Official Logitech Harmony One thread - Page 380 - AVS Forum
 12Likes
post #11371 of 11387 Old 10-19-2014, 12:43 PM - Thread Starter
joe221's Avatar
Quoted: 23 Post(s)
Originally Posted by Sgooter View Post
Thanks guys - much appreciated.
I don't know yet if the OEM battery will come out or if it's swollen; will check on this soon. Just thought that after 7 yrs I should probably get a new battery for it. I have noticed that my H1 needs recharging sooner than it used to.
UPDATE: The OEM battery is very swollen in both of my H1s and they're not budging, so I have emailed Logitech support for a solution...keeping my fingers crossed.
They will probably offer you a Ultimate One. IMHO they are much better than the forum gives them credit for. Not perfect but I've been using the Ultimate for months now and am quite used to it. Yes I miss some things but I'm mostly over it.
I'd advise taking it if offered. They are also easily upgradable to Ultimate (RF) as the remote is the Ultimate just without the RF kit.
Joe in West Los Angeles, CA
joe221 is offline
post #11372 of 11387 Old 10-19-2014, 12:46 PM - Thread Starter
joe221's Avatar
Quoted: 23 Post(s)
Originally Posted by Feirstein View Post
I just replaced my One with a Touch. I'll report back if it is an adequate substitute.
Touch < Ultimate One. They basically fixed the errors they made in the Touch. Can you still return it? Yes it's that different.
joe221 is offline
post #11373 of 11387 Old 10-19-2014, 01:21 PM
pappaduke's Avatar
Quoted: 35 Post(s)
Liked: 51
Which Harmony model do they typically offer as a replacement for the H1?
I believe they're replacing it with a touch.
pappaduke is offline
post #11374 of 11387 Old 10-19-2014, 01:44 PM - Thread Starter
joe221's Avatar
Quoted: 23 Post(s)
The last reported replacement was an Ultimate One. The Touch is discontinued.
joe221 is offline
post #11375 of 11387 Old 10-19-2014, 03:04 PM
Sgooter's Avatar
Does Logitech require the problematic H1 be shipped back to them as part of the exchange?
When in doubt, do the right thing.
Sgooter is offline
post #11376 of 11387 Old 10-19-2014, 03:29 PM - Thread Starter
joe221's Avatar
Quoted: 23 Post(s)
No, the ID code you give them will enable them to kill the remote. You can still use it as it sits but never program it again.
Sometimes they asked for a part but I don't think they do that any more.
joe221 is offline
post #11377 of 11387 Old 10-27-2014, 08:29 AM
Sgooter's Avatar
Logitech says my two H1's (with swollen batteries) will be replaced with two Ultimate Ones, which is an impressive gesture of good will.
So, this old dog will need to learn some new tricks. This H1 thread has been a great source of knowledge for everyone for many years, as I'm sure all will agree.
Has a similar Official Harmony Ultimate One Thread (of similar depth of knowledge) been established on AVS? If not, then any recommendations for HU1 knowledge and tips?
Sgooter is offline
post #11378 of 11387 Old 10-27-2014, 09:17 AM - Thread Starter
joe221's Avatar
Quoted: 23 Post(s)
Great to hear! I knew the last One was replaced with a U1 so I figured that was still the deal.
Go to the Ultimate thread. The U1 is essentially an Ultimate without the RF kit. Easy upgrade BTW. I have both the U and the U1 which I upgraded with Smart control kit. My last One is doing kitchen TV duty and its power button is getting wonky. Enjoy the new hardware.
joe221 is offline
post #11379 of 11387 Old 10-27-2014, 10:42 AM
Sgooter's Avatar
Originally Posted by joe221 View Post
...Go to the Ultimate thread. The U1 is essentially an Ultimate without the RF kit...
Will do - thanks Joe.
Sgooter is offline
post #11380 of 11387 Old 10-28-2014, 01:42 AM
Fofer's Avatar
A year or two back I called to inquire about my Harmony One, that didn't seem to last very long (maybe 2-3 days?) with a fully charged battery. I had replaced the battery with a new one, and the situation didn't change. Anyway, Logitech sent me a replacement. The new one lasts 5-6 days with similar use. They said I could hold on to the old one, no need to send it back. And they didn't appear to "kill" it either, I am still able to use it, and I'm still able to program it. I relegated it to the bedroom instead of the living room, reprogrammed it with a smaller set of A/V equipment, and it sits on the recharging cradle whenever it's not in use.
I realize this is a YMMV situation, and the current replacement of an Ultimate One (after seven YEARS of ownership?!?) is a much better deal (I mean, WOW!) so perhaps the terms of the replacement are different.
Fofer is offline
post #11381 of 11387 Old 10-28-2014, 07:52 AM - Thread Starter
joe221's Avatar
Quoted: 23 Post(s)
Typical was killing the bad one. Things Change.
joe221 is offline
post #11382 of 11387 Old 10-29-2014, 07:17 PM
BartMan01's Avatar
Their policy keeps changing on this. When I had my swollen battery issue they were still selling the H1, and the only thing they would offer me was a 'discount' on a new one in the online store that would still make it more expensive than street prices were at the time (no free swap out). I was able to pry that battery out with a thin knife, a screw driver, a pair of needle nosed pliers, and a bit of force. That unit is a bit worn on the front, but still works better than the newer model H1 upstairs I got when CostCo was clearing them out.
BartMan01 is offline
post #11383 of 11387 Old Today, 10:13 AM
kjpjr's Avatar
Harmony One will not turn activities on
When I press watch TV sometimes the TV, DVR and sound bar will all turn on. Most of the time they do not, the TV always turns on but I need to go through help to get the DVR and sound bar. I have called logitech for help and all they do is have me take out the battery and press a few buttons. The last time I called they asked me to pay $10 for the help. They had me "reinstall" all the devices. None of this fixed the problem. I tried to increase the delay and it really did no good. They told me since the device is four years old they will only give me a 20% discount on a new item. There has to be a fix and may be in this forum but I could not find it. Hopefully someone can help me. Thanks!
kjpjr is online now
post #11384 of 11387 Old Today, 10:42 AM
pappaduke's Avatar
Quoted: 35 Post(s)
Liked: 51
I may not be able to help but you'll have to give more info. Mainly type of equipment. Also, the order that they come on. You may need to change the sequence. One other thing, my ATV does not always come on unless I point the remote at the ceiling.
post #11385 of 11387 Old Today, 12:17 PM
kjpjr's Avatar
My equipment is as follows and this is also the order they turn on when they do. TV - Panasonic TC-P60ST30 Cable Box - Cisco 8742HDC Sound Bar - Vizio VHT215 They all code out and all works sometimes. The TV always comes on but the box and the bar not so much.
kjpjr is online now
post #11386 of 11387 Old Today, 12:44 PM
NickTheGreat's Avatar
Quoted: 113 Post(s)
Liked: 94
Do you have good line of sight? My HTIB doesn't work very well with my H1, and it's mostly if I can't get a good view.
NickTheGreat is online now
post #11387 of 11387 Old Today, 01:04 PM
kjpjr's Avatar
There is nothing in the way, nothing
kjpjr is online now
Reply Remote Control Area
Logitech , Harmony 880 Advanced Universal Remote
User Tag List
