Official Logitech Harmony One thread - Page 400 - AVS Forum | Home Theater Discussions And Reviews
 81Likes
post #11971 of 11996 Old 11-07-2016, 05:27 AM
Sgooter's Avatar
Quoted: 92 Post(s)
Liked: 81
If I were to connect a friend's programmed H1 to my Logitech Harmony software would I be able to see and/or change its devices and settings? His H1 was acquired thru a house purchase 2 yrs ago and hasn't been used since, and the original home owner has moved abroad and out of touch - so his Logitech Harmony s/w log-in credentials are unknown. Our local cable company has been bought out by Charter and some things will soon change, such as a new channel lineup and maybe a different cable box. My friend now wants to start using the H1, and would prefer not to start all over to re-program it. If I can't see his programming set up on my software, then I suppose he could seek help from Logitech. Anyone have experience with getting Logitech's cooperation in resolving this type of issue? Thanks.
Please enter password to view this signature.
Sgooter is offline
post #11972 of 11996 Old 11-07-2016, 06:16 AM
Bond 007's Avatar
Quoted: 2091 Post(s)
Liked: 1749
Only if you know the previous owners login.
Bond 007 is offline
post #11973 of 11996 Old 11-10-2016, 06:55 PM
mekump's Avatar
Battery charge not lasting very long anymore. I was able to pry the swollen battery from my harmony one. I'd like to replace it with an OEM battery. Where can I purchase one from?
mekump is offline
post #11974 of 11996 Old 11-10-2016, 08:16 PM
Bond 007's Avatar
Liked: 1749
Amazon, ebay
Bond 007 is offline
post #11975 of 11996 Old 11-11-2016, 04:50 AM
Sgooter's Avatar
Quoted: 92 Post(s)
Liked: 81
Thank you.
Sgooter is offline
post #11976 of 11996 Old 11-11-2016, 05:10 AM
Sgooter's Avatar
Quoted: 92 Post(s)
Liked: 81
I suggest searching for a Logitech OEM replacement battery. My replacement was a Logitech (w/logo) 930maH, S/N: F12440023, L/N: Q33C.
Sgooter is offline
post #11977 of 11996 Old 11-11-2016, 05:14 AM
Bond 007's Avatar
Liked: 1749
Thank you.
To be clear.
You cant revise the previous owners settings but you can reprogram it with your own. Basically, treat it as if it is new.
Bond 007 is offline
post #11978 of 11996 Old 11-11-2016, 05:25 AM
Sgooter's Avatar
Quoted: 92 Post(s)
Liked: 81
To be clear.
Yep, I understand. He was hoping that he wouldn't need to start all over. I suggested he contact Logitech; maybe they will be cooperative. If a total re-do is needed, at least he has now written down all the devices currently programmed in the remote. For me, setting up and tweaking my activities was fun to do.
Sgooter is offline
post #11979 of 11996 Old 11-11-2016, 05:32 AM
Bond 007's Avatar
Liked: 1749
Yep, I understand. He was hoping that he wouldn't need to start all over. I suggested he contact Logitech; maybe they will be cooperative. If a total re-do is needed, at least he has now written down all the devices currently programmed in the remote. For me, setting up and tweaking my activities was fun to to.
Same here. I would rather spend a couple of hours customizing it to my liking than spend that time on the phone with Logitech.
Bond 007 is offline
post #11980 of 11996 Old 11-11-2016, 06:10 AM
mekump's Avatar
Amazon, ebay
I am concerned about counterfeit batteries, so I was hoping for an OEM battery.
mekump is offline
post #11981 of 11996 Old 11-11-2016, 06:41 AM
mekump's Avatar
I sent an email to Logitech support asking where I can purchase an OEM battery for the harmony one since I am having trouble finding one online.
Here is part of their reply:
"Please know that your remote has been discontinued for years now. The battery is no longer available. You may check local electronic stores or legitimate online sellers for the lithium-ion battery. Please be guided by this link: https://thecounterfeitreport.com/product/570/Logitech-Harmony-Remote-Batteries.html"
mekump is offline
post #11982 of 11996 Old 11-11-2016, 06:58 AM
Tom C's Avatar
Quoted: 52 Post(s)
Liked: 56
Originally Posted by NickTheGreat View Post
I bought this one through AMZ in Dec 2011 and it still works fine (knock on wood)
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Originally Posted by rehaz1 View Post
The problem with that battery is it is the one with the Blue Stripe, and those batteries have a tendancy to swell, making it impossible to remove the battery from the remote.
Originally Posted by Tom C View Post
Are you sure? I seem to recall that when I researched it the blue stripe ones are the good ones. Of course I wouldn't put it past myself to get them backwards.
Yes I am positive, I had 3 Blue Stripe batteries that swelled, luckly I was able to remove them from my H1 and 2 900s. I have all White batteried with the labling directly on the batteries, there are some counterfit batteries that have a white label affixed to them that have caused permanent damage to the Harmony remotes making them completely unuaable and unfixable
I did get it a$$backwards. Thanks for the correction.
Hope this helps.
shimonmor likes this.
LG OLED65B6P ** Denon AVR-X4200W ** oppo BDP-103D
HR44 DirecTV ** Panamax 5300 ** Harmony One Universal Remote
Hsu HB-1 MK2 (L, R & S) ** Hsu HC-1 MK2 (C) ** Hsu VTF-15H (sub)
Crowson Technology Level 2 Motion System
Tom C is offline
post #11983 of 11996 Old 11-11-2016, 07:58 AM
Tom Thomas's Avatar
I ordered this one from Amazon last year and it has been working well.
https://www.amazon.com/M2cpower%C2%A...8876195&sr=8-1
mekump likes this.
Tom Thomas is offline
post #11984 of 11996 Old 11-11-2016, 08:41 AM
Bond 007's Avatar
Liked: 1749
I got this one and it works perfectly.
Do your research and shop wisely.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
mekump likes this.
Bond 007 is offline
post #11985 of 11996 Old 11-18-2016, 10:54 AM
b_scott's Avatar
Quoted: 33 Post(s)
Any Harmony One fans used the 950? Is it comparable? I'd miss the hard number buttons but otherwise it seems decent from looking at it.
b_scott is offline
post #11986 of 11996 Old 11-18-2016, 11:12 AM
Bond 007's Avatar
Liked: 1749
I think that was covered in the last 10 pages or so.
Bond 007 is offline
post #11987 of 11996 Old 11-19-2016, 05:24 AM
radamo's Avatar
Quoted: 171 Post(s)
Liked: 35
I was just about to post the same question. I have been starting to have a few buttons on my Harmony One be a little "iffy". The 950 looks to be the best alternative so far. Will miss the One for sure though.
radamo is offline
post #11988 of 11996 Old 11-19-2016, 08:15 AM
Sgooter's Avatar
Quoted: 92 Post(s)
Liked: 81
Before giving up on your H1, take a look at harmonyremoterepair.com. I sent my two well-used H1s there; received them back a few days later - all good as new. Highly recommend.
radamo likes this.
Sgooter is offline
post #11989 of 11996 Old 11-19-2016, 08:58 AM
balpers's Avatar
Thanks for posting this. I was about to ask if anyone has experience with this service. Good to know they seem to be reliable.
The Consultant's Creed:
I can do it right.
I can do it cheap.
I can do it fast.
You get to choose any two.
balpers is offline
post #11990 of 11996 Old 11-19-2016, 11:54 AM
Sgooter's Avatar
Quoted: 92 Post(s)
Liked: 81
It was the finest experience I have ever had: integrity, technical expertise, systematic approach to inspection and repair, great communication, attention to detail, fair price, quick turnaround, etc...tops in every aspect.
Sgooter is offline
post #11991 of 11996 Old 11-21-2016, 06:31 AM
Deezul's Avatar
Quoted: 35 Post(s)
Liked: 26
I had a great experience with them as well. Numerous buttons on my One weren't responding to key presses, more than one of their default packages, so a quick email and I was given a quote for repair. Very much recommended! I'll give up my Harmony One only when Logitech stops updating it with devices!
Xbox 360: Deezul AwT
HDTV since 2004, 3D since 2011
Go Jackets!
Deezul is offline
post #11992 of 11996 Old 11-21-2016, 07:51 AM
Tom Thomas's Avatar
I used him as well and was extremely happy with the level of service and the overall experience. I would highly recommend Quin at harmony remote repair.
post #11993 of 11996 Old 11-21-2016, 01:26 PM
pappaduke's Avatar
Quoted: 112 Post(s)
Liked: 103
I know I have at least two buttons that don't respond well, but will they check all buttons or do you have to specify which buttons to replace?
Yamaha 2010
Oppo 103D,ATV3,PS3, Samsung UN60ES7100F, Bluesound Vault 2 and Pulse Mini, Harmony One, Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's
Zone2-Paradigm SE-1's, Zone3-Paradigm-Stylus 370-SM
pappaduke is offline
post #11994 of 11996 Old 11-21-2016, 01:33 PM
Tom Thomas's Avatar
It would be best to describe the problems you are having as best you can and let him troubleshoot and recommend what repair may be needed.
You can email him and discuss your needs at: info@harmonyremoterepair.com
Sgooter likes this.
post #11995 of 11996 Old 11-21-2016, 05:27 PM
fpileggi's Avatar
Quoted: 40 Post(s)
Liked: 36
The site has a template of the buttons you can mark for inspection/replacements so you should be confident in the work to be done.
fpileggi is offline
post #11996 of 11996 Old 11-21-2016, 08:31 PM
pappaduke's Avatar
Quoted: 112 Post(s)
Liked: 103
Thanks for the responses and advice. I'll do a button check and then figure out the best time to send in my beloved One. I don't ever want to give up this remote.
Yamaha 2010
Reply Remote Control Area
Harmony 880 Advanced Universal Remote , Logitech
