Harmony Slow Response? Read here! - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #211 of 243 Old 05-17-2009, 10:51 PM
mva5580's Avatar
Quoted: 49 Post(s)
Picked up an 890 for a good price today, but I have to say so far I'm a bit baffled as to how this remote responds slower than the Xbox 360 Harmony. I downloaded the firmware update, lowered the delay times in the settings, and the 890 is noticeably slower at times than the 360 remote, and also seems to have difficulty "waking" from the state it goes into after the time has elapsed that you set for the glow timer. It's a cool remote and all but so far I'm pretty amazed that a 99.99 MSRP remote works much smoother than a 349.99 MSRP remote.
Any suggestions?
mva5580 is offline
post #212 of 243 Old 06-08-2009, 03:04 PM
sbtv's Avatar
Originally Posted by Chairface1 View Post
I apologize if this has been covered before, but are any of you using a Harmony with the Samsung 950 LCDs? I have a 46a950, and I'd like to have the TV respond quicker to the remote. When I try to start an activity with everything off, it seems to take forever to have the TV come on and switch inputs. However, switching inputs once the TV is on seems to work well.
I've tried reducing the "warm-up" time for the TV in the Device options. The default is 13000ms. The problem is that when I set the number too low, the TV won't get the command to switch inputs once it's on. Has anyone found that "ideal" delay time for this LCD?
I have the same question as Chairface1 but with the Samsung UN55B6000. I can't seem to get the Harmony to switch inputs on the Samsung TV when I start an activity with everything off. Once the TV is on and I switch activities, the inputs switch correctly.
sbtv is offline
post #213 of 243 Old 06-14-2009, 08:28 AM
dmede13's Avatar
Hi, there. I'm hoping somebody might have some suggestions for the *opposite* problem that I am having with my new Harmony 890 remote. I'm using the remote to control my FIOS cable box/DVR, which is a Motorola QIP6416-2. The box is in a different room than the tv, and I am using RF to control it.
The problem is that the buttons are *too* sensitive. If I press channel up or channel down, it goes up two channels or down two channels. If I try to enter a channel number, channel 570 becomes channell 557700. You can imagine how annoying this gets.
I've tried reducing the repeat to 0 and I've also tried increasing the inter-key delay to 1000ms, but neither has fixed the problem. Any other suggestions? Thanks.
dmede13 is offline
post #214 of 243 Old 09-13-2009, 06:40 PM
irod87's Avatar
I sure am glad a stumbled across this thread. My 720 has had a delay with my TWC Motorola DVR for the longest. I did some adjusting and I think all is well now
irod87 is offline
post #215 of 243 Old 11-05-2009, 10:11 PM
mariob33's Avatar
Quoted: 95 Post(s)
Liked: 76
Send a message via Skype™ to mariob33
or if anyone has for prior series its my understanding they are very similar.
In search of video bliss...
mariob33 is offline
post #216 of 243 Old 11-18-2009, 03:25 PM
sofakng's Avatar
Quoted: 33 Post(s)
My Harmony 890 remote doesn't send commands anywhere near as fast as my factory remote.
In fact, if I hit the volume-up several times in a row (quickly), the remote is still sending commands long after I stopped pressing the button. You can also see the little red "radar" signal stay lit on the remote control for a long time.
I've reduced the "time between button presses" from 100 ms to 0 ms and I've reduced the "responding too much" from 2 to 0.
What else can I do?
Will it respond faster if I learn the IR signals from my original remote?
(NOTE: This is happening on pretty much all of my devices and not just my A/V receiver/amplifier)
sofakng is offline
post #217 of 243 Old 11-19-2009, 10:14 AM
FORIAMBILL's Avatar
I bought a second 890 for a second room. I LOVE my first one. In the second room, everything works great, except for the Directv HR20. before, the directv remote was iffy too. I need to hold the remote at a ~60 degree angle. wouldn't work straight on. The 890 is the same way. I tried using the RF extender and everything is worse. the repeater is directly on the IR.
any ideas?
FORIAMBILL is offline
post #218 of 243 Old 01-06-2010, 12:33 AM
spocko's Avatar
Note that on at least some of the Harmony remotes, the inter-device delay affects the speed of sequences, even sequences that only involve one device.
See this thread for further discussion:
http://www.avsforum.com/avs-vb/showthread.php?t=1213638
spocko is offline
post #219 of 243 Old 02-07-2010, 01:47 PM
Tucdaddy's Avatar
I'm having trouble with delay when using my H1 as my mce remote in the guide section of WMC. Here is my setup:
Harmony one
This IR receiver: http://www.amazon.com/Windows-Contro.../dp/B00224ZDFY
Sony 46z4100
Sony STR-DG510
W7 64bit media center
I couldn't seem to find a code in the database that works for the IR receiver, so I eventually just used the remote to RAW program it. Everything works as it should, except there is significant delay when using the guide in WMC. The OEM remote works just fine with the guide. My IR receiver lights up when it receives a signal, and I noticed that is it slightly delayed when signals are sent from the H1 when compared to the OEM. I've tried changing the inter key and inter device delays to 0, changing the number of repeats to 0, as well as multiple combinations of the above, including my other components. No luck. I called logitech support, and the guy pushed me up to level 2 support, but no one's available on the weekend. Anyone here have any other suggestions to try?
Edit: I thought I'd update this post for others who may have purchased this remote. Logitech finally returned my call today and the fix was pretty easy. They analyzed my raw signals, and "trimmed" the end of each raw signal I had programmed. Works great now, is much more responsive, and I have no complaints.
Tucdaddy is offline
post #220 of 243 Old 02-24-2010, 09:31 PM
pehgrif's Avatar
I have a Harmony 880 thats spent the past couple years in a drawer because of the terrible lag. The lag basically makes it unusable with anything with a menu, and makes volume controls a royal pain.
Read every guide I could find (including this one), went through every possible way of fixing it, and nothing would work. I even contacted logitech support who edited some settings the consumer software can't (which to me is an utter disgrace, but thats a whole other story), and what they did actually made the lag at least 10x worse. So into the drawer it went, and it's been there since mid-08.
I'm still using my old pronto tsu-2000 that has absolutely no lag, it's just getting a bit old now. I even have a cheap $20 universal remote that I find much more usable than my Harmony 880, all because of the lag.
pehgrif is offline
post #221 of 243 Old 02-26-2010, 10:18 PM
JBaumgart's Avatar
Quoted: 133 Post(s)
Liked: 81
Sorry to hear. I have 3 Harmony remotes (880, 657 and Harmony 1) in my home and none of them have ever had a lag problem.
Vizio M80-C3
Denon AVR-X7200WA
Odyssey HT-3 Plus
Infinity Prelude MTS
HSU ULS-15 MK2 DualDrive
Oppo BDP-83
JBaumgart is offline
post #222 of 243 Old 04-02-2010, 06:07 PM
Krackar's Avatar
Originally Posted by HuskerHarley View Post
Sorry about the,,,'DELAY'...
My 3808ci, H-1 settings:
Power On Delay: 0 ms
Inter-key Delay: 100 ms
Input Delay: 100 ms
Inter-Device Delay: 100 ms
Repeats: 0
My volume works just fine.
HH
Thanks mate! These settings work a treat on my AVR-2310!!!
Krackar is offline
post #223 of 243 Old 04-09-2010, 11:53 AM
djqwik's Avatar
Can someone help? I have a ROKU NETFLIX HD box and I have tried everything to get the speed of the HARMONY 550 remote to match the speed of the orig roku remote.. when I use the orig remote and press left or right or up or down it works in real time - IE I press it two times it moves 2 times as fast as I press the buttons.. but on the harmony there is a delay.. I have tried changing all the settings as described here and I get it BETTER but still not up to the same speed as the ORIG remote.. any help would be appreciated...
djqwik is offline
post #224 of 243 Old 04-16-2010, 07:19 PM
smail.nathan's Avatar
Quoted: 111 Post(s)
Liked: 42
hey all,
I've long had a harmony 550 remote, and love it. it controls a 40 inch samsung 1080P LCD, a yamaha audio receiver, and a panasonic dvd/vcr recorder (plus a ps3 for blu-ray. but i don't have the adapter for it yet).
I'm noticing a problem that's been occurring as of late, and didn't when I first got it. When I press different activities, it often times does not switch to the proper input on the tv, and also doesn't switch to the proper input on the yamaha av receiver. This is the case both when it has switch all components on from being off (and then doesn't switch to the proper inputs), and sometimes even when everything is already on, the inputs just need switched.
The question is: how do i go about fixing this? I know you can switch delay times and all that fun tech stuff in the remote's menu, but I have no idea what all that stuff means, and how i properly adjust all those settings (which ones, and by how much).
Anyone have any advice for me? I would appreciate some good step-by-step directions. Forgive me for my stupidity in advance. Yes, I've changed the batteries, that is not the issue. I just don't understand what delays to change, and what I should try changing them too. Thx for the help!
smail.nathan is offline
post #225 of 243 Old 04-17-2010, 11:20 AM
ajshin27's Avatar
Harmony one
Sony 46z4100
Sony STR-DG510
I bought a cheap pc remote (chinavision) as well to be used with my Harmony ONE. The remote is in their database (cvsb-983) but it only works if I teach it raw commands just like your situation. How did you "trim" the raw commands exactly? The button delays when using the Harmony ONE is killing me.
ajshin27 is offline
post #226 of 243 Old 06-01-2010, 07:35 PM
Smitty2k1's Avatar
What else can I do?
I'm in the same boat and it's frustrating! Especially for my HTPC!
Smitty2k1 is offline
post #227 of 243 Old 07-02-2010, 07:36 AM
Stickgs's Avatar
I have a Harmony One controlling A/V Receiver Onkyo 1007, PIO KRP 600M and Comcast 8300 cable box along with Sony DVD player. Recently, (perhaps since updating Harmony remote), the delay times when switching channels have gotten very long. Is it possible that the Inter-Key/Delay times have defaulted to a longer timeframe? Any suggested settings for my set-up would be appreciated thanks!
Stick
Stickgs is offline
post #228 of 243 Old 07-02-2010, 07:38 AM
djqwik's Avatar
not to change the topic, but because he Harmony remotes work with the internet, if I purchased a new harmony remote (but a different model), can I just connect it to the usb cable and it will download all the settings from the old remote so I dont have to re-program it??
djqwik is offline
post #229 of 243 Old 07-02-2010, 07:56 AM
Stickgs's Avatar
In the Logitech software theres a place that asks if you have a new remote....try clicking to see if it gives you the option to transfer setttings....just a thought as I'm not at my home computer to try it myself. good luck
Stickgs is offline
post #230 of 243 Old 07-02-2010, 08:02 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
Usually, the basic settings for your devices and activities are transferred if you use go into your existing account and use the Replace Remote function.
What does not always translate over very well are custom button layouts... you may have to redo those. I have use the following replace remote combinations:
  • 880 > One - Devices and activities transferred intact, custom buttons and favorite channels did not. This bothered me because the two remotes have essentially the same capabilities with only going from 8 to 6 custom buttons per page being the difference. This being a very complex setup, it took me days to redo the custom buttons.
  • 520 > 520 - All transferred intact
  • 520 > 550 - All transferred intact
  • 520 > 610 - All transferred intact
  • 550 > 610 - All transferred intact
  • One > 550 - Devices and activities transferred intact, custom buttons and (obviously) favorite channels did not. I did not actually replace the One with a 550, either... I had Harmony clone my One account and changed the clone over to the 550. It is my "backup" remote for the One, since the 550 can also handle the 11 devices in my main system.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #231 of 243 Old 10-09-2010, 03:31 PM
rhehd's Avatar
I have an 880 and the roku inter-key delay always seemed to be about 500ms no matter what I set it to (0, 100).
First I went and got rid of all mentions of 500ms from all my devices, changing all inter-device delays to 100ms. Not sure if this helped because in the same troubleshooting step I also clicked the "troubleshooting" button on the top right of the harmony software which told me there's an update available for my roku device. I updated it and it screwed up my roku activity a bit and added a duplicate roku device.
The delays were better now, about 100ms. I deleted the duplicate roku device which was simply named "dvd" and had the activity use my original device. Delays came back.
I deleted both roku devices and readded one. I think this is what fixed it as my delays now seem to be about 100ms. It's not quite as fast as the roku remote, but it's much better than 500ms.
I also updated the remote firmware. "Downloads" button on top right.
HTH
rhehd is offline
post #232 of 243 Old 08-07-2011, 11:21 AM
kaitlyn2004's Avatar
I've got the Harmony 700 and am frustrated using XBMC
I will for example hold "down" to scroll down a list, but it will continue scrolling after I let go. Keyboard and HP remote have no delay.
Keyboard is RF USB, but the HP remote is ALSO infrared... why doesn't it suffer this lag?
It's quite annoying
kaitlyn2004 is offline
post #233 of 243 Old 08-09-2011, 01:14 PM
tetpbt's Avatar
I am having the same problem. Did you ever find a fix, it is driving me crazy. Thanks
tetpbt is offline
post #234 of 243 Old 01-29-2012, 09:58 AM
tungngroove2000's Avatar
here's my setup followed by a question that has me stumped.
Panasonic TCP60ST30
Bell Expressvu 9242 PVR
Apple TV
Sony PS3
Pioneer VSX1021K wired LAN
Harmony 880 Remote
All components are HDMI to the 1021 with one "out" HDMI to the Panasonic Plasma.
When i power on, everything comes on as it should, but the 1021 powers back off within a few seconds. I have tried changing the power on delay settings with the Harmony software. I have changed them higher to 6000 mms and lower to 500 mms. The default setting is 1500mms. I have also changed the repeat numbers as well.
Once i use the "help" button on the remote, the 1021 powers on and switches to the proper input and works/sounds wonderfully.
Can anyone suggest another setting i should try to change to get it to power on and stay on with the Harmony 880?
Any help is much appreciated, love this forum.
Cheers
tungngroove2000 is offline
post #235 of 243 Old 01-30-2012, 06:45 AM
BPlayer's Avatar
Panasonic TCP60ST30
Apple TV
Sony PS3
Harmony 880 Remote
Cheers
You likely have Viera Link HDMI control turned on in the TV settings (TV not remote). Turn it off and let the Harmony control power on and off of all your devices.
BPlayer is offline
post #236 of 243 Old 01-30-2012, 04:38 PM
wow. thanks so much, that seems to have fixed it...good thing i shave my head cuz i was pulling out my hair trying to figure this out. much appreciated.
post #237 of 243 Old 03-12-2015, 03:17 PM
Liked: 0
I just got a 650 - and i have to press a button twice to "get it going" - is this common?
darthnanu is offline
post #238 of 243 Old 03-12-2015, 03:18 PM
Liked: 0
I had a 700 and didn't have that problem.
post #239 of 243 Old 08-23-2015, 12:06 AM
Skram0's Avatar
I have a Harmony One and suffer from massive key delays too. Any fix for this?
Anyone know if Concordance could fix these issues, or does that program use the same remote codes that Logitech's software uses too?
I need faster codes.
EDIT: After reading the first post in this thread, I reprogrammed my remote for my device to only repeat 1 time, and that drastically sped up my commands. I see the signal icon on the remote is on less after I press a button now, as it's only repeating the command one extra time, instead of repeating 3 times. Which technically was transmitting the command 4 times every time I hit a button. I may experiment with a repeat of 0, but at least a 1 repeat has sped up my button commands. Note to self; read first post and experiment.
Skram0 is offline
post #240 of 243 Old 08-24-2015, 06:21 AM
jcalabria's Avatar
Quoted: 142 Post(s)
Liked: 117
In my experience, inter-key delay makes a bigger difference in the sluggishness because it extends the period between commands being sent, including (I believe) between the repeats. The default inter-key delay of 500ms in most devices is extraordinarily high. I automatically change inter-key to 0 and repeats to 2 as a default for all devices I add to my setups and only adjust if something doesn't work properly (rare). I have not had any responsiveness issues with this strategy and only rarely have operational issues that require additional adjustments. I've never had to raise the repeats back up to three... occasionally still need to drop the repeats to 1 when a command registers too many times on a device (most often seen as skipping over items when negotiating a menu or guide). A very few devices have required the inter-key to be raised to 100ms, but nothing any higher.
If you're a perfectionist, you'd ideally keep tweaking all delays and repeats to be as low as possible and still have your devices function properly, but the gains to be had by tweaking that last little bit diminish rapidly. 0-100ms inter-key and 2 repeats typically produce results that work and any additional speed improvements from additional tweaking are likely to be unnoticeable.
FYI... inter-device delay is similar to inter-key, only for when commands to two different devices come back-to-back. This typically only occurs during startup and shut down and during any sequences you may have made. It's not such a big deal otherwise. You typically can lower this a bit, but you won't see any difference during normal in-activity operation.
Power delay settings can be trickier... Logitech defaults tend to be a bit conservative (long) but don't expect to be able to reduce an 11 second power-on delay for a TV to just a few seconds. All of mine have required somewhere between 8.5 and 13 seconds of "warm up" before they'll accept any additional commands after being powered on. Again, the only thing this would really affect is how long your startup sequences take.
JBaumgart likes this.
Reply Remote Control Area
