johnnyt is offline
post #4 of 4 Old 10-06-2005, 10:12 AM - Thread Starter
johnnyt's Avatar
a quick call to the Logitech helpdesk solved my problems. The tech guy walked me throgh how to learn commands on the H680. One of the fan commands took a couple of attempts, but now it works!
Panny PT-50LC13
Pioneer VSX-1015TX
PB12 sub
SA 8300HD (HD DVR)
Toshiba SD4900 DVD
H-680 remote
johnnyt is offline
Closed Thread Remote Control Area
