Harmony 1000 (3.5 inch screen) - Page 51 - AVS Forum | Home Theater Discussions And Reviews
post #1501 of 1504 Old 02-01-2011, 08:28 PM
SPDSpappy's Avatar
I have the IR4PS3 and it works great w/ my 1000 & RF extender. I have Insteon lighting for 4 zones in my theater. I use the Insteon IR receiver with a line from the RF extender to control all the zones (3 control panels in equipment closet, one pad in theater room).
Check out my "Too many decisions" build here:
Too many decisions...
SPDSpappy is offline
post #1502 of 1504 Old 08-31-2013, 02:41 PM
taxman48's Avatar
Quoted: 301 Post(s)
Liked: 297
first time poster in this forum. I have the Harmony 1000 and would like to know if it could control an Elite motorized screen and projector? I received an Elite 100" screen for a birthday present and now I am shopping around for a PJ. the remote works flawlessly now, controlling tv, STB, AVR, PS3, Cd player, 200 disc cd player, lights. Thanks in advance, let me go back to unpacking my screen..smile.gif
Update: 1000 controls PJ which triggers screen to go up or down.. Can this RF extender work with a Pio Elite 03 in my rack? I put up some blackout curtains now and need a RF extender for the rack components.. thanks in advance.
http://www.ebay.com/itm/Logitech-Harmony-RF-Wireless-Extender-for-Harmony-890-pro-1000-1100-NEW-IN-BOX/360797145047?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D261%26meid%3D3474907937639753828%26pid%3D100005%26prg%3D1088%26rk%3D1%26rkt%3D2%26sd%3D320444502028%26
taxman48 is offline
post #1503 of 1504 Old 12-24-2013, 11:25 AM
taxman48's Avatar
Quoted: 301 Post(s)
Liked: 297
Another 1000 question: After shutting off the JVC projector w/Harmony, it asks "Are you sure you want to exit?" and then you have to hit the button on the JVC remote again..The Harmony shuts it off but you have to hit a button on JVC remote again to answer that stupid question.. How do I set up the Harmony to hit this button again and not use the pj remote? thanks in advance
from the manual:
While the “Are you sure you want to turn off?” message is displayed, press the button again.
The lamp turns off, and the “STANDBY/ON” indicator switches from a green light to a red blinking light.
After the light goes off, the fan will run for about 60 seconds to cool down the lamp (Cool-down mode)
Do not disconnect the power cable while cooling is in progress.
taxman48 is offline
post #1504 of 1504 Old 01-04-2014, 06:13 PM
taxman48's Avatar
Quoted: 301 Post(s)
Liked: 297
fixed the off problem.. According to the Logitech forum, I had to program in a few off commands in a row separated by a few mili seconds.. Everything works perfect now..
taxman48 is offline
Reply Remote Control Area
Logitech Harmony 1000 Advanced Universal Remote Silver
