Official Logitech Harmony One thread - Page 382 - AVS Forum
 19Likes
post #11431 of 11451 Old 12-08-2014, 06:04 PM
jsmiddleton4's Avatar
Quoted: 95 Post(s)
Liked: 31
Pioneer 1124
Setting up a Pioneer 1124. Some times it feels like I need to adjust some of the default delays, time between button commands being sent, etc.
Wanted to check if anyone else with an 1124 and the Harmony One has dialed in any of those kinds of remote options and if so what values did you end up with?
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is offline
post #11432 of 11451 Old 12-10-2014, 07:12 AM
de8212's Avatar
Quoted: 76 Post(s)
Originally Posted by de8212 View Post
Every now and then my Harmony goes to the right input on my receiver, I get a second or two of audio and video and then it goes to another input. Pressing help fixes it but I'd like to add a delay and then have it go back to the right input.
I've gone through the software and can't seem to find a way.
Still can't get this to work. I've added a 2 second delay (which I thought was plenty of time) but it still ends up at the wrong input. And it's happening more often now.
de8212 is online now
post #11433 of 11451 Old 12-10-2014, 10:36 AM
ejhuzy's Avatar
Maybe it's not the delay, but repeats? IIRC there's another setting (sort of like the delay) that says how many times the command is repeated. Hope that's right, doing that from my memory. Sorry if I'm wrong.
ejhuzy is offline
post #11434 of 11451 Old 12-11-2014, 07:00 AM
rehaz1's Avatar
It sounds like you have HDMI-CEC control turned on, on one or more of your devices, this needs to be turned off, see thishttp://support.myharmony.com/en/unde...g-hdmi-and-cec
rehaz1 is offline
post #11435 of 11451 Old 12-11-2014, 07:23 AM
de8212's Avatar
Quoted: 76 Post(s)
I think you might be right. The only issue with that is my new samsung tv has some "smart" hub or something that utilizes it.
post #11436 of 11451 Old 12-11-2014, 12:29 PM
jyung's Avatar
Swollen Battery
I recently discovered that my One has a swollen battery. The battery has the blue label, and it is swollen enough that I cannot remove it with my fingers; I'm hesitant to use more force.
Random google searches have shown that up to last year, people were having success with Logitech replacing the remote with a current remote, even well out of the warranty period. Has anyone had success recently? How did you contact Logitech?
I contacted Logitech through the support email link at http://myharmony.com/ a few days ago, but no response.
TIA.
jyung is offline
post #11437 of 11451 Old 12-11-2014, 01:19 PM
Sgooter's Avatar
Random google searches have shown that up to last year, people were having success with Logitech replacing the remote with a current remote, even well out of the warranty period. Has anyone had success recently? How did you contact Logitech?..
Eventually, you should receive a response from someone at customercare@logitech.com. If they are willing and able to help you, a case number will be issued and further discussions and actions will follow, such as you sending them a photo showing your H1's serial number and the swollen blue stripe battery (not removed). If all is in order, they may opt to send you a new remote; most likely a Harmony Ultimate One. Good luck!
When in doubt, do the right thing.
Sgooter is online now
post #11438 of 11451 Old 12-12-2014, 03:17 AM
balboa dave's Avatar
TIA.
I pulled mine out with a butter knife (flat and not sharp) under it to lift and hold it up above the retaining ridge, and a pair of pliers to pull it out. It took a couple of tries, but it worked.
balboa dave is online now
post #11439 of 11451 Old 12-12-2014, 06:13 AM
NYC Guy's Avatar
I was successful with this type of method also. I used a small needle nose pliers and a very thin slot head type screwdriver. You insert the screwdriver first and lift the battery slightly and then pull the battery out with the needlenose pliers. My battery was pretty swollen and I was surprised about how easily the battery was able to come out.
NYC Guy is offline
post #11440 of 11451 Old 12-14-2014, 03:08 PM
kjpjr's Avatar
Quoted: 13 Post(s)
Thumbs down Harmony one still screwed up.
About 6 weeks ago I asked for help with my remote and got several replies but none of them really worked so I am going to try again. I appreciate the help from last time, let us see what happens this time.
My Harmony One turns on all 3 things about 15% of the time. The other times I need to use the help button to get the cable box to turn on and then to get the sound bar to turn on. Today it took about 3 or 4 minutes to get all running. I have a Panasonic Plasma TV, Cisco cable box and a Vizio sound bar. The TV always turns on but the other two -- maybe. I would go back to the TWC remote but their remote will not let me enter a 4 digit code and the sound bar has a 4 digit code. I have uninstalled, reinstalled and done that again. The tech service at Harmony talked me through it the first time. I have set the delays to longer times. I really do not know what I can do. There also is an occasional problem turning everything off but only about 10% of the time. Ever notice how the little things drive you crazy! Help, maybe, please! Harmony tech says they can do no more and are not willing to stand behind the product. This remote is becoming very close to a door stop
kjpjr is offline
post #11441 of 11451 Old 12-14-2014, 03:46 PM
mylan's Avatar
Quoted: 53 Post(s)
Liked: 74
Keeping it simple first, make sure you are holding the remote toward the equipment long enough for all the commands to be issued. I've never had a problem but sometimes my wife will pick it up, press the button and drop the remote on the sofa and has this same problem.
kjpjr likes this.
mylan is online now
post #11442 of 11451 Old 12-14-2014, 04:35 PM
49Merc's Avatar
Identify which component takes the longest to turn on. Do the same for all components. Next, program your One to power up each component in that order. You will have to insert delays as needed.
Another idea. If you use a SAT or cable box have it turn on first, TV second, AVR last. For a DVD have it power up first, TV second, AVR last.
Good luck.
MY EQUIPMENT
Sony HDTV KDL-46HX750
Denon AVR 1912
DirecTV HD DVR HR24 & AM21N OTA Receiver
Panasonic HD DVD DMP-BD65 & Toshiba HD DVR A20
Infinity Alpha Series Speakers - 50's (2), 20's (2), 10's (2), 37c (1) & Velodyne Subwoofer
Panamax M4300-PM Power Center
Monoprice Cables & Harmony One Remote
49Merc is offline
post #11443 of 11451 Old 12-14-2014, 07:31 PM
kjpjr's Avatar
Quoted: 13 Post(s)
Talking Help
Thanks for the ideas, I have been careful to aim the remote but it is important.
The order of turn on may help. I will rearrange them tomorrow and see what happens. Currently I have TV,Box and sound bar in that order. I will try the Box first.
49Merc likes this.
kjpjr is offline
post #11444 of 11451 Old 12-15-2014, 07:19 AM
Dominic26's Avatar
Are you using an IR repeater? That is screwing me up on 1 item.
Dominic26 is offline
post #11445 of 11451 Old 12-15-2014, 11:10 PM
tightrope's Avatar
Have you tried increasing the number of command repeats for the device that does not come on?
tightrope is offline
post #11446 of 11451 Old 12-16-2014, 08:27 AM
kikkoman's Avatar
Quoted: 33 Post(s)
Need to get back to reprogramming my One since I picked up some new devices. Anyhow, I have had similar issues where I have to keep hitting the help for things to turn on for me. I played with the delays but wasn't sure how much it helped or if I was setting them correctly. I just want it to work well like it seems to do for alot of people. Is there an up-to-date guide on setting up the One with your devices and a guide to be able to mimic all commands from your device onto the One? Or a quick way to do it or is that all manual? I do not recall.
But make sure to program the One so that it turns on the device that takes the longest to run, first, correct? That makes sense.
This means it will send the same command multiple times? So you can program the activity to turn on TV, 3d player, AVR and say the 3d player has issues, you tell that one device to send multiple 'On' commands to it? Sorry, I haven't gone in the setup in over a year. I need to download the program again and setup on my MBP. I did have the software on the PC awhile back.
Any other up-to-date guides would be great!
Thanks in advance.
kikkoman is offline
post #11447 of 11451 Old 12-16-2014, 10:11 AM
tightrope's Avatar
Here's a guide outlining how to add command repeats:
http://support.myharmony.com/en/adju...ommand-repeats
post #11448 of 11451 Old 12-16-2014, 02:52 PM
kikkoman's Avatar
Quoted: 33 Post(s)
Thanks, I'll look into that as well as probably just going thru the harmony site and setting everything up again. Just thought that there was an up-to-date guide somewhere to setup the One and get it working with all devices.
Curious, but how long did it take all of you to setup your One with all your devices and Activities? I know it depends on how many devices and activities you have, but maybe a rough ballpark on setting up 1 device with all of that devices buttons. I know you can pull in the device from the harmony device database but I don't recall if it gives you all of the commands for that device. But then going thru and moving buttons around and which page they should be setup in. Then for those who use a cable box to use the cable icons. Not sure if I will do that now, but maybe in the future.
kikkoman is offline
post #11449 of 11451 Old 12-16-2014, 03:52 PM
rehaz1's Avatar
Another setting to check is the Inter-Device delay for those devices not powering on, since the Help button fixes the problem usually points to the Inter-Device delay not being set high enough for each of those devices.
rehaz1 is offline
post #11450 of 11451 Unread Yesterday, 11:13 PM
pappaduke's Avatar
Quoted: 42 Post(s)
Liked: 52
I'm not going to give a timeframe, but I will give this advice. Make sure when you sit down to do the programming that you have all of your components model numbers written down. Also, make sure that you write down what inputs your components are connected to. This will surely speed up the process. I personally keep all of this information on my iPad for easy reference. Generally the One will have the majority of your original remotes commands. I usually concentrate on getting the basics right and then go back and do the fine tuning later. Hope this helps.
pappaduke is online now
post #11451 of 11451 Unread Today, 05:56 AM
Sgooter's Avatar
...Curious, but how long did it take all of you to setup your One with all your devices and Activities? I know it depends on how many devices and activities you have, but maybe a rough ballpark on setting up 1 device with all of that devices buttons...
I had 12 devices in my HT system and the initial setup with my H1 took just over an hour and it was fun to do. Over the next 3-4 weeks I made numerous small adjustments and added the favorite channel icons. Then, over the next 6+ years, I made changes only when I replaced/added new devices and activities to my HT system, and those took only a few minutes, including "learning" some needed button commands for a new device's remote to the H1. So, my H1 was a high maintenance gadget during its first month, then very little maintenance afterwards.
Reply Remote Control Area
Logitech , Harmony 880 Advanced Universal Remote
