Control aspect ratio with Comcast remote? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-25-2006, 02:37 PM - Thread Starter
Anondonk's Avatar
Any way I can control the display's aspect ratio ("format") using comcast's "universal" remote control?
When in "TV" mode the remote only works for the volume and input functions. I'm forced to use the TV's remote to change aspect ratio (which I do frequently). Annoying.
Anondonk
Anondonk is offline
post #2 of 6 Old 04-25-2006, 04:16 PM
wjjz106's Avatar
Anondonk -
You can access the "On Screen Menu" by power ON your TV and power OFF the cable box. Press the MENU button on your remote control. The following user settings will then appear for optimizing your TV picture;
- TV TYPE (16:9 Widescreen, 4:3 Letterbox, and 4:3 Pan Scan)
- Y Pb Pr OUTPUT (1080i, 720p, 480p, and 480i)
- 4:3 OVERRIDE
To exit and save changes press the POWER or MENU button.
I don't know if this is what your looking for but its still nice to know you can access OSM through your remote control.
wjjz106 is offline
post #3 of 6 Old 04-25-2006, 10:05 PM
cbane's Avatar
Originally Posted by wjjz106
Anondonk -
- 4:3 OVERRIDE
Either you can read minds....... or I missed something!
Did he even say what TV he has?
I am sooooooo confused right now!
Corey
Sound Home Theaters
Authorized Fujitsu Plasma Dealer
Custom Remote Programmer
San Diego
cbane is offline
post #4 of 6 Old 04-26-2006, 07:44 AM
wjjz106's Avatar
cbane -
I wasn't sure myself. :confused:
I use the learnt TV picture format discreet codes in my TSU7000.
wjjz106 is offline
post #5 of 6 Old 04-26-2006, 07:48 AM
remoteshoppe's Avatar
I'm confused too. If the Comcast box you have is HD like the SA8000 or 8300 then can't you just adjust the aspect ratio of the cable box? If so why would you ever need to change the aspect ratio of the TV?
On my SA8300HD I can scroll through the aspect ratio options with the "#" key.
Jim
remoteshoppe is offline
post #6 of 6 Old 05-20-2006, 10:40 AM
RBBrittain's Avatar
The Motorola DCT6412 (Comcast's most popular HD DVR) isn't like the SA boxes; the ONLY way to adjust this box's aspect ratios is the special menu described earlier, and even that menu doesn't affect 1080i or 720p signals unless they are downconverted to 480p/i.
Though that setup is OK for widescreen HDTVs, if you have a 4:3 HDTV (like my Samsung TX-R2779H) it limits your options. If you leave the TV aspect ratio alone, your options are (a) vertically-stretched HD and normal SD, (b) letterboxed HD and squeezed or postage-stamp SD, or (c) have the box downconvert HD to 480p and format it automatically. If you want true letterboxed HD and normal SD (as I do), you must constantly change the TV's aspect ratio between 16:9 and 4:3.
Since I was able to program my Comcast remote for my Sammy (note that though code 0060 works on my set, only 0702 provides full control), my solution was to find my TV's keycode for the aspect-ratio key thru trial and error, then program it onto the remote. I initially used one of the PIP keys, but I'm moving it to the Help key, which is closer to the channel up/down keys and AFAIK isn't used with i-Guide software.
RBBrittain is offline
Closed Thread Remote Control Area
