Comcast Custom DVR 3 Device & Sony DAV-C450 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-29-2007, 03:34 PM - Thread Starter
o2sk8's Avatar
Just got Comcast and would like to control the volume with the Comcast remote. Searched quite a bit and can't find anything that works. I tried the auto-search mentioned in this thread (edit: apparently I don't have enough posts to post a URL, but it is thread ID 912902), but that didn't work. He never got a response so I was hoping someone could either point me in the direction a code or whatever it would be I need to get this to work. Thank you very much.
o2sk8 is offline
post #2 of 6 Old 12-29-2007, 04:21 PM
ar7499's Avatar
I have had comcast for a while now. As far as I can tell, there is no way to have the comcast remote change volume on a receiver without switching control devices. There does not seem to be any punch-through code.
Having to constantly switch to the receiver to change volume, and then back to cable to change channels was enough to drive me to a urc-810. It's too bad too, because you can't find a remote that is easier to access the advanced (pvr and on-demand) features of the comcast remote.
One of the many shortcomings you will find as you get used to comcast, but hey, they're comcastic. Unfortunately, their commercials are their greatest strength.
ar
ar7499 is offline
post #3 of 6 Old 12-29-2007, 09:30 PM
Kupakai's Avatar
I don't think you will find a setup code that will give you full control, but there might be a way to make some of the functions work, including volume control. Try the following to add volume functions by "borrowing" the correct protocol from AUX/1232:
1. First set the setup code for AUX to 1232
2. Press and hold SETUP until the remote blinks twice
3. Type 994
4. Press and release SETUP
5. Type 32975
6. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with the Sony HT device. For each of the following function codes, follow steps 2 to 6 and use the code listed for step 5 and press the key you want to assign that function to in step 6.
Vol+ = 32975
Vol- = 31951
Power = 32719
There are other functions, but many of them you can't program in without using a JP1.2 cable to upload a new upgrade file to the remote.
You should be able to change the punch through device to AUX using the instructions in the manual (see the direction under "Locking Volume Control to TV or AUX Mode").
Kupakai is offline
post #4 of 6 Old 01-25-2008, 06:50 AM
lachrymist's Avatar
Those codes worked beautifully...but i need one more
Where did you get these codes? what would i search for...cause these are different codes than i have used for previous comcast remotes...
I'm looking for a code to change functions on the Sony HT
bascically it's the TV/VCR button (Switch A/B)
thats the one i need
but i need it from the same list of codes you got these from:
any ideas??
Vol+ = 32975
Vol- = 31951
Power = 32719
lachrymist is offline
post #5 of 6 Old 06-08-2008, 05:35 PM
stussy2112's Avatar
Did any one ever get the complete list of codes for the DAV-C450?
stussy2112 is offline
post #6 of 6 Old 10-30-2013, 04:38 PM
smnetworks's Avatar
This helped with my remote settings:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Mute = 33743
Input/Function = 44750
and try these :  Sony15 seems to work for  me.
Function            EFC           Device Subdevice
Theater Sync        43333   Sony12   1   none
TV Power            34629   Sony12   1   none
Display             53199   Sony15   80   none
Function            44750   Sony15   208   none
0                   50894   Sony20   16   16
1                   19150   Sony20   16   16
2                   18126   Sony20   16   16
3                   18638   Sony20   16   16
4                   17614   Sony20   16   16
5                   19406   Sony20   16   16
6                   18382   Sony20   16   16
7                   18894   Sony20   16   16
8                   17870   Sony20   16   16
9                   51918   Sony20   16   16
TV Input            10053   Sony12   1   none
Angle               33998   Sony20   16   16
Audio               35022   Sony20   16   16
Clear               50638   Sony20   16   16
Disc Skip           59854   Sony20   16   16
Down                63182   Sony20   16   16
DVD Display         02766   Sony20   16   16
DVD Menu/Album +    02254   Sony20   16   16
DVD Top Menu        01742   Sony20   16   16
Enter               52174   Sony20   16   16
Fast Fwd/Tuning Up  27598   Sony20   16   16
Left                63694   Sony20   16   16
Preset +            26318   Sony20   16   16
Open/Close          60366   Sony20   16   16
Pause               16078   Sony15   208   none
Play                16590   Sony15   208   none
Preset -            27342   Sony20   16   16
Return              63438   Sony20   16   16
Rewind/Tune Down    25806   Sony20   16   16
Right               62670   Sony20   16   16
Search Forward      09422   Sony20   16   16
Search Reverse      10446   Sony20   16   16
Select, Enter       64462   Sony20   16   16
Shuffle             43214   Sony20   16   16
Stop                17102   Sony15   208   none
Subtitle/d. Tuning  34510   Sony20   16   16
Up                  64206   Sony20   16   16
DVD Angle           14236   Sony20   26   73
DVD Audio           15260   Sony20   26   73
DVD Clear           50588   Sony20   26   73
DVD Disc Skip       58780   Sony20   26   73
DVD Display         39836   Sony20   26   73
DVD Menu            02204   Sony20   26   73
DVD Open/Close      35228   Sony20   26   73
DVD Pause           59036   Sony20   26   73
DVD Play            16590   Sony15   208   none
DVD Play Mode       42140   Sony20   26   73
DVD Repeat          43932   Sony20   26   73
DVD Return          51612   Sony20   26   73
DVD Setup           38044   Sony20   26   73
DVD Stop            60060   Sony20   26   73
DVD Subtitle        13468   Sony20   26   73
DVD Time            43676   Sony20   26   73
DVD Title           02204   Sony20   26   73
DVD                 61391   Sony15   80   none
Mute                33743   Sony15   80   none
Power               32719   Sony15   80   none
Power Off(discrete) 40399   Sony15   80   none
Power On (discrete) 41423   Sony15   80   none
Sleep               13007   Sony15   80   none
Tuner               07887   Sony15   80   none
Volume Down         31951   Sony15   80   none
Volume Up           32975   Sony15   80   none
Play                24782   Sony15   208   none
Sound Field –       44494   Sony15   208   none
Tune –              41934   Sony15   208   none
Tune +              40142   Sony15   208   none
Tuner Men           41422   Sony15   208   none
Dynamic bass        53198   Sony15   208   none
Movie/Music         52430   Sony15   208   none
Video Format        16846   Sony15   208   none
Picture Navi        03022   Sony20   16   16
Tools               28110   Sony15   208   none
Advance             10958   Sony20   16   16
Replay              09934   Sony20   16   16
Sound Field+        45518   Sony15   208   none
Sound Field+        44494   Sony15   208   none
Tuner               48591   Sony15   80   none
Satellite/Video2    00463   Sony15   80   none
Video 1             08399   Sony15   80   none
smnetworks is offline
Reply Remote Control Area
Sony Dav C450 Dream System
