Official Logitech Harmony One thread - Page 404 - AVS Forum | Home Theater Discussions And Reviews
 103Likes
Old 01-22-2017, 12:19 PM
tokerblue's Avatar
Quoted: 132 Post(s)
Liked: 86
I haven't updated my One in several years, but I just added a Sony Bluray/SACD player.
Is there a way to map a color button icon to the Activity? I know that the One will do it for specific devices like a DirecTV box, Playstation 3, etc. But I don't know if there is a way to do it for other devices. I typed in "Blue", "Red", "Yellow", "Green" for custom buttons, but only the text appears.
tokerblue is online now
Old 01-22-2017, 02:34 PM
garnuts's Avatar
Quoted: 79 Post(s)
Liked: 58
You should be able to 'learn' any IR signal if you have an original remote to learn it from.
Using the Harmony 7.7.0 software:
-Devices tab
-'Learn IR' for desired device
-Scroll to bottom of page to 'Learn a New Command'
-You can name that new command anything you want
-Go back to activities, under desired activity 'Customize Buttons'
-Your New Command should be there if the device you chose is part of that Activity
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is offline
Old 01-22-2017, 02:43 PM
tokerblue's Avatar
Quoted: 132 Post(s)
Liked: 86
Sorry, I should have been more clear. I meant picture icons like this. The actual Blue/Yellow/Red/Green text sends the correct command.
Old 01-22-2017, 07:06 PM
garnuts's Avatar
Quoted: 79 Post(s)
Liked: 58
Gotcha,
If you ever figure out a way to do this please post it, I would like these for a couple of my activities.
garnuts is offline
Old 01-22-2017, 07:16 PM
mdavej's Avatar
Quoted: 2130 Post(s)
Liked: 941
http://www.remotecentral.com/cgi-bin...hread.cgi?6618
mdavej is offline
Old 01-22-2017, 07:34 PM
tokerblue's Avatar
Quoted: 132 Post(s)
Liked: 86
Originally Posted by mdavej View Post
Unfortunately, it seems to be device based. The icons will appear automatically for certain Activities, possibly only certain devices. I'm going to try adding a device that has the icons and see if I can somehow get it to work.
ID:	1913233   Click image for larger version
Old 01-22-2017, 07:49 PM
tokerblue's Avatar
Quoted: 132 Post(s)
Liked: 86
It looks like the functionality is Activity based. I added the DirecTV DVR to the Bluray Activity and the color icons did not appear. I created a new TV Activity and added the Bluray player. When I typed in "Red", it automatically added the icon.
garnuts likes this.
Old 01-22-2017, 08:38 PM
tokerblue's Avatar
Quoted: 132 Post(s)
Liked: 86
I got it to work. I basically created a dummy DirecTV device. I then changed the power setting to "No Power Button". That will keep the Harmony from turning on the dummy device when going to the Activity.
Next step was to create a "Watch TV" Activity. I then added the Blu-ray player to the Activity manually and programmed it as normal.
When I named the buttons Red, Yellow, Green, Blue the Harmony automatically mapped the icons to the soft button screen for the Blu-Ray Activity.
Old 01-22-2017, 09:07 PM
garnuts's Avatar
Quoted: 79 Post(s)
Liked: 58
Thanks for posting your work around. I'll have to give it a try.
garnuts is offline
Old 01-27-2017, 12:29 PM
Bond 007's Avatar
Quoted: 2376 Post(s)
Liked: 1914
Just got my replacement for the refurb H1 with the cracked screen.
Its appearance is not like new but I would consider it very good and it seems to function like new.
They gave me a partial refund too. Very happy for $70.
Bond 007 is offline
Old 01-30-2017, 09:44 PM
49Merc's Avatar
Quoted: 342 Post(s)
Liked: 73
Ultimate One Does Not Perform As Well From A Short Distance
Just moved our AV stand with all components to a new, closer to us position in our living room. Now with the AV closer my Ultimate One does not always connect with each component. It's performance with the AV further away was flawless. This seems odd. Any suggestions?
LG OLED 55EG9100 HDTV, DirecTV HD DVR Genie HR44, DirecTV AM21 OTA Receiver, Sony BDPS6500 Blu-Ray, Bose Soundtouch 130 HTC (Sound Bar), Panamax MR5100 Power Manager, Harmony Ultimate One Remote, Monoprice AV Cables
LG OLED 55EG9100 Calibrated by Best Buy Geek Squad
49Merc is offline
Old 01-31-2017, 05:20 AM
Sgooter's Avatar
Quoted: 107 Post(s)
Liked: 87
Is there something between where you're sitting and the new location of the AV stand, such as a coffee table? If so, consider buying a small convex mirror (a common/cheap auto accessories item), and place it where it can reflect/spread the remote's IR beam toward your AV stand. I did this several years ago for the in-laws by mounting the sticky-back mirror on the bottom of a ceiling fan in their family room; works perfectly.
Please enter password to view this signature.
Sgooter is offline
Old 01-31-2017, 06:20 AM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
Besides something blocking the IR as Sgooter noted, it could also be the angle your hitting the components at, which may be more severe with components now placed closer to you. The IR sensor for my last receiver was recessed a good bit back behind the front glass panel that had a small hole in it's black backcoating for the IR sensor. With the IR sensor set a bit back from that hole/window, you had to hit the IR window almost straight on for it to be able to see the remote. May not be your problem, but thought I should at least mention it as a possibility.
Commercial AV Design Engineer, CTS-D Certified
TWC-Charlotte, 8640HDC/ODN 8.0.0_21
jcalabria is offline
Old 01-31-2017, 06:41 AM
49Merc's Avatar
Quoted: 342 Post(s)
Liked: 73
No, nothing in between.
49Merc is offline
Old 01-31-2017, 06:43 AM
49Merc's Avatar
Quoted: 342 Post(s)
Liked: 73
You may have confirmed my first thought. Would blasters help?
49Merc is offline
Old 01-31-2017, 09:46 AM
jcalabria's Avatar
Quoted: 133 Post(s)
Liked: 104
When I had the problem, I picked up a relatively cheap IR repeater system from Amazon, and used the IR emitters for some other devices that were located in the back of the wall unit, but ended up hard wiring one of the repeater outputs to the IR IN connection on the back of the receiver.
THIS is the unit I purchased back in '09... still works fine (there are some similar units on Amazon now for $10-15 less, but I have no experience with them). As I said, mine was hard wired to the receiver I had at the time and all of the other devices were inside or behind the wall unit, so I had none of the emitter bugs visible.
49Merc likes this.
Old 02-04-2017, 04:08 PM
guitarguy316's Avatar
Quoted: 709 Post(s)
Liked: 248
Just got a harmony elite. I have Directv and on my harmony one I could hold the page up or down button to keep scrolling on the TV guide. Is there a setting somewhere on the elite to have this same functionality?
Never mind. Had to change what long press does on the page down button in settings.
guitarguy316 is online now
Old Today, 07:11 PM
shimonmor's Avatar
When I press the "off" button on my H1 remote, I do not want it to turn off a certain device (WeTek Hub). I went to device>settings>adjust power settings and selected "I want to leave this device on all the time" but it stills turns off when I press the "Off" button. How can I get the H1 to leave this device on all the time and never apply "power toggle" to this device?
-Shimon
shimonmor is online now
Harmony 880 Advanced Universal Remote , Logitech
