Schmart Solutions for PS3 IR Control (Discussion, Feedback, Q&A) - Page 32 - AVS Forum | Home Theater Discussions And Reviews
post #931 of 951 Old 11-12-2008, 01:23 PM
leemathre's Avatar
Quoted: 41 Post(s)
Originally Posted by drhankz View Post
Forum works fine for me.
http://ps3ir.com/simplemachinesforum....php?board=9.0
That's the link I am using. Every time I try it, I get this error
Database Error: Lost connection to MySQL server during query
File: /home/content/a/u/s/austindesign/html/simplemachinesforum/Sources/Security.php
Line: 279
Mike, I think you are right about the test site. That appears to be where I was. None of the links work.
Lee Mathre
Las Vegas, NV
leemathre is offline
post #932 of 951 Old 11-12-2008, 01:32 PM
MMuecke's Avatar
I just clicked on the link in your post and it worked great. That is a puzzler.
Also, what site did you go to that had broken links?
Mike
MMuecke is offline
post #933 of 951 Old 11-12-2008, 01:45 PM
leemathre's Avatar
Quoted: 41 Post(s)
The link I tried was ps3ir.com. It appears now that the links do work. I think my problem was that when clicking the support link, the page does not appear to change. I have noticed now that there are some minor changes to the page. I was just exspecting the support link to take me to the support forums. I still get the error message I mentioned above and I have tried from at least three different networks and as many computers. OH well, appears just to be me.
Lee Mathre
Las Vegas, NV
post #934 of 951 Old 11-12-2008, 03:08 PM
MMuecke's Avatar
yes ps3ir,com is something i was experimenting with many moons ago, I will redirect it this afternoon
please go to Schmartz.com to visit our site
MMuecke is offline
post #935 of 951 Old 11-12-2008, 05:06 PM
bpratt2's Avatar
The Support Forum link does not work on your site.
bpratt2 is offline
post #936 of 951 Old 11-12-2008, 05:46 PM
MMuecke's Avatar
It's working now. We were trying to forward the PS3IR.com domain to our current site but it also forwarded the forum doh!
MMuecke is offline
post #937 of 951 Old 12-04-2008, 12:20 PM
insane79's Avatar
^^ sent u a PM
insane79 is offline
post #938 of 951 Old 12-20-2008, 08:30 AM
insane79's Avatar
hi,
i received the adaptor, flawless design, ur'll guys are SUPERB
i got the harmony remote i added the ps3 as game console with dvd ps3irx1 as the instruction leaflet but the ps3 shutdown feature is not working
any help?
thanks..
Burjor
insane79 is offline
post #939 of 951 Old 12-20-2008, 08:39 AM
MMuecke's Avatar
Originally Posted by insane79 View Post
hi,
any help?
thanks..
Burjor
With the X1, simply navigate over to the far left and topmost item on the PS3 menu. There you will find the command to turn off the PS3.
If you want full control of turning the PS3 on and OFF, you need the PS3IR-PRO version
MMuecke is offline
post #940 of 951 Old 12-20-2008, 08:41 AM
insane79's Avatar
i think i read some where abt some macro commands which will make the harmony remote shut down the ps3??
insane79 is offline
post #941 of 951 Old 12-20-2008, 09:53 AM
MMuecke's Avatar
That requires the macro in the PRO version. The X1 is the entry level model and doesn't have the shutdown macro. However, assuming you are at the PS3 menu level, it is a simple matter to add a shutdown macro in the Harmony itself. If you search on that on this forum you will find several discussions about doing just that.
Keep in mind though, since the X1 does not have a PS button function, it is more complicated to shut down if you are in a game or watching a movie since you have to return to the PS3 menu first.
MMuecke is offline
post #942 of 951 Old 12-28-2008, 03:48 PM
DEIFan's Avatar
Mike,
Got a PS3IR-Pro for Christmas from the wifey and wanted to check for updated firmware before I installed it, but I'm getting an error message on your site. I went to schmartz.com which forwarded to schmartstff.com and when I click on the Support Forum link i get the following error:
Line: 279
Check it out and let us know, thanks.
DEIFan is offline
post #943 of 951 Old 12-28-2008, 04:03 PM
DMILANI's Avatar
Try this out:
http://ps3ir.com/simplemachinesforum...373b&board=9.0
Originally Posted by DEIFan View Post
Mike,
Line: 279
DMILANI is offline
post #944 of 951 Old 12-28-2008, 04:11 PM
DEIFan's Avatar
Thanks, but no dice. Same error:
Line: 279
DEIFan is offline
post #945 of 951 Old 12-28-2008, 05:46 PM
leemathre's Avatar
Quoted: 41 Post(s)
Line: 279
I haven't been able to get onto that site for several weeks. I get the same message. I have tried it from several different locations, different operating systems and different browsers. I reported it earlier in this thread, but until now it seemed that I was the only one having the problem. I am sorry that you are having issues, but I am relieved to know that it is not just I with the problem.
Lee Mathre
Las Vegas, NV
post #946 of 951 Old 12-28-2008, 07:19 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
Line: 279
THIS LINK works for me - it is the same one that DMILANI
Provided.
BUT COMPARE DMILANI's Link to yours. THEY ARE RADICALLY
different. Your Computer is changing them to something else.
drhankz is offline
post #947 of 951 Old 12-28-2008, 08:52 PM
DEIFan's Avatar
drhanks -- What I posted is not the link I am trying to use, but the resulting error message on the screen. When i tried your link (http://ps3ir.com/simplemachinesforum/index.php) I get the same error. I have also tried the following:
http://austindesignlabs.com/simplema...orum/index.php
http://ps3ir.com/simplemachinesforum...373b&board=9.0 (DMILANI's link)
This is from Firefox 3.0 as well as IE 7.0 on both my computer and my wife's laptop. Yet I can get to the page and login and go thru the forum on my iPhone, no problem on the cellular network. Weird. I'll try tomorrow from work and see what happens.
DEIFan is offline
post #948 of 951 Old 12-29-2008, 07:13 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
drhanks -- What I posted is not the link I am trying to use, but the resulting error message on the screen. When i tried your link (http://ps3ir.com/simplemachinesforum/index.php) I get the same error. I have also tried the following:.
I still smell a computer intervention - so to speak.
The only other thing I can think of is DMILANI and I are registered
users. When we click on that link - the website knows who we are.
You should be taken to a page to register. That seems to be not
working!
drhankz is offline
post #949 of 951 Old 12-29-2008, 08:26 AM
MMuecke's Avatar
Mike,
Line: 279
BTW, all devices are loaded and tested with the latest firmware which has not changed for several months now.
MMuecke is offline
post #950 of 951 Old 12-29-2008, 09:41 AM
DEIFan's Avatar
It's gotta be something weird with my ISP (Cox) since it works from my work computer as well as my iPhone over cellular. Anyways, thanks Mike for the confirmation about the latest version. Good deal.
DEIFan is offline
post #951 of 951 Old 12-29-2008, 09:45 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
AGAIN - my two cent suggestion is not to point the finger at Cox.
Point your finger at your own Computer since the other computers
are doing it fine.
drhankz is offline
Reply Remote Control Area
