Samsung Remote & Motorola STB DCT6416III Codes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-24-2007, 04:57 PM - Thread Starter
MaverickIA's Avatar
All,
I just bought a Samsung LCD TV (Model #LN-T4066F) From Best Buy. I have a Motorola DCT6416III Set Top Cable Box. I want to use my Samsung remote that came with the TV to control my Motorola STB. None of the codes in the manual work. I have tried codes #041, #043 and #046.
Does anyone have an idea what code will actually work with this configuration? Samsung's web site mentioned that #043 "may" work.
Any help appreciated.
MaverickIA is offline
post #2 of 6 Old 10-07-2007, 10:44 AM
schwachs's Avatar
I am having the same issue. Also, is this considered a Set Top Box or a Cable box?
schwachs is offline
post #3 of 6 Old 10-07-2007, 12:36 PM - Thread Starter
MaverickIA's Avatar
Here is what I found earlier this week:
Code #041 can be programmed under the Cable option on the Samsung remote. This allows you to turn the TV and Motorola cable box off with the Samsung remote BUT it does not allow you to access the on screen menus or DVR menus of the Motorola cable box. This leads me to believe that for full functionality, you need to program the STB function. I've tried many codes (not all of them yet) to no avail.
Unless someone has this configuration working, I may have to try every code just to see what if any of them will work. Any help is appreciated!
post #4 of 6 Old 10-19-2007, 05:08 AM
jeffreykristin's Avatar
I have the same issue. I googled the internet and the best I can do is to get the remote to turn the STB on and off. Not good enough.
If someone figures this please share...
jeffreykristin is offline
post #5 of 6 Old 11-24-2007, 11:59 AM
podo's Avatar
Ive gotten 038 to work if that doesnt work use 039
podo is offline
post #6 of 6 Old 10-03-2012, 05:03 PM
mtmcrawford's Avatar
Hey guys I have gotten 258 to work perfectly fine on several different occasions.
mtmcrawford is offline
Reply Remote Control Area
