Official Logitech Harmony One thread - Page 386 - AVS | Home Theater Discussions And Reviews
 41Likes
post #11551 of 11571 Old 03-07-2015, 01:50 PM
Duck05's Avatar
Originally Posted by jonperk View Post
My One has been working flawlessly for years. I now added two new activities (I have a total of 5) and for one of these new activities, the Denon volume does not respond. 3 activities use the Denon and work fine but not this new one. I've deleted the older Denon "device" and added it back with the newer 2808ci device (I've done this several times). I've also manually programmed the volume up/down and also reset the remote. Any ideas would be much appreciated!
Jon
Appears you have tried everything that has worked in the past.... Try re-ordering your activities placing the one that does not work at the "top"; reload the remote, test it, and if it still fails then delete it. Reload the remote. Create a new activity from scratch and see how that goes.... Beyond that sequence (which has been successful for me in similar circumstances) not sure what else to try....
BTW, for the activity that fails - when you try to use the volume up/down - does the IR icon illuminate or not? If it does, somewhere the H1 is not sending the correct IR sequence so the whole idea of reordering is an attempt to shuffle around how the commands are stored.
Duck05 is offline
post #11552 of 11571 Old 03-08-2015, 11:55 AM
BartMan01's Avatar
Originally Posted by 49Merc View Post
Okay, so I took off the cover then used a butter knife to lift up the white battery but it will not pop out. Tried it four times. Does this indicate anything other than it's stubborn. Battery looks rectangular and charges.
If you had to use a butter knife to lift it up then it is swollen - it swells in the middle (where you can't see it while in the remote) and the swelling prevents you from being able to just lift it up with your finger. When it is 'normal', you can lift it up with your finger and a spring pushes it out towards you when it clears the lip.
I had the problem back before they started replacing them for free (my support option was 'sorry buy a new one'), and a combination of thin knife, needle nose pliers, and patience eventually got the old battery out.
49Merc likes this.
BartMan01 is offline
post #11553 of 11571 Old 03-08-2015, 12:53 PM
de8212's Avatar
Quoted: 114 Post(s)
I can't remember when I got my One. And I've never heard of the swollen battery issue. Just checked for the heck of it. The battery didn't free fall out of the compartment but it wasn't stuck as bad as others. I got it out and can definitely see a bulging in the center.
Should I just replace the battery or contact Logitech?
de8212 is offline
post #11554 of 11571 Old 03-08-2015, 01:25 PM
johnboy813's Avatar
Since you can get it out, there are replacement batteries you can get from Amazon. I had the swollen battery a few years ago and ordered the replacement from Amazon and it has worked great ever since. The good thing about just ordering the battery is you get to keep the One verses a possible inferior replacement.
120inna55 and 49Merc like this.
johnboy813 is offline
post #11555 of 11571 Old 03-08-2015, 02:17 PM
de8212's Avatar
Quoted: 114 Post(s)
Just ordered one. Thanks.
de8212 is offline
post #11556 of 11571 Old 03-08-2015, 03:46 PM
120inna55's Avatar
Quoted: 17 Post(s)
FYI, when you lay the battery on a flat surface, you should not be able to spin it. If you can, it's a sign of early swelling.
120inna55 is offline
post #11557 of 11571 Old 03-09-2015, 03:25 AM
Bladerunner1959's Avatar
Location: Pittsburgh...Preferably the Virgin Islands....
Liked: 51
What' the cost of a replacement battery via Amazon?
Bladerunner1959 is offline
post #11558 of 11571 Old 03-09-2015, 05:17 AM
jonperk's Avatar
I figured this out. I had setup the activity with the activity type as "Utility". I deleted this and added the type as "laserdisc". All is fine now.
Jon
jonperk is offline
post #11559 of 11571 Old 03-09-2015, 09:01 AM
BartMan01's Avatar
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=harmony+one+battery
post #11560 of 11571 Old 03-09-2015, 09:03 AM
de8212's Avatar
Quoted: 114 Post(s)
I got the 7.99 one because it was Prime and it had a higher mAh than the one that's listed as "New Version".
de8212 is offline
post #11561 of 11571 Old 03-12-2015, 03:16 PM
49Merc's Avatar
Quoted: 54 Post(s)
Originally Posted by Sgooter View Post
Yes, I used their webpage, and I believe I reported it as a "swollen battery/unable-to-remove problem" versus a warranty issue. I later had to provide them with model/serial number photos and a photo of the swollen battery in-place inside the H1, and the log-in ID of my Harmony account. The total process time for me was about 2 weeks from reporting the problem to receiving the replacement. Good luck!
I received a response from Logitech today. Here is a portion: "Our Warranty department has requested a digital image of your Harmony Remote's LCD screen and the battery compartment of the remote showing the swollen battery and the PID and P/N of the remote. When submitting the digital image, please place a piece of paper beside/underneath the remote with your reference number......"
It has been impossible to get a Logitech CS rep who can answer the following question so I would like your opinion. As Logitech stated above, Logitech in part, has requested a digital image of the "LCD screen". Should my H1 be turned on or off? That leads me to another question. Should the swollen battery still power my remote?
Looking forward to your responses.
Sony HDTV KDL-46HX750, Denon AVR 1912, DirecTV HD DVR Genie HR44, DirecTV AM21 OTA Rcvr, Panasonic Blu-ray DMP-BD65, Toshiba HD DVD A20, Infinity Alpha Speakers 50's, 20's, 10's, 37c, Valodyne VRP-1000 Sub, Panamax M4300-PM, Harmony Ultimate One Remote, Monoprice AV Cables
49Merc is offline
post #11562 of 11571 Old 03-12-2015, 08:09 PM
Sgooter's Avatar
Quoted: 20 Post(s)
Liked: 26
I have some opinions versus definitive answers: I was never asked to provide a photo of the LCD screen; maybe Logitech now wants to make sure they're not being suckered into replacing an H1 that's already broken and inoperative due to reasons other than a swollen battery. So, my opinion is that the LCD screen should be ON for the photo. However, if your swollen battery is no longer rechargeable and does not have enough juice to power up the LCD screen, then just explain it that way in your email reply with your attached photos. The main reasons Logitech is willing to replace the H1 with the Ultimate One are: the swollen battery cannot be removed without risking damage, and...the H1 is no longer produced and the U1 is regarded as a suitable substitute. I don't believe it matters whether your swollen battery can still power your H1 or not, since the main problem is that it cannot be removed and replaced with a new battery. My swollen battery was not holding a charge for very long (5-10 hrs) and was getting progressively worse.
WRT difficulty in getting a CS rep to respond: I recall that each one of my several email exchanges (query and response) with Logitech customer support took a couple of days each, which I believe was due to time zone differences between me and Asia (maybe).
49Merc likes this.
When in doubt, do the right thing.
Sgooter is offline
post #11563 of 11571 Old 03-12-2015, 08:29 PM
49Merc's Avatar
Quoted: 54 Post(s)
Thank you for such a helpful response. Now I can get my reply to Logitech out by tomorrow.
49Merc is offline
post #11564 of 11571 Old 03-14-2015, 12:52 PM
49Merc's Avatar
Quoted: 54 Post(s)
Logitech informed me today that I will be receiving a new Harmony Ultimate One. The process was easy and timely. Thanks again for your help folks.
49Merc is offline
post #11565 of 11571 Old 03-14-2015, 04:38 PM
Sgooter's Avatar
Quoted: 20 Post(s)
Liked: 26
Glad to hear it worked out OK for you.
49Merc likes this.
Sgooter is offline
post #11566 of 11571 Old 03-14-2015, 05:06 PM
rightintel's Avatar
Quoted: 180 Post(s)
Liked: 66
They gave you a whole new remote due to the battery? Dang, that's customer service.
49Merc likes this.
Xbox Live: General PATT0N
rightintel is offline
post #11567 of 11571 Old 03-14-2015, 05:35 PM
49Merc's Avatar
Quoted: 54 Post(s)
Outstanding customer service. Logitech considers, which I assume is correct, that an in place swollen battery renders the H1 terminal. I failed to mention I was informed my H1 software account will be or is now inaccessible.
49Merc is offline
post #11568 of 11571 Unread Yesterday, 02:34 PM
rehaz1's Avatar
Quoted: 26 Post(s)
You are posting in the wrong forum, this forum is for the Harmony "One" you have the "Ultimate One" two entirely different remotes. Post your questions for the Ultimate One here: Harmony Ultimate, Smart Control and Hub
rehaz1 is offline
post #11569 of 11571 Unread Yesterday, 04:07 PM
49Merc's Avatar
Quoted: 54 Post(s)
rehaz1, please note that my post you referenced has been deleted from this forum.
49Merc is offline
post #11570 of 11571 Unread Yesterday, 05:17 PM
49Merc's Avatar
Quoted: 54 Post(s)
As I now leave this forum I wish all Harmony One owners the very best.
49Merc is offline
post #11571 of 11571 Unread Today, 06:46 AM
RVD26's Avatar
Quoted: 31 Post(s)
I had the same issue with the swollen battery in my H1.
Logitech also replaced it with the Harmony One Ultimate free of charge.
RVD26 is online now
Reply Remote Control Area
Logitech , Harmony 880 Advanced Universal Remote
