Programming a remote for a Vizio TV??? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 130 Old 01-05-2013, 07:38 PM
1976comet's Avatar
Originally Posted by Edmund View Post
Program it for what, it can't be programmed its single device remote, a Vizio tv, sorry.
So then this remote prolly doesn't work for my tv?
1976comet is offline
post #122 of 130 Old 01-05-2013, 10:31 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
According to the pdf I saw of your tv model, the remote looks like this:
http://www.ebay.com/itm/VIZIO-VR2-TV-Remote-Control-for-VECO320L-VECO320LHDTV-VECO320L1A-VO320E-VO370M-/190780546788?pt=US_Remote_Controls&hash=item2c6b681ee4
Edmund is offline
post #123 of 130 Old 01-05-2013, 10:57 PM
1976comet's Avatar
but it compatible for VIZIO VECO320L VECO320LHDTV VECO320L1A VO320E VO370M VO420E
not my VIZIO VX32L HDTV10A..... and that remote doesn't match the one I have here....
post #124 of 130 Old 01-06-2013, 12:24 AM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
You did try the remote? Did it work?
The remote comes with all kinds of models, see here:
http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=0980-0305-3000
Edmund is offline
post #125 of 130 Old 01-06-2013, 11:06 AM
1976comet's Avatar
I tried the remote didn't work. I contacted the seller for troubleshoot was told that it should work right away doesn't need programming it... I don't know but did some research for this TV and yes that remote should look just like that for this TV.And this remote I have is compatible for mine but I don't know why isn't working or maybe it NOT compatible and seller is wrong? Does my TV need some factory reset or something?
post #126 of 130 Old 01-06-2013, 12:06 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
Do you have another remote, like a directv, cable or some other universal remote? If so, list them, perhaps we get that working. It also might be the tv, it maybe broke, it is 2008 model you bought used.
Edmund is offline
post #127 of 130 Old 09-23-2014, 06:06 AM
dking paul's Avatar
Originally Posted by Kupakai View Post
<div class="quote-container"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>dmk1974</strong> <a href="/forum/post/0"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif" style=""></a><br><br>
But what about the "input" button on the Comcast Universal Remote? I can't get it to switch inputs on the Vizio TV. It does the power and volume just fine.</div>
</div>
<br>
If you are using TV/0178, or 11758
do the following:<br><br>
1. Press and release TV device key<br>
2. Press and hold SETUP until remote blinks twice<br>
3. Type 994<br>
4. Press and release SETUP<br>
5. Type 00090<br>
6. Press TV/VCR key<br>
The remote should blink twice if successful<br><br>
You can also assign the following to other keys (the number is for step 5, and choose whatever key you want for step 6):<br>
Wide = 00138<br>
TV = 00110<br>
AV = 00105<br>
Component = 00231<br>
HDMI = 00174
Then, do the following to add FORMAT function to the HD/ZOOM key:
2. Press and hold SETUP until the remote blinks twice
3. Type 994
5. Type 00138
6. Press and release HD/ZOOM key
The remote should blink twice to confirm. Now if you press HD/ZOOM, the TV should respond. If the above works, here are some other functions you could try. For each of the functions above, repeat steps 2 to 6 and use the code below in step 5 and press the key you want to assign the function to in step 6:
Aspect =00138 now the hdZoom button on the comcast remote will work for your vizio tv.. Mine is a 60 inch led smart vizio and this worked great..
dking paul is offline
post #128 of 130 Old 09-23-2014, 07:34 AM
mdavej's Avatar
Quoted: 2257 Post(s)
Liked: 987
Here are a few more Vizio codes (all QWERTY keys plus some discrete power and input commands, and Netflix, Crackle, etc.):
http://www.remotecentral.com/cgi-bin...5478,6#1256484
mdavej is online now
post #129 of 130 Old 02-01-2016, 05:30 PM
Liked: 0
If you got an old school Comcast Universal Remote(I bet half the US population does), they work much better than the little xr2 remotes if you want to do anything other than turn the TV on/off and change the volume. My daughter has a 32" Vizio in her room and she has the XR2 remote, we lost her Vizio remote ages ago and changing the input from the side of TV is huge pain in the ass so she can play her PS4. But with that old remote, that I remembered I had in the drawer after reading Kupakai's posts from 2007. That remote was always awesome and very user friendly.
I used Vizio code 11758 to pair it and then just push TV and then input and use the arrows and ok button to set it to HDMI2 to play her PS4 and that is easy enough for her to do by herself.
So thanks to Kupakai if he is still around and this forum for helping me solve a problem I have been living with for 14 months for no good reason.
Romophobia is offline
post #130 of 130 Old 02-02-2016, 06:06 AM
mdavej's Avatar
Liked: 987
No need to do that. I have a discrete code for HDMI 2 in the previous post, so you can switch with a single button press rather than using input and arrows. Follow the Advanced Code instructions in my signature.
Reply Remote Control Area
Vizio
