Comcast Custom DVR 3 + Sony DAV-C700 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-23-2007, 11:24 PM - Thread Starter
moahiek's Avatar
After trying every code on the manual and searching for the code manually, I still can't program the comcast remote to work with my Sony DAV-C700 Home theater system.
I got it work on my old comcast remote, which used 4 digit codes. But now I can't get it work with this new comcast remote which uses 5 digit codes.
I don't remember the 4-digit code that worked before, I don't have the original sony remote, and I don't have a JP1 cable either.
Can anyone please help me? I've come to a dead end with just searching online.
moahiek is offline
post #2 of 9 Old 09-24-2007, 12:20 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
If this is a UEI made remote, then code for sony dream systems is AUD/AUX 1658.
Edmund is offline
post #3 of 9 Old 09-24-2007, 08:31 AM - Thread Starter
moahiek's Avatar
Thanks Edmund, but my comcast remote only accepts 5-digit codes and adding a zero infront of old 4-digit codes doesn't seem to work...
moahiek is offline
post #4 of 9 Old 09-24-2007, 08:46 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
Then try code 31658.
Edmund is offline
post #5 of 9 Old 09-24-2007, 09:47 AM - Thread Starter
moahiek's Avatar
Nope didn't work, it gave me a long blink after i entered that code.. what else can i do?
moahiek is offline
post #6 of 9 Old 09-24-2007, 09:53 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
With the receiver on try a codesarch by volome instead of power:
1. aux
2. press and hold setup for two blinks
3. enter 9 9 1, wait two blinks
4. enter 3
5. press VOL UP and release
6. keep pressing and releasing the CH UP, if and when the volume changes
7. press setup to lock in code
Edmund is offline
post #7 of 9 Old 09-24-2007, 10:15 AM - Thread Starter
moahiek's Avatar
Still no luck... I can't believe this. Should I try the other 4-digit codes from the older comcast remotes and add a 3 in front of them?
moahiek is offline
post #8 of 9 Old 09-24-2007, 10:26 AM
Edmund's Avatar
Quoted: 50 Post(s)
Liked: 30
If you fail to come up with hit during codesearch that proves that there isnt a preset code in that remote to find.
Edmund is offline
post #9 of 9 Old 09-24-2007, 10:31 AM - Thread Starter
moahiek's Avatar
and the only way to program it is to use JP.1 cables?
moahiek is offline
Reply Remote Control Area
