New Harmony 670 for DVRs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 93 Old 10-10-2006, 11:45 AM - Thread Starter
MikeSRC's Avatar
See the press release here:
http://www.logitech.com/index.cfm/ne...=12896,crid=34
Here's a picture:
Enjoy!
Mike
Surf Remote Control
MikeSRC is offline
post #2 of 93 Old 10-10-2006, 03:48 PM
Superman07's Avatar
Quoted: 53 Post(s)
From what I can gather this does not handle RF. Are the 890 and 1000 the only Harmony remotes that handle RF?
Otherwise nice remote.
Superman07 is offline
post #3 of 93 Old 10-10-2006, 10:34 PM
remoteshoppe's Avatar
Correct. The 890 and 1000 are the only one's the will support the Logitech Harmony Wireless Extender for RF and Zwave control
Jim
remoteshoppe is offline
post #4 of 93 Old 10-11-2006, 07:02 AM
tamanaco's Avatar
Nice, but not dice. I'm hopping that Logitech will be announcing other new or improved remotes. The 1000 is a bit too big and the touch screen is a bit of overkill for an IR/RF remote. I'm not a fan of touch screens on a remote as they have the tendency of either not respoding quick enough (latency) or failing to sense that they have been touched completely. The only way I'd justify the touch screen is if the remote also suppored WiFi to control wireless media servers with rich content (album art). It would then also require thumb-wheel l(like an iPod) to navigate the music/video library with confort.
What I wish is for a replacement or a fully supported and enhanced 720. I like the form factor and color screen of the 720, but I'm reluctant to buy it because people are complaining about the motion sensor switch not working, the printed text on the body of the remote rubbing off and the appearance of not being "fully" supported by Logitech. Is this remote being recalled or what?... No one knows. Adding RF and DVR buttons to a remote with the form factor of the 720 would also be welcome addition.
tamanaco is offline
post #5 of 93 Old 10-14-2006, 10:22 AM
twooranges's Avatar
Could anybody tell whats the difference from the 680 im looking at getting one of these this weekend. if theirs no difference i'll just get the 680 because it's cheaper.
"Customers do not want online games."- Nintendo president Satoru Iwata.
twooranges is offline
post #6 of 93 Old 10-14-2006, 03:24 PM
bfdtv's Avatar
I would definitely choose the 670 over the 680. It has improved aesthetics and dedicated page +/- buttons. If this is for your own personal use, the improved graphics and labels on the remote (aesthetics) probably don't matter, though.
Still, it's more of the same. When is Harmony going to get its act together and release a remote with larger-sized, high-quality buttons like MX-900?
bfdtv is offline
post #7 of 93 Old 10-14-2006, 09:03 PM
bierboy's Avatar
Maybe never? Since it costs $450.
Mediacom Digital Cable and OTA HD
Panny TC-P55GT50 -- Denon AVR-1713 -- TiVo Premiere XL4 -- Sony BDP-S5100 -- SlingBox 350 -- Polk 5.1 Speakers -- Logitech Harmony One
bierboy is offline
post #8 of 93 Old 10-15-2006, 09:17 AM
bfdtv's Avatar
URC has ridiculous markup though. On ebay, it sells closer to $200.
I bet Logitech could mass produce a remote with a MX900-esque button design / feel for less than $2 extra in parts, compared to the 670/680.
bfdtv is offline
post #9 of 93 Old 11-05-2006, 05:03 PM
atreis's Avatar
I just got a 670 this weekend and it's okay... Does the job. The buttons have a nice feel, even if they are a little small. Support for devices is quite impressive. The software for programming the remote has some quircks that really take time to get used to and figure out.... The automatic stuff doesn't always do the right thing. I ended up changing almost all of the key mappings for the programmed activities. (It's nice that can be done though. :-) ) Overall, programming took too long and the software was very quircky... But I am still happy as the end result does exactly what I wanted.
atreis is offline
post #10 of 93 Old 11-05-2006, 05:49 PM
czzer's Avatar
Ditch the software setup and use the web based setup at http://members.harmonyremote.com
Nearly everyone finds it much easier and faster to use,
czzer is offline
post #11 of 93 Old 11-06-2006, 01:17 PM
atreis's Avatar
Good advice. I checked it out and it does appear to work better and has more options for controlling the various devices. I wonder why they don't expose all of that through the software (which also appears to do much of its work in a web-based way...).
atreis is offline
post #12 of 93 Old 11-08-2006, 08:21 PM
DJ79's Avatar
How responsive is this remote? Is there much delay between pressing a button and the action? I am about to throw my 550 out the window because of this sluggishness (discussed elsewhere) that makes it almost unusable for program guide navigation.
DJ79 is offline
post #13 of 93 Old 11-10-2006, 03:21 PM
atreis's Avatar
For me at least, there's no noticeable delay. Push a button and the command happens immediately.
atreis is offline
post #14 of 93 Old 11-10-2006, 03:46 PM
czzer's Avatar
Delays can be adjusted. See the sticky at the top of the page
czzer is offline
post #15 of 93 Old 01-09-2007, 03:55 PM
FaxMan's Avatar
I've been a happy 680 owner for a few years and it is showing wear. Just noticed the new 670. It looks nice.
The biggest thing I noticed is the lack of a 'media' button. I don't use it for programming, but do use it for selecting discs from a 100 disk CD changer. Am I missing something, or did they do away with it?
FaxMan is offline
post #16 of 93 Old 01-10-2007, 12:31 PM
texviddy's Avatar
Quoted: 17 Post(s)
Just got a 670!
Can I use the the web based setup without installing the software???
texviddy is offline
post #17 of 93 Old 01-10-2007, 06:02 PM
czzer's Avatar
Originally Posted by texviddy View Post
Just got a 670!
You still need to install the software to actually update the remote.
The different options are with the programming side. When you install the software it comes with a Java based setup program. You can bypass this and do your programming from the website. When you click "Update remote" it will launch the software to do the actual loading to the remote.
czzer is offline
post #18 of 93 Old 01-10-2007, 08:00 PM
bierboy's Avatar
...I am about to throw my 550 out the window because of this sluggishness (discussed elsewhere) that makes it almost unusable for program guide navigation.
That's curious because I have the 550 and use it with my TiVo's guide and experience no sluggishness at all.
bierboy is offline
post #19 of 93 Old 01-11-2007, 08:46 AM
texviddy's Avatar
Quoted: 17 Post(s)
Thanks. I installed the software, then closed it. Opened a browser and went to the web setup address (http://members.harmonyremote.com) and configured my 670 there.
It took all of 10 minutes and works pretty good, so far. I'll be customizing buttons in the next week or so and see how that goes.
The great thing about the 670 is how it fits in my hand. I don't have to "crawl" up & down it to reach the buttons. And the DVR controls are easy to access and very intuitive.
texviddy is offline
post #20 of 93 Old 01-11-2007, 08:54 PM
FaxMan's Avatar
For others who may be interested...
I called tech support and they said that although there is no longer a 'media' button, the functionality in regards to DVD/CD changers should be able to be mapped to an LCD function or a different hard button.
FaxMan is offline
post #21 of 93 Old 01-14-2007, 09:54 PM
wirechild73's Avatar
I am trying to decide between this 670 and the 880. I am leaning towards the 670 as I don't care much for the 880 LCD screen and the charging station.
My question, does anyone that owns the 670 have an XBOX 360 with the HD DVD addon? I went through the web setup and could not figure out I would control the HD DVD addon using the 670. Not a deal breaker, but I would like to know if it is possible and difficult it is to program.
I have 2 universal remotes now, plus you could consider the remote for my tv and pioneer receiver also universal remotes and I have not been able to get any of them to work well with the DVD or HD DVD drives on the 360 I am hoping/praying a harmony will make this easier.
XBL/PSN: wirechild
wirechild73 is offline
post #22 of 93 Old 01-16-2007, 06:52 PM
bmoss's Avatar
A couple of weeks ago, I used the Logitech web site to create an account and to configure a Harmony remote for four devices: Panasonic TH-50PH9UK plasma HDTV, Outlaw Audio 1050 receiver, Dish Network Vip 211, Oppo DV-970HD DVD player. All devices were in the database except for the plasma. I found last year's model, a TH-50PH8UK, in the database. The 8UK is functionally equivalent to a 9UK so I configured with the 8UK.
I ordered the Harmony 670 from Amazon and got it today. I installed the software and it updated itself to 7.0.2.1. I then logged into the Logitech members site and downloaded the configuration I had created several weeks ago.
The only problem I encountered was that on the Watch a Movie activity, the off button would not turn off the Outlaw 1050. I went to the support help pages and found that I needed to increase the inter-device delay for the 1050. After making this setting change in my account on the members web site, I downloaded a new configuration. It works. Total time to set up about 30 minutes.
bmoss is offline
post #23 of 93 Old 01-17-2007, 01:55 PM
nithos's Avatar
I have a 880 and it works flawlessly with my 360.
nithos is offline
post #24 of 93 Old 01-29-2007, 03:25 PM
sojodave's Avatar
Quoted: 16 Post(s)
Liked: 56
I got the 670 last Thursday. I added my devices and I was up and running in a half hour. I tweaked the buttons and added in more activities. I like the feel of the remote. The small buttons take a little getting used to. I am still trying to train my family on how it works. I have a 50" Vizio plasma, Panasonic 588 DVD player, Onkyo 604 receiver and a Dish 622. This remote is perfect for DVR use. Overall I am very happy with it and I would recommend it.
sojodave is offline
post #25 of 93 Old 01-30-2007, 08:53 AM
Kneecaps's Avatar
I got the remote a week or two ago and I'm pretty happy with it. I wish they had included A, B, and C buttons, as most DVRs and digital cable boxes use these buttons. Well, the ones I've always used have them anyway.. It also would have been nice to have an extra "List" or "DVR" button or something to bring up the DVR menu. I'm using the Menu button for that, so it's alright.
It's just that if they're marketing this as "great for DVRs" or whatever, they should have these extra, standard buttons. Obviously, I could be using the LCD buttons for all this, but it's just annoying to reach up there all the time. I'd rather use the LCD for weirder, non-standard stuff than for the stuff I use every day. Page up and down buttons are great, though, and I'm glad they put those in there.
The playback buttons are weirdly laid out, as well, but they're more accessible than on the other remotes in this price-range, so it'll do. It can be tough to tell which one you're hitting though, because they're all the same size and there's no little "bump" on any of the buttons to tell you which one you're on.
Of course, after all my complaining, I'm still WAY happy with the remote and I'm sure I will use this remote until a better Harmony comes along.
Kneecaps is offline
post #26 of 93 Old 01-30-2007, 12:19 PM
Packy's Avatar
I've always liked mapping the Stop button to the "list" for our Tivo. I did the same thing as you for the main menu, it's just mapped to Menu.
I also like the up and down arrows, which I've mapped to the thumbs up and thumbs down.
I am a consumer whore!
Packy is offline
post #27 of 93 Old 02-08-2007, 08:10 PM
zerostar's Avatar
How much battery life are you guys getting on this remote? When I first got it I was getting about a month and 1/2 that was with glow on every button and 10 sec. I turned glow only on the glow button and down to 5 sec. I ran out of batteries in 2 weeks now. Did I get bum batteries? Going to get some good ones and try again, perhaps something broke when I dropped it...
zerostar is offline
post #28 of 93 Old 02-09-2007, 04:17 AM
atreis's Avatar
I got my remote before Christmas and have yet to replace the batteries. I have full glow for 10s.
atreis is offline
post #29 of 93 Old 02-09-2007, 04:42 AM
Aliens's Avatar
Quoted: 1310 Post(s)
Liked: 1702
Got the 670 yesterday. Programming was a snap - getting used to a remote like this for the first time is an adjustment, but one I think will be well worth it. The cursor pad is just way too small. I can't imagine anyone with really BIG fingers being able to use this remote. I watch TV in a dark environment, but during my break-in period yesterday, the overhead lighting reflected off the keypad making it almost impossible to read each key function. I had to tilt it to various angles to see what was there. This won't be a problem once I memorize each key location/function, which will be very soon, but for others who aren't remote savvy or with room lighting, this is a PITA. While watching a recorded DVR show last night, the skip FW/RW stopped functioning, so I had to resort to the Dish 622 remote - that thing is sweet. Being a first time owner of a remote like this requires patience, something I'm not good at, but the upside is so fantastic I'll give it a week to tweak and then reassess whether the TC-30 or something else might be a better feel for me. The research continues.
Aliens is offline
post #30 of 93 Old 02-12-2007, 06:29 AM
lastplace's Avatar
Quoted: 33 Post(s)
The 670 is missing the a-b buttons. These are great for setting up commerical skips. I'll stick with my 676.
I love this HD stuff!
lastplace is offline
Reply Remote Control Area
