Programming an RTI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 55 Old 12-21-2007, 08:53 AM - Thread Starter
rickeame's Avatar
I have an RTI system, and rather than call my installer out for every tweak, I would like to learn to make some tweaks myself.
How hard is it to program?
Rick
rickeame is offline
post #2 of 55 Old 12-24-2007, 01:20 AM - Thread Starter
rickeame's Avatar
nobody....really?
rickeame is offline
post #3 of 55 Old 12-24-2007, 05:47 AM
thebland's Avatar
Quoted: 1519 Post(s)
Liked: 867
What do you need help with...? Let me know. Mark Rubin is also an RTI expert.
I have almost 60 pages programmed into my RP6, T3 combo.. Bulletproof RF.
Best remote I have ever seen for the end user.
Great choice!!
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is online now
post #4 of 55 Old 12-24-2007, 10:35 AM
hfriedman's Avatar
I would love to have an RTI remote. How do you guys get the software to program and support it? Everything I have raed indicates they do not want end users programing their stuff.
hfriedman is offline
post #5 of 55 Old 12-24-2007, 10:09 PM
Nasty N8's Avatar
I want to know as well looking for the best remote system for my setup but want to do the programming. If I cannot set it up the Harmony will have to do.
Nate
www.NastyPerformance.com
10,000 Watts, custom built speakers, 10' CIH screen = Holy Crap
Nasty N8 is offline
post #6 of 55 Old 12-26-2007, 06:32 AM
dfrey's Avatar
Not that hard to program - slight learning curve.
I agree with Jeff that the RF of RTI gear is great. Easy integration of RS-232 gear is also nice. One of trickier things is getting proper RS-232 strings since it seems alot of manufacturers use different command protocols (hex, checksums, etc.), but once you figure out one command for a piece then it's easy.
Overall, if you have a dealer that will work with you on the software, programming isn't that difficult.
David
dfrey is offline
post #7 of 55 Old 12-26-2007, 06:52 AM
shah993's Avatar
Is the software included in the box with the remote?
shah993 is online now
post #8 of 55 Old 12-26-2007, 08:36 AM
sunstar's Avatar
RTI markets their remotes directly to the CI and the software is not included with the remote. Most dealers will not give the s/w to the enduser; although if you have a good relationship with the dealer you may get lucky.
sunstar is offline
post #9 of 55 Old 12-29-2007, 05:21 AM
thebland's Avatar
Liked: 867
Best remote I have ever seen for an end user (though not technically for the end user).
I have 5 RS232 components as part of my system and 10 IR components. All reliably controlled.
My system start up Macro has over 15 commands that are alway releabley executed.
You''ll pay more than a Harmony, but you get what you pay for. This is as close to a Crestron as you can get but no programmer needed.
Check online dealers, you can find the software..
post #10 of 55 Old 12-29-2007, 07:14 AM
Super Moderator
markrubin's Avatar
Quoted: 1084 Post(s)
Liked: 2422
Big RTI fan here too
RTI is just introducing 2 way RS232 control and Zigbee communications, plus many whole house control products
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #11 of 55 Old 12-29-2007, 01:17 PM
Glackowitz's Avatar
RTI programmer and personal user here too, We switched about 2 1/2 years ago and havent been happier with a product.
RF is awsome, the additional sensors and 232 make it great, its more than URC but it also works better.
We went thru several systems using URC with poor RF and after it was all over it would have been less to install crestron
RTI interfaces with crestron quite well and we have used it that way as well, works awsome and clients love it
Glackowitz is offline
post #12 of 55 Old 12-29-2007, 01:43 PM
Perfectionist2's Avatar
Quoted: 43 Post(s)
Does RTI interface with AMX?
Perfectionist2 is offline
post #13 of 55 Old 12-29-2007, 05:40 PM
Glackowitz's Avatar
Yes, quite well actually
There is more info on the RTI website in the dealer section
post #14 of 55 Old 01-01-2008, 11:07 AM
stanger89's Avatar
Quoted: 2885 Post(s)
Liked: 1503
thebland,
Could you give a little more detail (honestly I'm not sure what I'm looking for) about setting up an RTI "system"? I've been looking (for years literally) for a solution to manage the remote madness in my HT, but things like Harmony's and "universal" remotes just leave me wanting. Also, while touchscreens are cool, they just don't work well with my usage model, I need/want/like all the "standard" remote buttons as hard buttons (transport controls, arrows, numbers, etc). The RTI T-2C line looks like it has the potential to fulfill my desires.
stanger89 is offline
post #15 of 55 Old 01-01-2008, 11:23 AM
barhoram's Avatar
Quoted: 125 Post(s)
Liked: 34
The house we moved into has a couple of RTI in wall controllers. Apparently there is a firmware upgrade to enable flash on websites. We called the company that put the system in, but they no longer handle RTI. RTI doesn't list dealers on their site, and the only contact listed is the large major distributor who acted like they don't talk to end customers direct. Anyone know what it involved with a firmware upgrade on a T4/K4? Was hoping it was a simple download and install. Shoot me a PM. Thanks.
barhoram is offline
post #16 of 55 Old 01-01-2008, 06:22 PM
mike pesci's Avatar
Yep!! RTI programmer and personal user as well!!! T2+ and the T2C is awesome remotes, best of both worlds, touchscreen and hard buttons. It is really flawless.
mike pesci is offline
post #17 of 55 Old 01-02-2008, 09:31 AM
dfrey's Avatar
Stranger89 - not thebland, but i have the T2c and a T3. As Mike said, the T2c is the best of both worlds, touchscreen and hard buttons. Build quality is awesome and is just an all-around great product.
As far as setting up an RTI system, you'll need:
1.) a Processor - technically don't need one, but all of the advanced features, including RF communication, RS-232, sensors, etc require one. And overall, the processor/remote combo is where the strength of the RTI system is. You'll need either the RP1 or RP6. Which one depends on your system. If you just want RF communication but will then control everything via IR you can get away with the RP1. If you'll want to add RS232 or voltage/video sensing, then you'll need the RP6. If you choose the RP6, then you'll also need RTI's rm-433, which is what receives the RF signals transmitted to the RP6. The RP1 is both an RF receiver and processor in one unit.
2.) a Remote - I'd coose the T2c currently. RTI is supposed to be coming out with T2cs in the 1st quarter. This might be a better solution for you as it has alot of the benefits of the T2c but with a smaller touchscreen and I think it's a couple hundred bucks cheaper.
3.) Accessories - depends which processor you go with, but with either one, you'll likely need some IR emitters. If you go with the RP6 for RS232 control, you'll also need RTI's serial communication cable for each device you control via RS232.
That's about it. Of course you'll also need the thing programmed. You can work that out with your dealer. Again programming isn't that difficult, but there are some nuances.
RTI isn't an inexpensive proposition, but you get the high-end look and feel, advanced control and, for me at least, it's rock-solid controlling everything I need controlled.
David
dfrey is offline
post #18 of 55 Old 01-02-2008, 10:31 AM
stanger89's Avatar
Liked: 1503
Thanks, that's a good bit of the problem though, as near as I can tell, I don't have a dealer (AVAD doesn't list anything in Iowa), and none of the HT shops appear to carry RTI.
Second problem is I've heard some, IMO, astronomical numbers for getting remotes programmed, I'm not the best programmer in the world, but I do do coding at work, and on the side, I've done some Girder "programming", which from what I can glean is very similar to what these remotes use, at least in thought process if not syntax.
Add to that the fact that I'm just simply more of a DIY person than a "pay to get it done" person, and I'm not willing to drop a couple hundred to have someone do something I could.
post #19 of 55 Old 01-03-2008, 05:36 PM
Nasty N8's Avatar
I have a buddy that carries them Looks like I will be getting into one soon.
Nate
Nasty N8 is offline
post #20 of 55 Old 01-07-2008, 07:35 AM
blicj11's Avatar
I have had a T2C for about 6 months. For several weeks at a time it is the best remote I have ever had. Every couple of months, in the middle of use, all the soft buttons will lock up. I can't reload the program or get to the reset screen. The dealer has been very nice about taking it back and swapping for a new one, but this has happened to me three times, most recently yesterday. Anyone have any ideas?
blicj11 is offline
post #21 of 55 Old 01-07-2008, 07:38 AM
Super Moderator
markrubin's Avatar
Liked: 2422
this happens: one of my T2C's locked up this morning: I noticed the display never went off and the light on the RM433 stayed on: had to reboot the remote
Last night my T4 locked up (stopped responding)
I think it is the nature of the beast: consider that these things run on a variant of Windows CE
post #22 of 55 Old 01-09-2008, 07:31 AM
blicj11's Avatar
With my T2C, I cannot reboot the remote. Taking the battery out, waiting 30 minutes, then reconnecting did not solve the problem. I am unable to reload the programming. I cannot get to the reset screen. My only option is to return the remote to the dealer and get a new one. Frustrating. However, when the remote is working, it's the best!
blicj11 is offline
post #23 of 55 Old 02-28-2008, 11:34 AM
blicj11's Avatar
An update, in case anyone else out there has the same issue or any insight. Since my last post I have had two replacement T2-Cs. Each one worked for a few weeks before the screen locked up and allows no soft button selection. Cannot get to the reset screen or technicians screen. RTI is still researching and claiming its never happened before. I have no idea what is causing it. Hope one of you fellow AV forumites has an idea.
blicj11 is offline
post #24 of 55 Old 02-28-2008, 02:37 PM
Greg C's Avatar
Remove the battery cover. There is an on/off switch on the lower left side. Turn off for about a minute then back on.
Greg C.
www.pghcustomht.com
CEDIA University Designer CAT Member
CEDIA University Instructor
Crestron DMC-E
Greg C is offline
post #25 of 55 Old 02-28-2008, 09:25 PM
roddymcg's Avatar
I had a couple early T2c's out there go bad on us, got an RA right away and they sent us replacements pretty quick.
I have had one in the house for a few months now with no issues, I am a hug fan of RTI. I like Crestron bit better, but I can only afford to install that product so far...
roddymcg is offline
post #26 of 55 Old 03-01-2008, 12:03 PM
blicj11's Avatar
Thanks, I had already tried that, as well as removing the battery for a few minutes and then reinstalling. Neither of these did the trick. Getting replacements with RAs is the only solution but I'd like to know what causes the problem to recur. It can't be random unless I am the unluckiest person in the Western Hemisphere.
blicj11 is offline
post #27 of 55 Old 03-15-2008, 09:43 PM
AnthemAVM's Avatar
What price are you looking at for a fully installed system with the T3?
AnthemAVM is offline
post #28 of 55 Old 03-15-2008, 09:59 PM
roddymcg's Avatar
Depends on the gear, we do a flat rate with systems we put together. We charge by the hour when it is not our design. I say this from experience, some product just does not automate very well so I steer away from a lot of product.
roddymcg is offline
post #29 of 55 Old 03-24-2008, 08:23 AM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Hey Anthem,
If you are thinking RTI...contact Spackman....he does that.
RayJr
Rayjr is offline
post #30 of 55 Old 03-26-2008, 05:23 AM
jevans64's Avatar
Quoted: 192 Post(s)
Liked: 147
I have an RTI dealer in my area. I have purchased a lot of stuff from them in the last year. When they said that they would not provide the software with the remote I turned around and walked out.
RTI may make good remotes but they are useless to me if they want to lock their end users out of being able to add commands without having a dealer do it. I would want to change a button or command in TWO minutes --- not TWO DAYS.
URC is heading down this path also but at least I can get the software from a dealer.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Reply Remote Control Area
