Official Logitech Harmony One thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
post #901 of 12107 Old 02-25-2008, 08:47 AM
RadYOacTve's Avatar
Quoted: 40 Post(s)
I didn't see this already posted but here is a nice review from CNET:
http://reviews.cnet.com/remote-contr...?tag=cnetfd.mt
RadYOacTve is offline
post #902 of 12107 Old 02-25-2008, 09:00 AM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
Thanks! Updated message #1.
Joe in West Los Angeles, CA
joe221 is offline
post #903 of 12107 Old 02-25-2008, 04:54 PM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
Randy,
Is it just me, or do I see a bunch of new icons in the group? I see there are now 15 pages, even if most of the pages say 14. Nice work!
joe221 is offline
post #904 of 12107 Old 02-25-2008, 05:08 PM
czzer's Avatar
Originally Posted by burnsy1 View Post
This is turning out to be a big pain. Im up to 18 commands now trying to get this to work. THe logitech software leaves a lot to be desired when putting together a lengthy activity. I've had to insert a couple delays to allow time for the 360 to boot up before its ready to respond to a command...and now it looks like I'll have to add a delay between each command on the 360. Each time I add a delay I have to click the stupid order up button to move it up to where it needs to be.... I wish they had an advanced ui where you could copy and paste in delay commands.... or even some sort of text editor....
You don't need to insert delays manually.
For the 360's boot up delay, increase the "Power On Delay" for the 360 device.
For the delay between commands, increase the "Inter Key Delay" for the 360 device.
czzer is offline
post #905 of 12107 Old 02-25-2008, 05:16 PM
SaltiDawg's Avatar
Exactly!
SaltiDawg is offline
post #906 of 12107 Old 02-25-2008, 05:23 PM
squareeyes's Avatar
Originally Posted by SaltiDawg View Post
Exactly!
czzer,
That's a logical and elegant solution. I'm going to have to try that out.
,R
follow icon updates, av & remote info on facebook and twitter.
http://www.iconharmony.com
squareeyes is offline
post #907 of 12107 Old 02-25-2008, 05:58 PM
burnsy1's Avatar
Quoted: 20 Post(s)
Yeah, I actually did figure that out about halfway through my programming last night. I got to a point where the xbox guide would come up...chose dashboard...but then on the following window where you have to "ok" to exiting whatever your doing..it stopped.
I tried fiddling with it some more ..messing with different delays, but its gotten to the point where the remote lockups completely when I attempt that activity ....back to the drawing board
Marantz 8802A / Anthem Pre2L / Anthem CD1 / Outlaw Audio 7200 / Rotel 976 / Rotel 971 / B&W 604S3 /
burnsy1 is offline
post #908 of 12107 Old 02-26-2008, 11:26 AM
thptrek's Avatar
Has anyone developed an activity or button to be able to change a Panasonic plasma's picture mode. I have been trying to find a solution such that one push and the plasma goes to Cinema mode, then another button for Standard, Custom, etc.
thptrek is offline
post #909 of 12107 Old 02-26-2008, 11:28 AM
YMark's Avatar
You would have to program a "sequence" (one for each picture mode) and then assign this sequence to a button(s).
Mark
YMark is offline
post #910 of 12107 Old 02-26-2008, 11:30 AM
yngdiego's Avatar
Quoted: 37 Post(s)
I think he's asking for discreet codes to set the picture mode, not a sequence that would manually arrow through the TV menus to change the picture modes.
yngdiego is offline
post #911 of 12107 Old 02-26-2008, 01:09 PM
RadYOacTve's Avatar
Quoted: 40 Post(s)
Can the ONE do "sequences?" I read in the 1000 thread that you can program a 5 command sequence" (or macro).
post #912 of 12107 Old 02-26-2008, 01:27 PM
tripleM's Avatar
Do u mean configuring a specific contrast / brightness / gamma to a picture mode?
you are better than me! I find my viewing is too temperamental to keep the same all the time
Panasonic TC-P60ST60 + Sony STR-DG810 + LG BH200 + JBL L830's x2 + JBL LC1 + JBL Loft40 x 2 + Polk PSW10 + Harmony One
tripleM is offline
post #913 of 12107 Old 02-26-2008, 03:48 PM
NathanC's Avatar
Unless you're willing to program in a macro that follows exactly what you would have to hit to do it by hand, then no. This is no fault of the Harmony, just a lack of discrete commands on devices.
NathanC is offline
post #914 of 12107 Old 02-26-2008, 05:20 PM
squareeyes's Avatar
The One can do sequences. Check in the button areas in activities.
,R
post #915 of 12107 Old 02-26-2008, 05:58 PM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
Go through the device listing of commands, both on the remote and on the loftware list. See what they can do and if you can get creative.
Good luck.
joe221 is offline
post #916 of 12107 Old 02-26-2008, 06:08 PM
girdnerg's Avatar
You can also learn sequences using learn a command, in "RAW" mode.
I needed a sequence to toggle the closed captions on my Dish Network receiver. Unfortunately, it takes 9 button presses to navigate thru the menu to do this. Since the software limits you to 5 commands in a sequence, this meant I had to use 2 buttons just to turn the CC on.
After a search of the forums, I found my solution; using the RAW mode. In this mode, the remote learns the command just how you press it. So if you hold one button for a long time, it learns that. If you push several buttons quickly, it learns all of those.
I created a new command called CC1 and it RAW mode, taught it the sequence of MENU>8>8>1>LeftArrow. The next one was CC2 and was the commands SELECT>RighArrow>SELECT>ViewLiveTV.
Now I had the 9 commands learned into 2 buttons. Then I created a sequence and used the 2 commands CC1 and CC2 to create a button I named CC Toggle.
It took a few tries to get it right, but now I can toggle the Closed Captions with one button press!
My max sequence learned in RAW mode seems to be limited to 5 button presses, but I've read where others have gotten it to learn more at once.
Complicated? Yes! but elegant when you get it to work.
girdnerg is offline
post #917 of 12107 Old 02-26-2008, 06:46 PM
RadYOacTve's Avatar
Quoted: 40 Post(s)
Thanks Randy..never noticed it!
I've read some people use it when they press play it will dim the lights automatically.
Anyone have any clever ideas to put this feature to good use?
,R
post #918 of 12107 Old 02-26-2008, 10:00 PM
JimInPT's Avatar
Quoted: 14 Post(s)
I just shoot out the lights with a .22 - it usually wakes up the dog, but I don't have to get off the couch.
I'm shocked AND odd.
JimInPT is offline
post #919 of 12107 Old 02-26-2008, 10:08 PM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
Silencer, maybe?
joe221 is offline
post #920 of 12107 Old 02-26-2008, 10:30 PM
JimInPT's Avatar
Quoted: 14 Post(s)
Originally Posted by joe221 View Post
Silencer, maybe?
D'oh! An obvious solution. Nice to see somebody out there's thinkin'.
I think I've even got one here under the middle cushion . . . . . . yep. Dog's gonna be a lot happier.
JimInPT is offline
post #921 of 12107 Old 02-26-2008, 11:46 PM
marmel's Avatar
Could someone have a look at the charger and tell me what the voltage range is. I am looking at getting one of ebay but want to make sure the US voltage isn't going to be a problem. Thanks.
marmel is offline
post #922 of 12107 Old 02-27-2008, 01:08 AM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
Hope this helps, not really a voltage guy...
Input and output are 5V 800ma
joe221 is offline
post #923 of 12107 Old 02-27-2008, 01:53 AM
marmel's Avatar
I probably need someone to have a lok at the plug that goes into the wall socket and see if there is a voltage range listed. Hopefully it will be similar to cellphone chargers and be widely compatible.
marmel is offline
post #924 of 12107 Old 02-27-2008, 02:42 AM
marmel's Avatar
Thanks for that but I probably need the voltage range listed on the plug that goes into the wall socket.
US voltage is 110, here it is 240. Pretty much all laptop/cellphone chargers are universal and will work so hopefully this will to.
So if anyone can pull their plug and have a look I'd appreciate it.
marmel is offline
post #925 of 12107 Old 02-27-2008, 04:27 AM
tvmack's Avatar
Could someone who currently owns the ONE give me some feedback on the one press/play modes for DVD, TV, Radio (turning several devices on at once). How is this working for you?
My previous IR remotes would only turn on a couple items always leaving something not turned on/off. Is this happening a lot with the ONE? Is the IR signal strong enough to do the job turning on/off three or more devices at once even if its not directly pointing at them?
Feedback appreciated.
tvmack is offline
post #926 of 12107 Old 02-27-2008, 07:11 AM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
I've had it several weeks now and it has been quite accurate. All my devices are straight ahead of me, unobstructed. I have tried the, point it behind me and push, and it works that way too. I do know some here have had trouble, it's a single bad one issue, usually the replacement fixes the problem. It is new, expect it may have a problem and get it replaced if it does.So far so good.
joe221 is offline
post #927 of 12107 Old 02-27-2008, 07:18 AM
Lee L's Avatar
Liked: 42
I have also had no issues. Of course, you will need to go through some initial tweaking to get the dealys and sequencing right, but after one run through and following the Remote Assitant built in help, it has been great, even a little off axis.
XBOX Live: SheriffTruman
Lee L is offline
post #928 of 12107 Old 02-27-2008, 07:26 AM
yngdiego's Avatar
Quoted: 37 Post(s)
100-240v, 50/60Hz.
yngdiego is offline
post #929 of 12107 Old 02-27-2008, 10:46 AM
thptrek's Avatar
Thanks girdnerg for the info. I was hoping for a discrete code to change the picture mode but there the Panny does not have them. I will use your method. I'll just have to plan out the steps to make the change.
thptrek is offline
post #930 of 12107 Old 02-27-2008, 11:59 AM
Abulia's Avatar
Just picked this up on Monday and am falling in love. Still have to program -- and have a new A/V Receiver arriving tomorrow -- but it's very powerful and useful remote.
While looking for new button icons I was not surprised at all to find a link to the always-knowledgeable AVS forums for an excellent Harmony One thread. Time to start reading this thread from top to bottom!
Abulia is offline
Reply Remote Control Area
Harmony 880 Advanced Universal Remote , Logitech
