Sony Remote to Vizio TV Code - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-22-2007, 01:51 PM - Thread Starter
rwkyle's Avatar
Hello all thanks ahead of time from a new user.
I have just purchased a Vizio VW32 LCD TV. I have a Sony SAT-B65A Direct TV receiver(about 5 years old) and it came with a Sony RM-Y812 remote. Of course I want to be able to power the Vizio on and off and run the volume. Any advanced functions would be a plus but I will take volume and Power. Anybody have an idea's for a code(s) to run it.
**Update**
Well after finding the remote on Sony's website I found that the codes were all 3 digit codes. So I started writing them down and most seemed to be common from tv model to tv model. I started at 100 and when I got to 103 it powered off the TV, oh joy!! it also ran the volume. So that is what I need it to do. We are only using this in our bedroom so that will do. I may going to try some other codes to see if it will work in the menu. I bet this will work for other Sony remotes.
rwkyle is offline
post #2 of 4 Old 12-22-2007, 07:35 PM
Edmund's Avatar
Quoted: 54 Post(s)
Liked: 31
Check the codes listed under Goldstar or LG.
gnk1 likes this.
Edmund is offline
post #3 of 4 Old 07-14-2009, 08:16 PM
webmasterf's Avatar
Thanks! I just got my Vizio on Sunday and have been frantically seareching for that darn code!
webmasterf is offline
post #4 of 4 Old 11-12-2012, 05:27 PM
chavezy's Avatar
I have a older sony DVD player and A Vizio tv. Couldnt find a code
But the LG code worked for my sony remote so now i.can turn the tv off and on and control the volume too. I used this website http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=32&DIRECTOR=RCODES
I have a vizio and it is NOT an option here but the LG code "04" worked for me.
Good luck to you all.
chavezy is offline
Reply Remote Control Area
