Harmony 880 Official Thread. For all info and FAQs - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 6299 Old 06-23-2006, 09:51 PM
RangersFan's Avatar
how do I totally reset my remote and settings in the harmony program, as if it were new?
RangersFan is offline
post #362 of 6299 Old 06-23-2006, 11:02 PM
czzer's Avatar
You could delete all the devices and activities, but it may be easier to just create a new login.
czzer is offline
post #363 of 6299 Old 06-24-2006, 08:51 PM
RangersFan's Avatar
Anyone else having trouble trying to get Rewind to work with the SA 8300HD PVR? I've tried to get it to learn the command from the original controler and it still doesn't work. This is absolutely annoying, considering that REW is one of the most common buttons used on a PVR. Any help getting this function to work correctly would be greatly appreciated.
Also any way to reorder the order of the devices on the device menu? I was able to reorder the activities menu, but cannot find an option anywhere to re-order the devices.
post #364 of 6299 Old 06-25-2006, 08:37 AM
Codeman's Avatar
Tech support might be able to, but I don't think users can.
Codeman is offline
post #365 of 6299 Old 06-25-2006, 09:15 AM
Scott Smith's Avatar
No problem what so ever with native commands.
Scott Smith is offline
post #366 of 6299 Old 06-25-2006, 09:33 AM
Guys I'm stumped on this one..
My 880 has worked flawless for about 6 months now with the following equipment.
Denon 3806 AVR
Denon 1920 DVD
Denon DCM-380 CD
Dish vip622 Sat Box
SA 8300HD Cable DVR
Mitsubishi 52628 TV
I moved my equipment to a closet this weekend and did a hard wired IR repeater system with a emitter on each peice of equipment.
Here's the head scratching problem. Every thing works fine but the 1920 DVD.
I will not respond to any command from the 880. However the OEM remote as well as the 3806 remote works with every command.
If I go to the closet the 880 will operate the DVD with no problems.
I went back to the Harmony and taught it each individual command from the origional remote to no avail.
Bottom line the Harmony is not working through the repeater but works fine without the repeater.
Only thing I can come up with is maybe a timing issue. Only thing I havent tried is raw codes.
Any suggestion would be appreciated.
post #367 of 6299 Old 06-25-2006, 12:06 PM
miked2023's Avatar
This may have been addressed but is there a way to prioritize the order of options when watching DVD or Tivo, etc on the LCD screen? For example, my ASPECT button goes on to page 2 but I'd really like it to be on page one and switch it for something else - I've tried a moving things around but aspect always comes up on page two regardless. thanks.
miked2023 is offline
post #368 of 6299 Old 06-25-2006, 06:07 PM
AV Land's Avatar
No problem here with the SA 8300HD PVR. The rewind button was mapped automatically to the REW button on the remote and works OK...
AV Land is offline
post #369 of 6299 Old 06-25-2006, 07:23 PM
huberjgl's Avatar
Only way I've found is to remove things I don't really use on a regular basis, and it moved ASPECT up to page 1.
TiVo for instance, I really only cared about LIVE TV, THUMBS, SLOMO and ASPECT (for the TV), so they are the only ones there in that activity.
If I need any other buttons, I'll go to that particular DEVICE for them, as I left them as is.
Jerry
I don't just watch HD-TV, I make it happen.
huberjgl is offline
post #370 of 6299 Old 06-25-2006, 10:45 PM
RangersFan's Avatar
thanks for the replies guys, spent an hour or so tweaking all sorts of different options and trying different stuff. Perhaps the REW button is broken? I hope not, anyways I'll give customer support a ring tomorrow.
post #371 of 6299 Old 06-25-2006, 11:00 PM
Brandonw27858's Avatar
If I am trying to set this remote up for the Scientific Atlanta 8300HD cable bx, do I have to select it under both set top box and PVR when selecting my devices?
Brandonw27858 is offline
post #372 of 6299 Old 06-25-2006, 11:05 PM
No,
Add a device,
Pick channel decoder,
Digital Set top box,
Select Scientific Atlanta as the manufacturer,
Type in 8300HD and your done.
post #373 of 6299 Old 06-25-2006, 11:07 PM
I mean if I am setting the remote up for the very first time. Do I only select that I have a set top box or do I select both set top box and PVR?
post #374 of 6299 Old 06-25-2006, 11:14 PM
I don't understand what you are asking.
Are you building an activity or are you creating your devices?
List your equipment and how each peice is hooked up.
post #375 of 6299 Old 06-25-2006, 11:16 PM
ok sorry i was so vague. This is the first time I have plugged my remote into my computer for setup of devices. I just wasn't sure if I needed to add the 8300HD as a set top box alone or as a set top box and a PVR as it does both. Thanks, sorry again.
post #376 of 6299 Old 06-25-2006, 11:19 PM
blazeblaze's Avatar
I think you will just set it up as a single "device", and the Harmony site will figure out what "activities" you can do with it.
blazeblaze is offline
post #377 of 6299 Old 06-25-2006, 11:25 PM
so just list it under set top box and nothig else. Thanks!!
post #378 of 6299 Old 06-25-2006, 11:28 PM
Do as I said above to build the device.
When you create an activity (Watch TV) it will ask you what you use to control volume, what you use to change channels ect.
There are some tips and tricks for the 8300HD
After you build the device click on more options and change power settings to leave on all the time.
Then go into the menu of the 8300HD and create a wake timer for 5:00 AM.
The 8300 has an auto shut down between 2 and 5 AM the creates problems.
To get to the menu of the 8300 push the settings button twice on the 8300 remote.
post #379 of 6299 Old 06-25-2006, 11:44 PM
I turn my box off all the time and have had any probs yet(knock on wood).
Did you mean on the 880?
post #380 of 6299 Old 06-26-2006, 12:26 AM
No the 8300 remote. The 880 doesnt do well at turning on the 8300 when it's powered down. The 8300 remote sometimes takes multiple attempts to turn it on.
Been there done that and have a whole box of T shirts.
post #381 of 6299 Old 06-26-2006, 03:30 AM
RangersFan's Avatar
So yea I solved the whole REW issue I was having. Apparently the function was working correctly all along it was just that I wasn't pushing the button hard enough. However I am still not satisfied. Apparently to get the REW function to work I have to push the REW button very hard, like i'm about to break the damn thing to get it to respond. If I press it like every other button, i get nothing even when the button clicks like the rest of the buttons. Shouldn't I be able to depress it normally like the other buttons, just where u press it down and clicks? No, I gotta push the damn thing down hard, where it will break in a few months i'm sure. What you guys think, should I exchange it? Gonna be a pain in the ass bought it from some amazon.com seller.
post #382 of 6299 Old 06-26-2006, 06:34 AM
pospower's Avatar
OK I went out and bought the Harmony 880 remote can anyone help me with setting up the TV inputs. I can't seem to get it to know which input is for the TV and Which is for DVD and which is for the computer. It just defaults to the last one used. I remember someone mentioning descrete codes for each input. Where can I find those and how do I program it thanks in advance. Jay
pospower is offline
post #383 of 6299 Old 06-26-2006, 06:41 AM
RangersFan's Avatar
it's all done online at the logitech website, or with the harmony remote program that came with. you answer a bunch of questions about ur setup online, then connect to remote via usb cable to ur pc, and it'll update it.
post #384 of 6299 Old 06-26-2006, 07:31 AM
mschiff's Avatar
I've been using a 659 with the 8300HD for a year or so, and am now using an 880. I always turn it off when not watching TV, and have NEVER had a problem with the Harmony remote (either one) turning it on at any time of the day or night (unless the batteries in the remote are low).
-- Martin
mschiff is offline
post #385 of 6299 Old 06-26-2006, 09:14 AM
FLBoy's Avatar
Quoted: 13 Post(s)
Can't say what's happening with your specific TV, but my Sony SXRD set would not recognize the Harmony's input code after turn on. I had to increase the turn on delay setting from the default value of 5000 msec to 6000 msec to allow enough time for the TV to recognize the input code.
To do this, I went to my Harmony home page, clicked on Troubleshoot, and selected the item that matched my problem. That took me to a screen where I could change the turn on delay (time to warm up).
By the way, if your TV can understand discrete codes, I think the 880 will automatically assign discrete codes for input and power control. You don't have to tell it to.
FLBoy is offline
post #386 of 6299 Old 06-26-2006, 10:19 AM
sharding's Avatar
Liked: 25
So yea I solved the whole REW issue I was having. Apparently the function was working correctly all along it was just that I was pushing the button hard enough. However I am still not satisfied. Apparently to get the REW function to work I have to push the REW button very hard, like i'm about to break the damn thing to get it to respond.
Mine is like that on some buttons too. There are a few buttons we have to press really hard to make them work. I've been considering returning it, but it seems to be getting better. I dunno if the keys just need to be broken in or what.
Is this a normal issue?
sharding is offline
post #387 of 6299 Old 06-26-2006, 10:49 AM
mschiff's Avatar
There are no buttons that are difficult to push on either the 880 that I have at home, or the 890 at work. Sounds like it is a problem with the unit.
-- Martin
mschiff is offline
post #388 of 6299 Old 06-26-2006, 06:13 PM
AV Land's Avatar
I had the same problem with the PAUSE button but after a few weeks of fighting with it it started working normally. There must be some kind of residue on the contacts that gets wiped out after multiple use. So try pressing it multiple times for a few minutes and see if that makes a difference, otherwise you might have a defective unit.
AV Land is offline
post #389 of 6299 Old 06-26-2006, 09:12 PM
vgs86's Avatar
Does anybody have problem with keeping time? After couple of months, it had lost over 30 minutes. Is this normal?
- Vikas
vgs86 is offline
post #390 of 6299 Old 06-27-2006, 06:49 AM
RangersFan's Avatar
damn it, now apparently when I want to control the volume on my tv, I have to press vol + each time to move it up incrementally instead of holding it down, like I was able to before. weird, i wonder if it had anything to with dropping the remote shortly before I noticed this glitch. hmm, holding vol + to increase volume works fine with my surround sound receiver. dunno why it stopped working when controlling the tv's volume. holding vol - is working fine.
Reply Remote Control Area
