Harmony Slow Response? Read here! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #91 of 243 Old 03-12-2007, 11:20 AM
colleycol's Avatar
Quoted: 23 Post(s)
Guys, I have a Westinghouse 47 inch LCD and I have to go to the HDMI input from the VGA input to watch HDTV.
I have the activity set up and with the correct inputs. The only thing that doesn't work is that when it switched it always get hung up on DVI2 instead of going one more to HDMI.
The TV cycles through DVI1--->DVI2-->HDMI. Could this be a timing issue? I have to now go to devices and choose monitor and hit InputNext.
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
post #92 of 243 Old 03-13-2007, 06:33 AM
Scuba Steve's Avatar
First of all, thanks to all of you out there that are much smarter than me when it comes to AV.
Does anyone happen to have the delays that work best for-
Onkyo 790 HTIB
Panasonic AX100
Toshiba SD-K860 DVD Player
Any help is appreciated.
Scuba Steve is offline
post #93 of 243 Old 03-13-2007, 11:05 AM
g-speed's Avatar
bummer. It's too dumbed down IMHO. Thanks for the response.
g-speed is offline
post #94 of 243 Old 03-19-2007, 12:49 PM
Paul Arnette's Avatar
Quoted: 40 Post(s)
I did some searching around in this thread, but I wasn't able to find an answer to my question, so I thought I would ask it here.
I have a Toshiba HD-XA2, and it seems to take an eternity to turn on and establish an HDMI handshake between it and my display. Consequently, the correct input on my Monoprice 5x1 HDMI switcher never gets set properly. Is the best way to handle this situation to increase the Power On Delay? If so, where can I find that option, and does anyone have any experience with this model or other Toshiba HD DVD players that could recommend a Power On Delay value?
Update:
Well, I tried bumping the Power On Delay to 20000 ms for my Toshiba HD-XA2, and I'm still having issues. I guess I need to bump it up more. BTW, does anyone know where you can find what order the Harmony 880 attempts to turn on devices? Can this order be changed?
Paul Arnette is offline
post #95 of 243 Old 05-03-2007, 04:37 PM
jimmytop's Avatar
I have a Harmony 550 and I can't find wherever it is I'm supposed to go to change these settings. I have software version 7.2.1 and there is no "More Options" or anywhere that I can find to change these settings. Haven't found it on the remote either. Thanks for any help.
jimmytop is offline
post #96 of 243 Old 05-04-2007, 04:24 PM
jimmytop's Avatar
Can anyone help me out? This remote is useless if it can't keep up with scrolling thru the DVR menu....
jimmytop is offline
post #97 of 243 Old 05-06-2007, 05:39 PM
willymaze's Avatar
im having trouble with my harmony 520
im running a 37" mitsubishi lcd lc-3780 with a proprietery box hd-4001
with a sony 400 disc dvd , sa8300hd and a mitsubishi hsu VCR
with the mitsu stock remote it has the device button and you scroll up or down and highlight the input you want and then press enter
so with my harmony i couldnt find any adjustments with programming to switch inputs for each device.
i got close but in wasnt consistent!
does anyone having any tips or experience with programmming mitsubishi t.v's or any t.v with similiar features and a proprietery box
willymaze is offline
post #98 of 243 Old 05-08-2007, 07:46 AM
joerod's Avatar
Quoted: 719 Post(s)
Liked: 653
I gave up!
My Martin Logan Illusion & Impressions Review:
http://hstrial-jrodriguez996.homeste...=1494808387395
joerod is offline
post #99 of 243 Old 05-26-2007, 08:46 PM
jmchinch's Avatar
having problems with my Harmony 676...some buttons you have to crush or push multiple times to get them to work...it seems to come and go with certain buttons...anyone else have this problem?
jmchinch is offline
post #100 of 243 Old 06-01-2007, 05:31 PM
adrman's Avatar
Same here, it's the rubber pad they use under the keys. I've been trying (w/o luck) to get a replacement part. I've also offered to pay for it since my unit is off warranty. The best Logitech has done is offer me a 659 or 670 for $75. I'll post if I'm successful in obtaining the part. Also, if anyone has any insight in how to do it, please let me know.
adrman is offline
post #101 of 243 Old 06-02-2007, 03:20 AM
czzer's Avatar
Have you tried cleaning the contacts? Open the remote and give the contacts a clean with some rubbing alcohol or similar. This will fix it 90% of the time.
czzer is offline
post #102 of 243 Old 06-02-2007, 11:40 AM
adrman's Avatar
That's going to be the next step. I figured if I was going to open up the remote I might as well replace the pad if I could get it.
adrman is offline
post #103 of 243 Old 06-05-2007, 05:57 AM
adrman's Avatar
Just an update. A good cleaning did the trick. As luck would have it, after two weeks of going back and forth with Harmony last night I got an email telling me how to purchase the replacement part ($5+$5 shipping). I think I'll go ahead and pick one up anyway.
One word of caution to anyone opening up their remote. Be very careful removing the screws. The heads feel as if they'd strip very easily.
adrman is offline
post #104 of 243 Old 06-05-2007, 05:59 PM
jmchinch's Avatar
thanks czzer!...worked like a charm.
jmchinch is offline
post #105 of 243 Old 06-11-2007, 01:52 AM
assbag69's Avatar
When I tweak the millisecond delay per device as suggested at the start of this thread I am able to get quicker a quicker response per button push... However it seem whatever the hell this remote (Harmony XBOX 360) does to send a signal after a button push is WAY slower than most of my devices' original remotes.
Specifically the Harmony responds a good 4-5x slower than the stock XBOX (original xbox) remote. Mostly noticible when trying to do multiple button pushes- like direction down-down-down in a menu etc.
Is there something else I can do to get this remote to respond better to multiple button pushes? Or is there a better uni-remote I should be considering?
assbag69 is offline
post #106 of 243 Old 06-11-2007, 04:16 AM
czzer's Avatar
Have you also reduced the Inter-Device Delay and the number of Repeats?
czzer is offline
post #107 of 243 Old 06-11-2007, 03:31 PM
assbag69's Avatar
I can't seem to find these settings- I'm using the web interface... I feel really stupid, but do you know where I should be looking?
assbag69 is offline
post #108 of 243 Old 06-11-2007, 03:54 PM
assbag69's Avatar
Ok, found them, and I did have them both set to zero for all devices in question.
The problem seems to be how long the romte sends a signal after a button push. Any button push seems to result in the remote sending the signal for a good half second- which none of my devices seem to really require.
assbag69 is offline
post #109 of 243 Old 06-13-2007, 02:43 PM
Person99's Avatar
Liked: 125
Originally Posted by Bob Pariseau View Post
And then what they learn from working with you gets put in the queue for the next database update.
I don't see how it is possible that they learn anything from support calls. I just got an 880 and the programming software is so awful and can't do simple things that I find it hard to believe that there is a time when it was worse!
Person99 is offline
post #110 of 243 Old 07-07-2007, 01:12 PM
ace-cage-#29's Avatar
Originally Posted by HuskerHarley View Post
I did that with no result in speed.
But this did work:
I found (From another poster up above) that this was the fix:
In the "How do you change channels with your factory remote" screen it gives you four choices:
1, two buttons (02)
2, three buttons (002)
3, one button plus enter (2 enter)
4, one or more buttons (2, 22, 1234)
Option 2 was set by default. ( My box uses three buttons (542) to select a channel) I chose option 4. I now have speed.?.?.?.?.?
HH
I cannot figure out how to get back to the "How do you change channels with your factory remote" screen.
Can someone help me out?
Matt
ace-cage-#29 is offline
post #111 of 243 Old 07-14-2007, 04:35 PM
shendley's Avatar
Matt
Go to "Device," click "Troubleshooting" (for the device you want to change), click "show me more problems," click "Changing channels using the number buttons on the remote doesn't work correctly."
shendley is offline
post #112 of 243 Old 07-14-2007, 04:41 PM
shendley's Avatar
I've got a question about how to get the Harmony to control the skip to tick/end/beginning functions on the directv hddvr, the HR20. I'm posting my question here because I suspect it may be an issue which involves delay settings. Anyway, all of these skip to functions involve pressing a key (Fast Forward and Rewind for Skip to Tick, 6 sec back for Skip to Beginning and 30 second advance for skip to end) and holding it for 3 seconds. But if you do that on the Harmony nothing happens. I was told of a workaround. If you hold the key down for three seconds, let up and then click once more it responds perfectly. So, for those of you who know much more about how this remote works, what do you think could be going on for the skip to functions to work in that peculiar way and what, if anything, do you think could be done to get it to work in the way it does on the original remote?
shendley is offline
post #113 of 243 Old 09-13-2007, 05:26 AM
AQUA1957's Avatar
I have the harmony 890. I am using it with my new Mitsubishi WD 65833. I can't seem to get it set up correctly. I had to set the power on command to 30000 which seems to be working properly since the TV takes a long time to warm up and turn on. The problem I am having my input delay is set to 1000 and what happens is that the picture will come on but than the screen goes blank for a second or two does the same thing for a second time than the picture finally stays on after it does this two times. Any help with the proper settings will be greatly appreciated. Thanks
AQUA1957 is offline
post #114 of 243 Old 10-07-2007, 09:05 AM
techtvman's Avatar
Quoted: 20 Post(s)
i have the harmony 880 and the samsung lnt-4671f lcd tv and i was having a issue when pressing the right arrow key, if i was in the menu of the samsung, that it would activate the wiselink usb feature, i tried to figure it out and i just decided the heck with it and called up harmony and they told me to do a new learn as raw command for the right arrow key, this fixed it but now just the right arrow key is slow to respond, the rest of the keys are fine. Which setting would i need to change to fix this
-- TechTVMan
JVC X770R / 120" Silver Ticket | Marantz 7011 | Nvidia Shield | OPPO BDP 203 UHD | Tivo Roamio OTA | Simple Control Remote | 7ch B&W 600 series | Rythmik FV15 | Insteon Automation
techtvman is offline
post #115 of 243 Old 10-24-2007, 06:00 PM
epicbard's Avatar
I must say this is driving me nuts. I have the Harmony 720 and I am trying to set up with the Denon 3808CI. The problem I am having is that one push of a button produces 2 inputs. Meaning 1 click = 2 clicks. Has anyone set it up with such a device? I tried setting the speed to 0 and the Default ones that they suggest. Also tried 300ms for the 2 input settings, but no avail.
epicbard is offline
post #116 of 243 Old 10-24-2007, 10:03 PM
czzer's Avatar
Have you reduced the number of repeats as mentioned in the first post?
czzer is offline
post #117 of 243 Old 10-25-2007, 05:40 AM - Thread Starter
tokerblue's Avatar
Quoted: 199 Post(s)
Liked: 174
- This is what I am using for my 3808ci.
Power On Delay: 1600 ms
Inter-key Delay: 0 ms
Input Delay: 200 ms
Inter-Device Delay: 200 ms
Repeats: 1
tokerblue is offline
post #118 of 243 Old 10-25-2007, 09:42 PM
abuharabi's Avatar
All right, just got the 880 today. I am having a hell of a time getting the channels to input correctly. I have a Sharp Aquos LC-C3742U. The biggest issue is inputting a channel with multiple numbers past the decimal point when digital tuning. For me, that is 1.257 -- I have to enter it almost perfectly to get it to go in correctly. I have all the delays, other than the very last one set to zero.
Also, none of my favorite channels work.
So far, I'd give this remote a B grade.
Gamertag: Bonfirehat
abuharabi is offline
post #119 of 243 Old 10-26-2007, 09:35 AM - Thread Starter
tokerblue's Avatar
Quoted: 199 Post(s)
Liked: 174
- Having all of the delays set to 0 isn't necessarily the fastest setup. Try using 300 ms for the inter-key delay. Then lower it by 100 ms until it seems to respond better. Then try adjusting the repeats from 3 to 2 to 1 to 0 and see what the best combination for your TV is.
post #120 of 243 Old 10-28-2007, 09:06 AM
DeadDingo's Avatar
I am having real trouble with my 890 and my sharp LC-45GD1 I cannot get the input next to work properly automatically. I have tried all the available options and several differnent input delays (1000 (default) 500, 300) and none make any difference. Has anyone got this (or any other remote) to work with the sharps? I am currently having to cheat and defined the down arrow button as the input next button and manually do it, but this is not ideal.
I updated the firmware and software to the latest yesterday, but still no joy
Any help anyone can give would be greatly appreciated.
DeadDingo is offline
Reply Remote Control Area
