Harmony 890 first impressions - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 90 Old 04-30-2007, 08:46 PM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 430
Originally Posted by pwrmetal View Post
Just wanted to amend that I was looking at the web site today, and renaming an Acivity IS quite easy on the site. I am not sure what my problem was yesterday. Either I was having a brainfart, or the site was not behaving correctly (probably the former). I do still prefer the look of the regular software.
Does Logitech support the "regular" software anymore? Only the Web based software came with my newly purchased 890. Their Web site doesn't have it for download either. The remote's working great and doing exactly what I need, but I'm a gear-head and I'd like to try it.
erkq is online now
post #62 of 90 Old 05-01-2007, 07:22 AM - Thread Starter
pwrmetal's Avatar
The software that came with the remote is still web based. (You have to login to the online database to use it.) The front end is just different on the software that came with it as opposed to logging into the Harmony web site and using the web browser interface. That's the distinction I was making.
-John
pwrmetal is offline
post #63 of 90 Old 05-01-2007, 08:17 AM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 430
IC. Thanks!
erkq is online now
post #64 of 90 Old 05-14-2007, 07:54 AM
whodean's Avatar
I've had my 890 for only a couple of days and have played with it some, have a question.
After selecting activity "play pvr" to power up my components, the options on the 8 programmable buttons are different than if I push "device" and then "pvr" (I was able to customize those buttons to see exactly what I want on the first "page")
I'd like for my customized 8 buttons to pop up right after I select "play pvr" instead of having to push device then pvr to bring up this screen, anyone know how to do this?
whodean is offline
post #65 of 90 Old 05-14-2007, 05:39 PM
golovemd's Avatar
If you are pressing device then you are not using the remote properly. That will control ONLY that device. So your volume will not work while in the device mode for instance. If you do not have any of the desired buttons in your lcd customizable buttons, then you will want to further customize your remote. The software should have automatically put some options on those buttons to begin with. Login to your account and under the activities section, click on the (I believe) customize button. I am not 100% sure what it says on this button because I don't really use Harmony's anymore so I forget. Anyway, you are looking for the edit buttons option. From there you can add whatever functions pretty much that you want there. If I am a little off or you need more help, I am sure someone else will chime in. If they don't I will log into an account and take a peak to help guide you. I just don't have the software on this computer. I would have to grab my work laptop and boot it up to take a peak.
golovemd is offline
post #66 of 90 Old 05-14-2007, 07:30 PM
whodean's Avatar
Ah, thank you. I've got the hang of that now.
whodean is offline
post #67 of 90 Old 05-17-2007, 06:04 AM
M-I-G's Avatar
Newbie questions:
After reading this thread and checking the harmony it still isn't clear to me if the 890 will do RF and IR without the Z wave component.
My situation is this:
I have a Panny 9UK 65" on the front wall with the components in a rear cabinet currently using a niles IR extender which works pretty well for the most part. I would like to add X10 dimmer switches (rear of room) as well. My understanding is that X10 is RF so I am trying to find a remote that will allow me to do IR and RF to control both TV/components and lights.
M-I-G is offline
post #68 of 90 Old 05-17-2007, 10:51 AM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 430
Originally Posted by M-I-G View Post
Newbie questions:
As far as I know... not gonna happen directly. But I've been wrong before. This is probably too complicated for your application, but since I'm going to be using CQC anyway:
A USB IR adapter will be used to trigger a CQC event in response to the remote. CQC will then control Instean (or X10) dimmers through their PC based controller.
erkq is online now
post #69 of 90 Old 06-08-2007, 07:31 PM
tbsmith's Avatar
Can I use multiple RF extenders with one remote? I saw the reverse question earlier but haven't been able to verify this one. Thanks.
tbsmith is offline
post #70 of 90 Old 06-10-2007, 12:35 PM - Thread Starter
pwrmetal's Avatar
You should check with Logitech to be sure, but I *think* the 890 can handle up to 2 RF extenders.
-John
pwrmetal is offline
post #71 of 90 Old 06-14-2007, 07:37 AM
whodean's Avatar
I just got my system installed at new house, working on setting up activities for my 890...there is a device setting for a PS3 but I thought the PS3 remote was bluetooth?
whodean is offline
post #72 of 90 Old 06-14-2007, 12:57 PM - Thread Starter
pwrmetal's Avatar
Correct. The activity will set your tv, receiver, etc. to pay attention to the PS3, but the remote itself will not turn on/off or control the PS3 in any way without some sort of remote adapter for the PS3.
-John
pwrmetal is offline
post #73 of 90 Old 06-14-2007, 01:22 PM
whodean's Avatar
How is it that every wire coming out of the IR extender can have 2 bugs? can you use these 2 for different devices?
whodean is offline
post #74 of 90 Old 06-14-2007, 03:18 PM
seplant's Avatar
Quoted: 58 Post(s)
Yep, you can use the two emitters on the end of each wire on different devices.
seplant is online now
post #75 of 90 Old 06-14-2007, 03:20 PM
seplant's Avatar
Quoted: 58 Post(s)
If anyone has found any kind of adapter to use with the PS3, I'm all ears! It's a real pain to be able to replace all of your remotes except one!
post #76 of 90 Old 06-14-2007, 06:32 PM - Thread Starter
pwrmetal's Avatar
I don't think there is any PS3 IR adapter at this point. I think some people have a kludgey workaround with a PS3 to PS2 controller adapter and plugging in the PS2's IR adapter into that, but I think it only gives limited functionality. You should check in the PS3 forum. I don't have a PS3 yet, so I am not sure that what I describe is the actual workaround. I am sure everyone is hoping for a true PS3 IR remote adapter in the future.
EDIT: I looked for you. Kludge instructions here.
-John
pwrmetal is offline
post #77 of 90 Old 06-16-2007, 01:58 AM
winstonwolf's Avatar
I was wondering: are the emitters pass-through? In other words, if I want to use a device's original remote, would I need to remove the sticked-on emitter so the device can "see" the IR signal (from the original remote)?
winstonwolf is offline
post #78 of 90 Old 06-16-2007, 07:32 AM
chucky08016's Avatar
I currently have the H890 and I have had no problem controlling any devices (with the original remotes) that I have placed an IR emitter on.
chucky08016 is offline
post #79 of 90 Old 06-29-2007, 08:30 AM
evena's Avatar
Originally Posted by Soybean View Post
I also came in AFTER Logitech removed the ability to assign macros to a button, so I've never experienced that glorious level of customization. I'm joining the write-in effort to get them to restore it.
I too am joining it asking them to restore it. I have a 659 that I used for years with my old system that was great and the customizable macros were awesome. Setting up my 890 this weekend I was for sure disappointed to see that I could not seemingly doing anything that didn't seem too "basic".
ie, I wanted to tell the remote to switch my picture presets on my Mitsu TV after completing an activity change. Can't figure out how to do that now that macros are gone! Any thoughts or am I looking at just pressing that picture button myself?
evena is offline
post #80 of 90 Old 06-30-2007, 02:07 PM
Mark521's Avatar
Yes the emitters allow IR to pass through them, so no you don't have to remove them. You also don't have to exactly center the stick on emitter on top of the IR receiver on your target device, as the emitters are strong enough.
Mark521 is offline
post #81 of 90 Old 07-02-2007, 09:56 PM
MikeMcQ1's Avatar
A little clarification please on the RF Wireless extender and IR emitters...
My components are all located out of site behind a wall in a seperate room. Basically, I need the RF Extender in line-of-sight of the 890 with the IR emitters running to the components, correct?
But how strong is the 890's transmission and RF extender's reception? In an ideal world, I'd like the RF extender as "out-of-site" as possible, such as behind the TV (wall mounted 52" Samsung) where there are no actual "walls" seperating the 890 and the RFextender. i.e. will the signal work "around" objects?
MikeMcQ1 is offline
post #82 of 90 Old 07-02-2007, 10:02 PM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 430
It'll go through walls, even. Many use it to control components in a seperate equipment room. This is what I'll do as soon as the new house is done. They say 100' range.
erkq is online now
post #83 of 90 Old 07-02-2007, 10:19 PM
MikeMcQ1's Avatar
Hmmm...so I'll only need to place the RF extender near my components in that room? Do I even need the IR emitters if this is the case?
MikeMcQ1 is offline
post #84 of 90 Old 07-03-2007, 12:27 AM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 430
The emitter in the extender seems to be quite powerful. I don't use any of the wired emitters. I have two stacks of equipment and the extender is about 3 feet away. If your equipment room is crowded enough that you can't get that distance you may need the emitters. Just try it out. You may be surprised.
erkq is online now
post #85 of 90 Old 07-04-2007, 10:56 AM
stubeeef's Avatar
so does the extender have to "plug" into a component to control it? What do you do if it doesn't have an IR input jack?
WAF
stubeeef is offline
post #86 of 90 Old 07-04-2007, 11:27 AM
erkq's Avatar
Quoted: 599 Post(s)
Liked: 430
The extender has its own IR emitter built in. If you have the room to face the extender toward the components you want to control it works great. There's a coverage "cone" so the larger the area your components span the further away you'll have to place the extender. If you don't have room for the extender's "cone", that's what the individual emitters are for.
erkq is online now
post #87 of 90 Old 07-04-2007, 11:35 AM
stubeeef's Avatar
that makes sense, thanks erkq!
WAF
stubeeef is offline
post #88 of 90 Old 11-06-2008, 01:54 AM
fly4christ78's Avatar
Question: do you think the 890 is the remote I need, read below:
I have decided that instead of worrying about lost remotes what I need to do is get one remote to control everything. My other problem is that I got a new rack for all of my AV equipment and I can not control everything in the rack from every seat in the theater. I thus need a RF remote. Of course the same last problem is that I am a pilot and I am currently gone and my wife and visiting parents sometimes are not able to get everything set up correctly and I often get a call while out of state for directions as to how to do things. I have the following components.
Onkyo TX-SR674S 7.1 Channel Up-Converting A/V Receiver (Silver) (this selects my HDMI input and controls the sound)
Sony 40Gb PS3 (this I know is RF, and will be a problem, we use this to watch DVD’s and BD movies, and I use it for games)
Samsung DTBH260F HDTV Terrestrial Receiver (this is used to watch TV very infrequently, mostly just watch the Steelers!)
Channel Master 9521A Remote Control Antenna Rotor (this controls the direction of the antenna and is controlled by a small IR remote. Some channels require me to change the direction to get continued signal.)
Panasonic PT-AE3000 projector
My question is what remote should I use? I can put little emitters on the rack door (screen mesh) or directly on the components, but I can not put an IR emitter in front of them all to hit them all at the same time. I know the PS3 will be a problem and I could live with two remotes if I have to. Also is there a way to program the remote to change the direction of the antenna when ever I change the channel (I get about 15 different channels)? In the future I would like to expand and have a remote that could control lights and maybe even open the curtain in front of the projector screen. Also in the future I want to add a HTPC and a 15Tb media server. Can you guys recommend a reasonable remote, I just blew a big chunk on the projector so money is really a problem right now, but I maybe can get this for Christmas?
fly4christ78 is offline
post #89 of 90 Old 03-15-2009, 07:57 AM
cuciu76's Avatar
I have a problem....
when i close an activity, watch tv, with panasonic tv, dvdo edge and sat, the dvdo edge doesn't go off...it continue to be on. why? what do i miss?
cuciu76 is offline
post #90 of 90 Old 03-15-2009, 02:35 PM
Florida's Avatar
This thread has had almost no activity in two years. Go to the official 880 thread and post your question - you will get a response there.
Florida is offline
Reply Remote Control Area
