Official Logitech Harmony One thread - Page 388 - AVS | Home Theater Discussions And Reviews
Old 05-01-2015, 10:32 AM
mdavej's Avatar
Quoted: 1125 Post(s)
Liked: 604
Another thing to consider is that IR dimmers need to be line of sight. So if your TV is in front of you and your wall switch is behind you, your activities that use both will fail. IMO, if you're spending big bucks on home automation anyway, may as well do it right and forego IR.
mdavej is offline
Old 05-01-2015, 12:35 PM
bmock17's Avatar
Quoted: 47 Post(s)
Originally Posted by mdavej View Post
It appears that series is not IR, so your One won't work. If you manage to find some sort of IR gateway device, then it may be possible to control it. Since that kind of thing is a couple hundred bucks anyway, may as well upgrade to Ultimate Home and control it natively. You'll need to confirm those are on the list of compatible devices for that remote though.
Originally Posted by jcalabria View Post
Just a bit of additional info... If you're not absolutely tied to that particular series of Lutron dimmer, the Lutron Maestro IR series of dimmers is IR-controlled. I don't have any myself to be able to strongly recommend for or against them, but I have set them up with various Harmony remotes for friends, and they do seem to work OK.
Originally Posted by Audixium View Post
I have one of the Lutron IR dimmers in the master bedroom and our Harmony 650 controls it just fine. It's a nice bonus to be able to include it in activities.
Originally Posted by pjp View Post
I've also had a Lutron Maestro IR dimmer for several years and it works flawlessly with my 880 (meaning it will also work with the One). I find the physical switch on the Maestro kind of poorly designed -- sometimes it turns "on" to full brightness from dim when I meant to turn it off -- it's almost certainly operator error on my part, but they could have designed the physical switch better IMO. That said, the switch works flawlessly and intuitively from the remote
One drawback of the Maestro is I don't think they have any way to support control multiple dimmers in the same area. It would be nice if they had an "A, B, C" channel switch so you could separately control different dimmers in the same room. That said, if you need a single dimer control in a room, it's hard to beat and it's only about $30 at Home Depot and elsewhere.
Thanks for all of the responses. I didnt realize the dimmer i bought was not IR. Not a huge deal, i can use the remote that came with the dimmer, i just thought it would be easier to use the harmony remote. Its not worth it to uninstall the dimmer and bring it back to home depot. Plus, i think i threw away the receipt already. Thanks again though for the help!
bmock17 is offline
Old 05-01-2015, 05:22 PM
pjp
pjp's Avatar
Quoted: 28 Post(s)
In case you change your mind, Home Depot will take it back without the receipt as long as you have the original credit card you bought it with -- have done this many times. No time limit on returns to Home Depot either (as long as they still sell the item, they will take it back).
pjp is offline
Old Today, 12:07 PM
kjpjr's Avatar
Quoted: 16 Post(s)
Liked: 26
Cisco 9865HDC and Harmony One
My Harmony one is doing weird things with this new box from TWC. It appears to be working fine until you go into any kind of settings. Then it will skip every other one. For example, I was trying to change the background color on Navigator but the remote would not let me stop there it went on to the next thing and then when you press the down or up arrow it skips that one and goes on to the next one. I called Harmony today for help. They say they are open 10 to 5 but all I get the message telling me that. This is the six dvr box TWC is putting out. BTW the remote that TWC gave me works perfectly. So it may be time to dump the one and go back to two remotes. The TWC remote will not accept my sound bar -- it has a 4 digit code and TWC only allow 3. Any ideas or anyhow thanks for the rant!
kjpjr is offline
Old Today, 02:26 PM
jcalabria's Avatar
Quoted: 43 Post(s)
Liked: 52
Should be a simple fix. In the Harmony software, go into troubleshooting for that device and select "...responds to some commands either too many times or only occasionally." Then reduce the setting, which represents the number of command repeats the One sends out. Once completed, update your One and give it a try. You may have to experiment a bit to find the best setting.
I've found it fairly common to have to reduce the number of repeats for devices. How a device responds to command repeats is a function of the particular device, not the One.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 7.3.1_6
jcalabria is offline
Logitech , Harmony 880 Advanced Universal Remote
