Official Logitech Harmony One thread - Page 378 - AVS Forum | Home Theater Discussions And Reviews
 99Likes
post #11311 of 12065 Old 07-16-2014, 04:40 PM
pbarach's Avatar
Quoted: 294 Post(s)
Liked: 185
Originally Posted by mdavej View Post
Set up a new activity "Manually" and you can do whatever you want. Don't start with the canned "Listen to..." or "Watch..." ones that are tied to specific types of devices. Then add commands to the start or end to navigate to the appropriate app on the Oppo automatically. Then add some sequences to streamline other nav functions.
When adding the Oppo unit to the Logitech sofrware, chose Oppo BDP-93 instead of the 103, since Logitech classifies the Oppo 103 as a music system and omits commands for most of the buttons on the remote (the two players use the same remote). For any buttons on the Oppo remote that you don't find in the Logitech software, you can easily teach that button's code to the H1.
AT&T U-Verse Northeast Ohio
Denon x4000, Carver m1.0t, Samsung LED TV, B&W 704 mains, two M&K subwoofers, Oppo 103, Roku 2, etc.
Headphone system: Sennheiser HD600, AKG K701, Burson HA-160, Marantz CD5004, Denon DVD-3910
pbarach is offline
post #11312 of 12065 Old 07-17-2014, 05:42 PM
jojoxl's Avatar
How do I change the order that devices are sent commands in an Activity? I need to have my HDBaseT switch to be the first device, but I can't find out how to change that.
jojoxl is offline
post #11313 of 12065 Old 07-18-2014, 09:31 AM
BPlayer's Avatar
Only the software, not web function, allows the order to be changed. From the software select the Activity, Setting, and Review the order in which devices are turned on.
BPlayer is offline
post #11314 of 12065 Old 07-18-2014, 12:13 PM
HarmonySylvain's Avatar
Quoted: 105 Post(s)
Liked: 50
This is also possible in MyHarmony (the 'web function') - sign in to your account, select your Activity and click 'Customize this Activity'. There is a separate section for powering on, and for powering off.
Sylvain
HarmonySylvain is offline
post #11315 of 12065 Old 07-25-2014, 07:44 AM
craig72's Avatar
Quoted: 38 Post(s)
Liked: 39
Sorry if this has been covered before, but I could not find anything in this thread or the Grafik Eye thread regarding this.
I have a Lutron Grafik Eye 3506 and a Harmony One (NOT Ultimate). I have set up 'Lighting Controller' as a device and it works just fine for selecting a scene, turning all lights off or on, and dimming all lights. What I have not been able to figure out is how to control just ONE particular zone. For example, my LED cove lights are on Zone 2. I would like to be able to dim those independently if the mood strikes me. Any suggestions? Thanks!
Craig
ejhuzy likes this.
craig72 is offline
post #11316 of 12065 Old 07-25-2014, 12:29 PM
antennahead's Avatar
Quoted: 244 Post(s)
Liked: 165
A quick kudos to Sylvain for having the Harmony techs look at my devices and make some adjustments that corrected an issue I, and other Anthem AVM 20 owners were having. We were unable to adjust the existing repeats to allow the pre/pro to change the volume in .5 db increments. The closest I could get prior to the changes was 1.0 db. After the changes I am happy to report I can now change volume in half db increments again. Thanks to Sylvain and Harmony!!!
John
antennahead is offline
post #11317 of 12065 Old 07-25-2014, 07:11 PM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
I have the harmony one. I recently moved my equipment rack from the front of the room to the back. What's the best way to handle no line of sight with this bad boy?
I see you can buy the harmony hub to add to it. If I do that does the One communicate with the Hub via RF or wi-fi (like smartphones). If it's wi-fi, this isn't an option for me as my media room is a wi-fi dead zone.
Are there any cheaper alternatives than adding the hub? Not sure 100 bucks is worth not having to reach behind my head.
Thanks in advance guys.
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::110" Silver Ticket
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI:::Darbee DVP 5000
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is offline
post #11318 of 12065 Old 07-25-2014, 07:42 PM
mdavej's Avatar
Quoted: 2087 Post(s)
Liked: 930
The hub works with the "Ultimate One", not with the "One", so that isn't an option. The One has no RF or wi-fi capabilities whatsoever. Just put a repeater in the front of the room. Many make them, including Logitech. Generic one from eBay is much cheaper though.
mdavej is online now
post #11319 of 12065 Old 07-25-2014, 07:58 PM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
i'm an idiot, I have the harmony touch. so it does upgrade with the hub. I guess asked my question in the wrong thread.
Denon 4520CI
Emotiva LPA-1
wadec22 is offline
post #11320 of 12065 Old 08-04-2014, 12:41 PM
DenisG's Avatar
Quoted: 65 Post(s)
Liked: 32
I recently changed BD players and updated the remote. Now it stopped turning off my projector. Not sure what happened. Everything looks to be fine on the desk top software.
DenisG is offline
post #11321 of 12065 Old 08-04-2014, 01:06 PM
b_scott's Avatar
Quoted: 37 Post(s)
I hate the setup of the new Harmony remotes. My One is showing its age though. It's 6 years old, and the rubber has rubbed off of the bottom in spots, while the motion sensor doesn't really work and there are hairs stuck under the screen. The buttons don't always work on first press either.
I'd like to get a new one, but I don't want to pay $300 for it. :sigh:
b_scott is offline
post #11322 of 12065 Old 08-04-2014, 02:18 PM
jcalabria's Avatar
Quoted: 126 Post(s)
Liked: 98
FYI... Meritline has refurbed 650s for $42 today... if you replace an existing remote currently on 7.7 software, you can still use the 7.7 software on the 650 and the lower device limit (five devices normally on the 650 using 7.7 software) doesn't apply. Keypad layout is similar to One but the screen area has 4 hard buttons instead of 6 touch buttons. In return you get dedicated color buttons.
http://www.meritline.com/logitech-ha...1&dealid=78305
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
post #11323 of 12065 Old 08-04-2014, 02:21 PM
b_scott's Avatar
Quoted: 37 Post(s)
oh interesting. Thank you for the information, I'll think on it.
b_scott is offline
post #11324 of 12065 Old 08-11-2014, 09:35 AM
theSteam's Avatar
I saw refurbished One's on Amazon ~$200.00 I have not bought one.
theSteam is online now
post #11325 of 12065 Old 08-11-2014, 06:15 PM
rightintel's Avatar
Quoted: 514 Post(s)
Liked: 179
Awfully high for a refurb...
joe221 likes this.
Xbox Live: General PATT0N
rightintel is offline
post #11326 of 12065 Old 08-12-2014, 07:00 AM
jcalabria's Avatar
Quoted: 126 Post(s)
Liked: 98
Agree, but prices have been creeping up as they get more and more scarce. Within about the past year I have bought two refurbed Ones from Meritline... the first was under $100, the second was ~$129. Currently Meritline lists them at $179, but they show no stock. As much as I like the One, I'd really have to think hard about purchasing a refurb at the current prices I see.
post #11327 of 12065 Old 08-12-2014, 07:12 AM
pappaduke's Avatar
Quoted: 126 Post(s)
Liked: 113
If Logitech reads this thread, they should clearly see that an updated one would bring in a lot of money for them.
joe221 and boe like this.
pappaduke is online now
post #11328 of 12065 Old 08-12-2014, 08:36 AM
NickTheGreat's Avatar
Quoted: 376 Post(s)
Liked: 251
But what if they read the Ultimate thread, and decide THAT brings them lots of money
NickTheGreat is offline
post #11329 of 12065 Old 08-12-2014, 08:38 AM
jcalabria's Avatar
Quoted: 126 Post(s)
Liked: 98
Agree... but my guess is that they believe they have done that with the Ultimate One, even though the majority of us here hold a preference for the original One, for some very good/valid reasons IMO. In some respects, the Ultimate One IS an upgrade, and it's not a horrible remote by any reasonable measure. However, it's ridiculous ergonomics (location of transport controls and loss of hard numeric keys) make it difficult for me to consider it as a true upgrade to the original One.
Regardless, what we think probably matters little, if any, to them... if they've seen a bump in sales versus what they were most recently getting from the One, they likely will see the new remote as a success. It's sort of similar to smart phones with hard-button keyboards. People like my wife would rather go back to a basic phone than adapt to touch screen typing, but the choices of slider smartphones with real keys are dwindling... and teetering towards none.
post #11330 of 12065 Old 08-12-2014, 03:20 PM
theSteam's Avatar
the original One fits my hand like no other remote I have ever used. I am tempted to buy a refurbished One just so I have a spare, if by the time mine dies, no one will DO a refurbish on it. Still thinking this over...
post #11331 of 12065 Old 08-12-2014, 07:31 PM
rightintel's Avatar
Quoted: 514 Post(s)
Liked: 179
If mine ever goes, that's the route I'll take. Hopefully some'll be left by then.
post #11332 of 12065 Old 08-13-2014, 07:26 AM
Tom Thomas's Avatar
I picked up a couple extra used ones from ebay at under $100 ea. I now rotate them every day to keep the batteries up and to hopefully get many more years of use from them.
theSteam likes this.
Tom Thomas is online now
post #11333 of 12065 Old 08-13-2014, 10:27 AM
theSteam's Avatar
Thanks for the thought...off to eBay!
post #11334 of 12065 Old 08-13-2014, 01:18 PM
pappaduke's Avatar
Quoted: 126 Post(s)
Liked: 113
The way the One fits in your hand and the hard buttons are what makes it such a wonderful remote. I will shed a tear the day mine dies. If I have to switch to something else at that point I'm sure I'll learn to love it, but the One is simply the best remote out there IMO.
post #11335 of 12065 Old 08-13-2014, 02:11 PM
jcalabria's Avatar
Quoted: 126 Post(s)
Liked: 98
FYI... If you haven't used either of them, the 650 and 700 are extremely similar to the One as far as how they feel in your hand. The button layout below the display is essentially identical to the One with the addition of the four color buttons. Even my EXTREMELY technophobic wife can move easily between our rooms with Ones and rooms with 650s. My only real complaint with the 650/700s (other than having only four soft keys in place of One's six soft keys) is the PITA workaround for ordering activities (assuming your on 7.7 software... AFAIK MyHarmony does not allow Activity reordering at all). If the 5 device limit (8 devices via MyHarmony... and no limit if "replacing" a One in 7.7 software) is not an issue for you, the 650/700 is a viable alternative to a One. 650 refurbs are typically available for ~$49.
I have three 650s and a 700... I prefer the 650s. They are essentially identical except for color and the 700's in-remote recharge capabilities. But without a charging cradle, I end up swapping the 700s batteries with rechargeable AAs I've charged outside of the remote, just like I do with the 650. The 700 is not worth the extra $$$ IMO.
post #11336 of 12065 Old 08-13-2014, 04:16 PM
120inna55's Avatar
Quoted: 28 Post(s)
I bought my One new 6 1/2 years ago, and it's gotten pretty heavy use daily since then. The "rubber" backing is not worn and the whole remote looks new when I polish it up every now and then. I'm using the original battery (yes, with the blue label it), and it's never swelled. I remove the battery when I clean the remote, so no issues noted there either. I still only have to charge it every 2 weeks. I only charge it when the icon turns orange. The only thing wrong with it is the motion sensor is essentially useless now. My wife and I simply changed our behavior and just swipe the screen to wake it. All in all, I think I got pretty lucky with such a durable One. It's my understanding they don't make 'em like they used to.
A couple years ago, I bought a refurb One as a spare, assuming one day my original one would crap out. I intended to just leave the spare in the box. One day, on a lark, I decided to get out the spare and discovered it had the black screen issue. I'd had it too long to get my money back, so I bought another refurb (~$100). I immediately checked it out when it arrived and it worked fine. I sync'd it with my software to mirror my current One. Since then, if I make any changes to my system, I update both remotes. (The software doesn't see the difference between the two remotes, so I keep the same profile.) So, expecting my original One to quit on me some day, I keep the spare in my media closet. I check it periodically to see how the battery is doing. Since it doesn't see any action, I only have to charge it about every 6 weeks or so. On a rare occasion, I'll actually use the spare (like in a case where the original is recharging).
If you're a big fan of this remote, I recommend you do just what I did. I'm still quite pleased with the 6 1/2 year old One, but I have peace of mind knowing there's a backup. I did notice the backup has a slightly lower resolution screen. The base doesn't have a light on it (but the base stays in a box). The rubberized backing on the refurb is different too.
120inna55 is offline
post #11337 of 12065 Old 08-13-2014, 07:22 PM
rightintel's Avatar
Quoted: 514 Post(s)
Liked: 179
I'm tempted to do just that, my motion detector's almost gone...
post #11338 of 12065 Old 08-14-2014, 05:36 AM
jcalabria's Avatar
Quoted: 126 Post(s)
Liked: 98
FYI... I know they've been mentioned here before, but Harmony Remote Repair can fix many of the routine problems. At the prices refurbs have hit, their services are getting more attractive. I haven't used them myself, so I can't vouch for them in any way.
post #11339 of 12065 Old 08-14-2014, 07:14 AM
pappaduke's Avatar
Quoted: 126 Post(s)
Liked: 113
Thanks for that info. I may try that if my One dies on me.
post #11340 of 12065 Old 08-14-2014, 08:15 AM
balpers's Avatar
Thank you for this. As these things age out this service is going to get more and more attractive.
Burt
The Consultant's Creed:
I can do it right.
I can do it cheap.
I can do it fast.
You get to choose any two.
balpers is offline
Reply Remote Control Area
Harmony 880 Advanced Universal Remote , Logitech
For the best viewing experience please update your browser to Google Chrome
