Official Logitech Harmony One thread - Page 274 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
post #8191 of 12107 Old 02-20-2011, 06:38 PM
ShadowTowel's Avatar
Thanks guys, you have swayed me towards the One so far. I'll keep saving.
ShadowTowel is offline
post #8192 of 12107 Old 02-20-2011, 06:46 PM
Ghpr13's Avatar
Look around online, I got my from Abt in Chicago for $149.00, no tax and free shipping. Amazon.com also had it for $149.00.
It's been a great remote so far. I had a Harmony 670 and that one serve me will, but I wanted to upgrade to the One.
Ghpr13
Info=Knowledge=Understanding=Better TV!
I see dead pixels!
Ghpr13 is offline
post #8193 of 12107 Old 02-20-2011, 07:53 PM
tokerblue's Avatar
Quoted: 95 Post(s)
Liked: 67
I had the 880 for about 3 years and the buttons started failing toward the end. Harmony offered me 50% off on the One about 1.5 years ago. Unfortunately, my Guide button (which is used a lot) on the One is starting to become unresponsive without a hard button push.
A little disappointed that my 880 seemed to hold up to harder use.
tokerblue is offline
post #8194 of 12107 Old 02-20-2011, 09:26 PM
Ghpr13
Thanks for the shopping tips! I'll definitely keep my eyes peeled for deals. Is buying used a bad idea due to button wear-down?
post #8195 of 12107 Old 02-20-2011, 09:40 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Buying a used harmony is a bad idea for many reasons. Not only could it be worn out, but it's possible the used harmony you buy has been deactivated by logitech if it was already replaced under warranty. Buying a refurb, on the other hand, is fine since it's still under warranty, and can save you a lot of money.
mdavej is online now
post #8196 of 12107 Old 02-20-2011, 09:44 PM
Are refurbished ones readily available or no? Like is there a website or eBay store that has official refurbished ones?
post #8197 of 12107 Old 02-20-2011, 11:00 PM
b_scott's Avatar
Quoted: 37 Post(s)
I just realized the motion sensor in my H1 doesn't work anymore. I wonder if they'd replace it. Probably not.... I got it in mid 2008.
b_scott is offline
post #8198 of 12107 Old 02-20-2011, 11:03 PM
Geezer's Avatar
Quoted: 20 Post(s)
I got my refurbished One @ Tigerdirect for $125.
Geezer is offline
post #8199 of 12107 Old 02-21-2011, 05:25 AM
richr8's Avatar
Originally Posted by bweissman View Post
I don't know what "only better of course" means,
IMO the buttons on the One feel like a higher quality tactily than on the 880, anf they are a bit bigger as well.
Rich
richr8 is offline
post #8200 of 12107 Old 02-21-2011, 07:12 AM
Olbi's Avatar
Give them a call. Some people had success replacing failed remotes after the warranty period. At least it doesn't hurt to give it a try.
Olbi is offline
post #8201 of 12107 Old 02-21-2011, 07:13 AM
Olbi's Avatar
I also got a refurbished from Tiger Direct in Canada for ~$135. They have them from time to time. CompUSA should ave them as well.
Olbi is offline
post #8202 of 12107 Old 02-21-2011, 02:02 PM
RockyMountainD's Avatar
Originally Posted by SDRANGER619 View Post
Does Logitec support fix broken screens on these remotes? or even sell it so i can repair?
Is it cracked? My first one got quite a few stuck pixels after a few months. It was still in warranty and they replaced for free.
RockyMountainD is offline
post #8203 of 12107 Old 02-21-2011, 05:51 PM
120inna55's Avatar
Quoted: 28 Post(s)
Do you hear the rattle? If not, as a last resort, strike the remote against the palm of your hand. It's possible it's just stuck.
120inna55 is offline
post #8204 of 12107 Old 02-23-2011, 10:52 PM
SDRANGER619's Avatar
Originally Posted by badgerpilot View Post
Best $75 you will ever spend! After you get it, go to Randy's website and download his icons and then give him a small donation for his excellent work. His icons really make a huge difference!
Been looking through the site, but I'm not sure how are the icons used? The channel you are on will show wth the custom icon?
huh?
SDRANGER619 is offline
post #8205 of 12107 Old 02-23-2011, 10:53 PM
the actual plastic screen isn't cracked, just the lcd stuff inside is partially all black.
I should call, I got the remote back in 2008 or so. THink I have a chance?
huh?
post #8206 of 12107 Old 02-23-2011, 11:06 PM
bernie33's Avatar
One of the features of the remote is "favorite channels". You can assign soft buttons for your favorite channels and tell the Harmony the number for each of those channels. You can tell it what text to display for each of those channels, but much better is to have it display the icon for each favorite channel.
We have no idea what the numbers are for our channels. We just push the soft button that displays the logo for the stations on both our One and our 880.
bernie33 is offline
post #8207 of 12107 Old 02-24-2011, 06:12 PM
Olbi's Avatar
I would say that you should give it a try. Worst case scenario is that they won't replace it, and you'll be in the same situation as you are in right now.
Olbi is offline
post #8208 of 12107 Old 02-25-2011, 03:29 PM
Same thing happened to 2 of the 3 I've owned; and the one it hasn't happened to is only 1 month old
As Olbi said, it can't hurt to try.
post #8209 of 12107 Old 02-26-2011, 11:57 AM
dskvid's Avatar
Hello from a ....so far, Happy new owner on an H1 replacing a Pronto tsu1000. I had just bought an URC R50 but it wasn't as nice as I thought it would be setting up and then I started to think that there was no way to back all the stuff I wanted to do with it, lots of work to redo if something happen. The Harmony is on sale at Best Buy so the R50 going back. I had no troubles setting my equipment and just started adding Icons for channels but here is my question.
On my Pronto I had set up an "Intermission Button" when I was watching movies. The marco would do this:
1. Pause the DVD
2. Switch AV Receiver and TV to DTV
3. Select a Jazz music channel on DTV
4. Lower the volume of the AV receiver to a background music level.
Then I had another button that reversed this sequence back to the DVD to pick up where I was with the same volume.
I don't think I can do this with this remote but thought I ask to be safe. Thanks.
dskvid is offline
post #8210 of 12107 Old 02-26-2011, 03:00 PM
mdavej's Avatar
Liked: 940
Yes you can. There are a couple of ways. Since you're switching sources, an intermission activity would be best. The pause will have to be an additional command at the end of your Watch DVD activity. Then put the rest in your new activity. Put the channel change and volume commands at the start of that activity. At the end of that activity, raise the volume back to normal.
You could also do it with sequences. I'm guessing this is around 10-15 steps, which can be accomplished with 5 raw learns of 3 commands each. You need one sequence to start intermission and another to go back.
post #8211 of 12107 Old 02-27-2011, 10:47 AM
dskvid's Avatar
Thanks MDavej for the response. I'll give it a try.
dskvid is offline
post #8212 of 12107 Old 03-03-2011, 10:31 AM
Seawater's Avatar
I have a new Yamaha RX-867 receiver. It has 6 HDMI in puts/2 HDMI outputs. When I go to set up an activity to watch movies, the Harmony One software doesn't not show the option for 2 HDMI ouputs. I need to use my Panny BD player on output 2. Any suggestions? This is Logitech's fault...
Seawater is offline
post #8213 of 12107 Old 03-03-2011, 10:50 AM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
I just looked at the Harmony database for your receiver (RX-V867?) and the HdmiOut command is definitely in there. You just need to add it to your activity startup and shutdown command strings and/or assign it to a button for manual control when needed.
That said, that command is a toggle command rather than discrete HDMI 1/HDMI2 commands, but it still should work. If you can determine that your receiver does support discrete HDMI output commands and also what the codes actually are, you can add or have them added to your account. Using them will make for more reliable operation (less likely to get out of sequence).
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #8214 of 12107 Old 03-03-2011, 01:01 PM
Seawater's Avatar
I am trying to do what you are saying and I still can not get it to work. I can not find the HDMI's out on it.
Seawater is offline
post #8215 of 12107 Old 03-03-2011, 01:05 PM
Seawater's Avatar
I did find in the customize buttons "HDMI Out" but there is no HDMI OUT1 or HDMI OUT2.
Seawater is offline
post #8216 of 12107 Old 03-03-2011, 01:21 PM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
That's what I was referring to by not having discreet output commands. But the other command should work as well, flip-flopping between 1 and 2 each time its sent.
post #8217 of 12107 Old 03-03-2011, 01:42 PM
Olbi's Avatar
If you have the discrete buttons on your remote you can simply learn them with the Harmony One and then add them to your activity/activities.
Olbi is offline
post #8218 of 12107 Old 03-07-2011, 09:54 AM
spyglass13's Avatar
I have had my Harmony for a couple of weeks and love it. I've had as much fun setting it up and realizing all that it will do as actually using it. Even the wife seems pretty comfortable with it. I have spent a lot of time reading this thread just to pick up any tips/tricks and it has been quite usefull. Here is my question (and yes I know this is discussed but I wanted to get specific) I am fairly saitified with delays and speeds involved with activities but when I press a favorites channel it seems to be awfully slow in putting in the channel numbers thus causing it to switch channels. Sometimes is will not put the correct number in, example: should be 2012 and will put in 201. Do I want to speed this up with adjusting delays or repeats. This part confuses me. Would someone hold my hand here and tell me exactly how fix/speed up that process. Thanks again. You people are a wealth of info on here...One more thing. I came across a discussion in here that said you could actually assign colors to the "A" "B" "C" buttons but darned if I can find that thread again. Is this possible?
spyglass13 is offline
post #8219 of 12107 Old 03-07-2011, 01:42 PM
BPlayer's Avatar
In the software, select Devices, and Troubleshoot under the device that is slow in responding. Then
- click on "name of device" responds to some commands either too many...
- lower the value by one, save the changes and test if that resolves the problem.
You can change the theme of the display, and this might alter how the buttons are displayed, but you cannot change the individual colors of the icons. To change the theme, select the Remote Settings tab, and Select a Theme. There should be three themes to choose from. I prefer Tron.
BPlayer is offline
post #8220 of 12107 Old 03-07-2011, 02:22 PM
spyglass13's Avatar
You guys are great. I will mess with the settings when I get home this evening. I have gotten pretty deep into the software settings and have been amazed at the control you can program. I just wanted a little backup or I should say guidance, before I started changing these settings.
Reply Remote Control Area
Harmony 880 Advanced Universal Remote , Logitech
