Official Logitech Harmony One thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
Old 03-01-2008, 07:19 AM
moonhawk's Avatar
Quoted: 84 Post(s)
Liked: 41
Originally Posted by madpony View Post
Man, I am still having a bitch of a time, almost two weeks later, getting the remote to power my tv on during the "watch tv" activity sequence.
The three devices I use in this chain are : TV (Sony 60A3000 SXRD), Receiver (Onkyo SR605), and DVR (DirecTV HR20). I have tried switching the order in which the devices are powered on to no avail. I have also played around with the inter-device delay settings for the tv. I was able to get it where it worked once, but the next day when I hit the activity button, the tv didn't power on.
I am about at a loss here. Other than this one issue, I am head over heels in love with this remote so far. Does anyone have any ideas? Maybe someone has the same equipment and can tell me what is the best order to have the devices in for powering on, or the best inter-device setting.
Call their support number...those folks are good!
______________________
__________
Dave
moonhawk is offline
Old 03-01-2008, 08:05 AM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
Ditto! You may have a bad unit. Did you try returning it to the store or is it a web purchase? Your devices are common and normal, it should just plain work.
Joe in West Los Angeles, CA
joe221 is offline
Old 03-01-2008, 03:21 PM
ducky124's Avatar
I have same tv but a Pioneer AVR and SA8300 box. But maybe my order can help. First turned on is cable box next is TV then finally AVR
Hope this helps
ducky124 is offline
Old 03-01-2008, 03:25 PM
OhioLefty's Avatar
I did a search and came up with some tips I have already tried.
Here is my problem, I'm switching from a Harmony 676 to a new Harmony One and I can't get a couple of commands to work. The first one is the "Skip Forward" or sometimes referred to as the "30 second commercial skip". I had it working perfectly on my 676 but can't get it to work on the One. I "learned" the command from both my 676 and Comcast remote (originally programmed using the Wiki code) and trying to program it on the One using the "Skip" button under the >>| button. What could I be doing wrong? I'm pretty familiar with using the Harmony software programming my 676 to do whatever I need for almost two (2) years.
The second question is (and I never got this to work with the 676 either) that I have a Sharp LS-52D64U and I can never get either remote to switch to the TV Tuner when I want. The only thing that works is to manually find and press NextInput until it switches to the "TV" input.
Can you guys give me some suggestions? I know I can call Logitech Tech Support but I've been spoiled from all the good help from my friends here at AVS in the other threads I frequent.
For what it's worth, here are my devices, and the 676 still controls everything perfectly and I did set up a seperate account for the H1.
Sharp LC-52D64U
Comcast Motorola DCH-3416
Toshiba HD-XA2
Panasonic DMP-BD30
Onkyo TX-SR705
edit: Just tried to call Support and they closed at 5:30p EST, missed them by 10 minutes!
Thanks in advance...
OhioLefty is offline
Old 03-01-2008, 04:28 PM
Mikeb33's Avatar
I have emailed them for support before and they adjusted my settings online and had me upload the remote and it worked!
Mikeb33 is offline
Old 03-01-2008, 04:40 PM
RadYOacTve's Avatar
Quoted: 40 Post(s)
There are a few people on here that have been having problems learning codes, including me. When I called tech support they told me they are aware of interference issues when trying to learn a code. They asked if I was using a laptop, how far from the tv, components, kitchen appliances, etc then asked me to unplug my laptop and try learning the code and have the remote as far as the USB cord will allow and this method has worked everytime.
Squareeyes had the same problem and this resolved it as well.
Good luck, let us know you end up solving the problem.
Sharp LC-52D64U
Toshiba HD-XA2
Panasonic DMP-BD30
Onkyo TX-SR705
RadYOacTve is offline
Old 03-01-2008, 05:27 PM
OhioLefty's Avatar
I swear, you guys are a godsend! I spent about two hours trying to figure this out and never would have dreamed it was the laptop! I went upstairs to a desktop and now it works perfect! I've been using the laptop to program my 676 for over a year now and never would have guessed.
Thanks again RadYOacTve! Thanks for taking a few minutes to end my frustration. I can't begin to tell you how great this forum has been over the past couple of years.
I guess I should have tried to read every post but it's hard when you just want to get something figured out. I will go back and start reading now that I am in more of a relaxed state.
Hopefully I'll be able to give back some helpful info when another member is frustrated and lost.
Thank you again!
Old 03-01-2008, 05:57 PM
RadYOacTve's Avatar
Quoted: 40 Post(s)
Hey Ohio,
Glad it worked! You can still use your laptop, just unplug the power cord from the laptop.
I agree, this message board and this thread in particular has been really helpful. Especially with a lot of new Harmony users getting help from previous Harmony users that are all new to the ONE.
Thank you again!
Old 03-01-2008, 06:13 PM
squareeyes's Avatar
Okay you guys, maybe you can get me to a happy ending on this one...
Backstory:
I'm able to view the menu of discs in my CD jukebox on my TV through my receiver. It allows me to quickly input text info and also to see a screen's worth of about 10 discs as I scroll up and down the menu.
I'd like to create a sequence in my 'Listen to CD' activity mapped to the remote's hard 'Menu' button that will essentially:
>Turn on my TV
>Switch it to the correct input
>Send the Text Menu command from my reciever's command set
Here's where I'm hitting a snag:
I'm able to add the TV as a device to this activity after setting up the activity I hit the "yes, but I want to add more control...".
After I add the TV, it shows up w/in the activity and the remote sends it a command to go on in the main activity when I switch to 'Listen to CD'. I don't want it to go on w/in the activity, I only want the option to turn it on and off when I want while I'm in that activity.
Short of faking out the remote software by using IR learning to teach a new command to my reciever or disc jukebox that is actually my TV on/off toggle, do you know a way to get the TV On command out of the main activity and just have it available so I can map buttons/sequences with it's IR commands?
Help!
,R
follow icon updates, av & remote info on facebook and twitter.
http://www.iconharmony.com
squareeyes is offline
Old 03-01-2008, 06:31 PM
badgerpilot's Avatar
Quoted: 73 Post(s)
Liked: 43
Just a reminder, if you like the icons from squareeyes, the link to donate is here:
http://www.iconharmony.com/about.html
The icons are awesome! Thanks.
badgerpilot is offline
Old 03-01-2008, 06:46 PM
OhioLefty's Avatar
I know it's probably in here somewhere but how do you add icons to the H1? If you can point me to directions, I would really appreciate it.
Thanks again...
Old 03-01-2008, 06:48 PM
OhioLefty's Avatar
Hey Ohio,
The power cord is the culprit? Thanks again, that makes it easier than running back and forth upstairs. Sitting with the laptop on my lap in front of the Home Theater makes it a lot better.
Old 03-01-2008, 06:56 PM
squareeyes's Avatar
Thanks again...
Ohio,
>Go to your 'Watch TV' activity settings
>Select 'Setup favorite channels' click 'Next'
>Select a slot to which you want to add a graphic and channel number click "Select Image...'
>Grab any of Harmony icons from their bank or click 'Browse...' to search your local drive for the icons you have downloaded.
That should do it.
,R
Old 03-01-2008, 07:01 PM
Quoted: 73 Post(s)
Liked: 43
Thanks again...
First, download Squareeys' icons to a file. Then, under activities, click on "settings", and you will see a page with the option to "Set up favorite channels." You will then be able to enter channel numbers and browse to the file that you downloaded the icons to and select an image.
Old 03-01-2008, 07:15 PM
OhioLefty's Avatar
Originally Posted by squareeyes View Post
Ohio,
That should do it.
,R
Thanks guys, I really appreciate it!
Old 03-01-2008, 07:19 PM
RadYOacTve's Avatar
Quoted: 40 Post(s)
I'd like to know this as well.
I've added my zone 2 of my receiver and my lutron lights into the "watch family room tv" activity so I have access to each device on the button pages of the activity. When I review the settings for this activity it shows that it both devices are turning on but a call to tech support said that on their simulator neither are turning on and my tests prove that. I was not told if there was a specific way to add a device to an activity without making the remote want to turn it on or off.
Backstory:
>Turn on my TV
Help!
,R
Old 03-01-2008, 07:33 PM
squareeyes's Avatar
Thanks. It definitely turns on my TV when I go to listen to my CD. I'm updating remote with the "fake out" learned IR method right now.
Will keep my fingers crossed.
,R
Old 03-02-2008, 06:22 AM
JackBauer24ctu's Avatar
Hello,
I am having trouble getting the inputs on the Sharp Aquos LC32GD9E
working correctly. I have programmed an action on the HO (Harmony One) for watching TV.
I have defined the Inputs as followed: TV, DTV, EXT1, EXT2, EXT3, EXT4, EXT5 and EXT6.
When I now start the action the wrong input channel is used. For "TV" for example "EXT3" is used.
In addition I have a TVIX 6500A HD-Player connected on EXT6 via HDMI cable. When I choose my programmed "HD Playback" Option EXT5 is used. But I have configured it to Ext6. Whats wrong here? I think the input sources
are totally mixed up? What must I Do to correct this? I already moved the Inputs in the Config App in order up and down or renamed the Inputs (Input5->Input6). But this did not solve my problem.
I would appreciate any comment on this matter.
Thomas
PS: How could I delete a command in the Config App which was learned by the HO before? I never see a button to delete a programmed key? Is it possible?
JackBauer24ctu is offline
Old 03-02-2008, 06:51 AM
speedoflight's Avatar
Help!
,R
You could just use the device menu to choose the TV after the activity is active to turn the TV on and/or off then go back to the activity. I do this often when I want to change the surround mode on the pre-amp or change the screen aspect on the TV.
speedoflight is online now
Old 03-02-2008, 06:55 AM
Originally Posted by JackBauer24ctu View Post
Hello,
Thomas
You can add commands to an activity to set the TV to the input you want. I don't remember the exact spot in the software but I've done this on mine. It's probably under I want to add more control menu option.
Old 03-02-2008, 07:13 AM
squareeyes's Avatar
Hello,
Thomas
From your post it sounds like you have discrete commands for all your inputs but that they are incorrect in the Harmony DB. This is a similar problem I experienced with a few of my devices. I had to manually relearn the IR signals from the original remotes and I let Harmony support know they were wrong in their DB. I don't know if they corrected them or not, but at least everything now works correctly.
,R
Old 03-02-2008, 07:25 AM
squareeyes's Avatar
That's what I used to do. I became tired of navigating around the remote UI and added many of the different speaker volume commands and TV screen commands to the activities in which I use them. For instance, I can now control the center and sub surround speakers right from my 'Watch TV' activity's screen. It's more convenient that way.
For the CD menu I thought I'd take advantage of the 'sequences' feature and try to make it a seamless command. It looks like it's working with the faking out method and I just need to get the delay for the TV on/off down.
Old 03-02-2008, 07:33 AM
squareeyes's Avatar
Eric,
I got it to work with the fake out method. It worked better when I used the 'Raw' learning mode and held the TV power button on the original remote down a little longer. That seems to have worked as a delay from w/in the sequence.
Of course, this method only helps someone if they have the original remote. At least my TV stays off now when I go to listen to a CD.
,R
Old 03-02-2008, 09:16 AM
,R
I have emailed tech-support. So let's see with which solution they come up with.
Old 03-02-2008, 09:51 AM
Do you have these special commands mapped to the touch screen or hard buttons?
Old 03-02-2008, 10:21 AM
squareeyes's Avatar
Touch screen, and usually side-by-side for volume function. So that left side is 'Volume Sub +" and right side is 'Volume Sub -'.
Although I just mapped that CD Jukebox onscreen menu sequence to the 'Menu' hard button on the remote.
Old 03-02-2008, 10:22 AM - Thread Starter
joe221's Avatar
Quoted: 29 Post(s)
Hello,
Thomas
While waiting for your reply, try this . On the remote go into your TV device. On the LCD you'll see all the commands displayed on pages in the LCD. Verify what each one does. You may find errors and misslabeling but they're all there. I did on my Mits TV and adjusted acordingly. You also may be surprised at what you find on the good side too. Often the discretes can do a lot more than the original remote and it's not labeled well. Sometimes not... As for deleting learned commands, I don't know, if you find out please post!
joe221 is offline
Old 03-02-2008, 11:08 AM
veevsato's Avatar
Just upgraded from the 688 to the One. The upgrade function of the harmony app worked fine. Just one question. I noticed when I switch to my tivo hd activity the screen has these nice thumbs up and down icons, but everything else is just a box with text. Anybody know how to replace the text boxes with icons. For example, I would love to be able to replace the word tivo with the little tivo guy as an icon....
Thanks in advance.
veevsato is offline
Old 03-02-2008, 11:42 AM
GR1MM's Avatar
I have just bought my Harmony One today.I want to use it on my PS3,but I have to buy a PS3 remote with an adapter to plug into the USB to accept the signal.Does any PS3 IR remote work?Which is the Best???
XBOX: xxx GR1MM xxx
PS3: GR1MM
GR1MM is offline
Old 03-02-2008, 12:49 PM
SaltiDawg's Avatar
You are actually looking for a solution that includes an IR dongle to plug into one of your PS3's USB ports. There are a couple of devices by Intec and Nyko.
I use a device found here: http://www.schmartz.com/main.sc
You may want to do some reading here to compare various options: http://www.avsforum.com/avs-vb/showthread.php?t=946674
If being able to remotely power the PS3 On and Off by IR commands, be sure to do your homework before choosing which to buy.
SaltiDawg is offline
Harmony 880 Advanced Universal Remote , Logitech
