Official Logitech Harmony One thread - Page 399 - AVS Forum | Home Theater Discussions And Reviews
 75Likes
post #11941 of 11958 Old 09-07-2016, 03:29 PM
mylan's Avatar
Quoted: 170 Post(s)
Liked: 162
Ok, I'm stumped. I am trying to update my One with commands for my new Tivo Bolt but it turns it off when I hit the power off button. Going into the menu gives me an option to leave the Tivo on but it will not let me finish it, any ideas?
Specifically, in settings it says "what settings do you want to change, power settings, my device doesn't turn on correctly.
Set that and you get a screen that says "I want to leave this device powered on all the time
Select that and you get "I press the same button" or "I press two different buttons" and the tip is select the second option, click that and and you get command settings but it asks for a command duration, I just want it to NOT turn it on..period..
This and hooking up a Tivo Bolt and Mini the same day is a bit much...
mylan is online now
post #11942 of 11958 Old 09-08-2016, 04:20 AM
InVinoVeritas's Avatar
The power off button turns off all devices that were turned on by the One. The options to leave it on are for when you are changing activities. For instance, if you have an activity 'Watch TV' and you elect to keep devices turned on, when you change to 'Listen to CD', it will leave all the original 'Watch TV' devices on (instead of powering off the unneeded ones), and also power on any additional devices. When you press the power off button, every device that was turned on will turn off.
I have mine set that way, so that everything I do stays on until I am done with everything - then everything goes off. Watch TV, Watch Netflix, Play XBox, etc.
Not sure what you are trying to do but hope that helps.
InVinoVeritas is offline
post #11943 of 11958 Old 09-08-2016, 04:34 AM
mylan's Avatar
Quoted: 170 Post(s)
Liked: 162
I am trying to program the One to never turn off the Tivo Bolt, regardless of which activity I've selected, so far to no avail.
mylan is online now
post #11944 of 11958 Old 09-08-2016, 04:51 AM
jcalabria's Avatar
Quoted: 108 Post(s)
Liked: 85
In the power settings for the Tivo device, tell the software that your remote has no power buttons (last option) rather than you want to leave it on all the time. The remote will then totally ignore power for the TiVo.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 7.3.2_0
jcalabria is offline
post #11945 of 11958 Old 09-08-2016, 05:31 AM
mylan's Avatar
Quoted: 170 Post(s)
Liked: 162
Much appreciated, I'll try that when I get home.
mylan is online now
post #11946 of 11958 Old 09-13-2016, 09:28 AM
khansha's Avatar
Has anyone gotten the Harmony 650 working with the Onkyo HT-RC-270 AV receiver? During setup it seemed to recognize the model number but most of the extra buttons don't really seem to work as expected.
khansha is online now
post #11947 of 11958 Old 09-13-2016, 09:48 AM
jcalabria's Avatar
Quoted: 108 Post(s)
Liked: 85
Not that particular model, but I've never have had much problem at all programming Harmony remotes for many other Onkyos (TX-NR801, TX-SR806, TX-SR876, TX-NR3007, TX-NR5008, TX-NR1010, TX-NR535, HT-R2295, HT-R693). The Onkyo IR command structure is consistent across multiple models/years, with only a few new commands being added each year. Since the most likely issue is that the Harmony database for your model may be incomplete or have errors, I would try using another similar vintage model in the Harmony database such as a TX-NR808, TX-NR1008, etc.
Alternatively, you could just teach the Harmony the correct IR commands from your OE remote for any commands that do not behave as expected.
post #11948 of 11958 Old 09-14-2016, 09:04 AM
mylan's Avatar
Quoted: 170 Post(s)
Liked: 162
I have just updated my One and noticed the time is wrong, it does indicate Wednesday but it says 5:08, any suggestions?
mylan is online now
post #11949 of 11958 Old 09-14-2016, 09:10 AM
Tom Thomas's Avatar
You can adjust the time and date on the remote itself. I think it's under OPTIONS on the main screen.
My One only goes to 2010 or so if I remember correctly
Tom Thomas is offline
post #11950 of 11958 Old 09-14-2016, 09:22 AM
mylan's Avatar
Quoted: 170 Post(s)
Liked: 162
Much appreciated, that was it. I've had my One for five years and I am still finding out things about it.....
mylan is online now
post #11951 of 11958 Old 09-17-2016, 12:57 PM
khansha's Avatar
Thanks for the suggestions, I tried using the TX-NR808 model number but I still cannot use the remote to control the receiver. Unfortunately my OE remote doesn't seem to work anymore.
I did call into Logitech support and they recommended getting the pronto hex codes and emailing them. Would you have an idea if those hex codes are available on this or other websites even for the TX-NR708 or the TX-NR808?
post #11952 of 11958 Old 09-17-2016, 01:35 PM
mdavej's Avatar
Quoted: 2038 Post(s)
Liked: 918
Onkyo support will email you the codes upon request. But I can tell you that all models in the past several years share the same codes, just like jcalabria said. So any model you pick should work fine. It's more likely that something is wrong with your Onkyo or interfering with it.
Here's the latest list of codes I have. Your models are in columns BV and BY, with codes in C, D, E for zones 1, 2, 3 respectively. They have the same codes as the following ~170 other models:
Spoiler!
mdavej is offline
post #11953 of 11958 Old 09-17-2016, 03:33 PM
roxiedog13's Avatar
Quoted: 881 Post(s)
Liked: 333
remote failed
My Harmony remote failed, I think one of the IC's popped from a visual inspection, battery is still good but the unit is a dead. Too bad never really used it, just getting around to it but out of warranty .
Anyway, I installed the apple app to a iPad and it works great. Nothing fancy but works well, guess I will not bother to upgrade to iRule or Simple control as this will cost me nothing.
The remote layouts on the iPad are not great just wondering if there is any way to modify this.
Dedicated Theater: JVC X950R/RS600 , Panamorph DC1 Anamorphic Lens, Draper TecVision XT1800X Screen, 2.40:1 132" diagonal curved 36FT radius, Denon X7200WA , 7.2.4 Atmos, Paradigm Monitor 11 fronts, Monitor 3 Center, Monitor V7 Rear, SA-ADP In-wall Surround, Niles DS-7 In-Ceiling, Subwoofers: (4000 watts peak) Klipsch RW-12 + SVS PC13-Ultra
roxiedog13 is offline
post #11954 of 11958 Old 09-17-2016, 03:52 PM
mdavej's Avatar
Liked: 918
I think you've posted in the wrong thread. The One has no app, so I'm not really sure what you have or what you're talking about. I assume you may have some hub based Harmony. Maybe post in one of those threads. I don't think One users would be able to help you with that.
mdavej is offline
post #11955 of 11958 Old Today, 06:37 AM
khansha's Avatar
Here's the latest list of codes I have. Your models are in columns BV and BY, with codes in C, D, E for zones 1, 2, 3 respectively. They have the same codes as the following ~170 other models.
Thank you for sharing that excel with me. Incidentally the excel shared with me by Onkyo support didn't have the pronto codes.
post #11956 of 11958 Old Today, 07:25 AM
mdavej's Avatar
Liked: 918
You're welcome. Would you mind posting the file(s) you got from Onkyo? I'd like to have the latest. Pronto hex can be easily generated from whatever limited info they gave you.
mdavej is offline
post #11957 of 11958 Old Today, 07:54 AM
khansha's Avatar
Here you go. Going by the number appended to the file, yours might be the later file.
post #11958 of 11958 Old Today, 08:21 AM
mdavej's Avatar
Liked: 918
Thanks. Yep, that's an older file, and those are serial codes for RS-232 and TCP-IP, not IR. No wonder the pronto hex was missing. So they gave you the wrong info. It would come in handy for something like iRule, but is useless with Harmony. They wouldn't know what to do with it.
mdavej is offline
Reply Remote Control Area
Harmony 880 Advanced Universal Remote , Logitech
