New Harmony 670 for DVRs - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 93 Old 03-27-2008, 11:59 AM
jgurley's Avatar
Originally Posted by cindyh View Post
Can you customize the buttons to the left and right of the lcd screen and if so what are they called on the software?
Yes, those are the ones I'm taking about. To program them follow the directions on my previous post. Activities, Watch TV, click "Customize Buttons", then the "Additional Buttons" tab. Here's where you can name a button anything you want, like "DVR", select VIP622 as the device, and in the case of DVR you would select "PVR" from the drop down list in the Command column.
Joel
jgurley is offline
post #92 of 93 Old 03-27-2008, 06:44 PM
cindyh's Avatar
Quoted: 20 Post(s)
Thanks so much Jgurley, i got it.. i was pressing learn command when done instead of just "done".. that was why it didnt' work. don't i feel stupid lol..
cindy
cindyh is offline
post #93 of 93 Old 05-05-2008, 09:06 AM
b_scott's Avatar
Quoted: 37 Post(s)
i have the Xbox 360 set up under the "music" activity button. hooked up through HDMI. my set is below.
half the time it does not turn the 360 on. but sometimes it does work. makes no sense to me. anyone have a similar problem? i'm pointed directly center of my unit.
b_scott is offline
Reply Remote Control Area
