RCA RCU810 - some buttons stopped responding... Please Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-07-2007, 11:21 AM - Thread Starter
KillerQ's Avatar
Hey all,
I have an RCU810 that I use for everyday use when I am not using my nice touchscreen remote... Now, all of the sudden, the play/pause/stop, etc section at the bottom of the remote has stopped responding when I push the buttons. All other buttons are fine.
Some people on other forums have talked about opening it, cleaning it, and even adding foil under the buttons to increase conductivity. I have tried all of that with no luck.....
Has anyone had a similar problem with this remote, and if so, what was the best way to fix it. I can't see why these random buttons would just stop...
Thanks a ton in advance,
Matt!
KillerQ is offline
Reply Remote Control Area
