Harmony 890 & light dimmers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 57 Old 01-04-2008, 10:52 AM - Thread Starter
Artcon's Avatar
've been looking at these dimmers TechnoHome.ca - Z-WAVE DIMMER 800-WATT 3 WAY #1137 - ZDW103W WHITE and would like to have 4 separately controlled by the 890.
Does anyone have experience with this type of dimmer or can recommend a place to look?
I don't need 3 way but haven't found a good alternative.
I need minimum 450 watts per dimmer.
Can a person control 4 separate switches with the 890?
Bob
Artcon is offline
post #2 of 57 Old 01-04-2008, 04:57 PM
BellyRat's Avatar
Funny....I was wondering the same thing. I am thinking about buying the 890 remote. I need the RF because my A/V equip is in a closet. However I want to run 3 seperate dimmers in the room. So my question is two fold. First, like Artcon I am wondering if the 890 will run 3 separate dimmers? Second, because my dimmers are in LOS can I get the cheaper IR dimmers (Lutron Maestro IR 600W-Dimmer with Infrared Receiver) and control them with the IR of the 890 or do I need to buy the more expensive Z-wave dimmers. Thanks in advance for your help!
BellyRat is offline
post #3 of 57 Old 01-05-2008, 05:36 AM
Maverickster2's Avatar
As for the second question, the 890 won't do both IR and RF simultaneously, so z-wave it is. I don't know the answer to the first question, but am also interested.
--Mav
Maverickster2 is offline
post #4 of 57 Old 01-05-2008, 08:17 AM
joeo's Avatar
HI,
I have 2 ZDW120 600 Watt Zwave Dimmer Switches working with a 890Pro.
I am a newbie with the 890PRO.
Best Regards,
Joe O
joeo is offline
post #5 of 57 Old 01-05-2008, 08:59 AM
bryansj's Avatar
Quoted: 1301 Post(s)
Liked: 619
--Mav
I've never heard of the 890 not doing IR and RF simultaneously.
The 890 can output RF to the base and IR from the remote. It just depends on how you set up the devices in the software. If you don't set up the IR light switches to be controlled by the RF base (which you won't) then the 890 will output IR straight from the remote.
bryansj is online now
post #6 of 57 Old 01-06-2008, 06:04 AM
That would be news to my TV. I had originally set up the software to have the TV controlled via IR and the rest of it RF, but that didn't work. I had to run a separate IR Blaster through the wall to the Wireless Extender in order for it to be controlled by my Harmony simultaneously with my various components in the cabinet. It's my understanding that the reason for this is that once you pair it with an RF Extender in the System Options on the remote's soft screen, it disables the IR. Of course, my remote could be unique.
Does yours do both IR and RF simultaneously?
post #7 of 57 Old 01-06-2008, 11:24 AM
mauiguy100's Avatar
I run my 890 pro with rf and ir. in fact if you look at the screen it has a red icon at top when it transmits ir and a white icon when it sends rf.
mauiguy100 is offline
post #8 of 57 Old 01-08-2008, 01:44 PM
bryansj's Avatar
Liked: 619
Originally Posted by SaltiDawg View Post
I'm setting up my new 890 PRO (replacing an older 680 Harmony.)
Just ordered my FREE Zwave module - you pay the $12.41 Shipping. I went to Zwave.com and saw the offer - sent Zwave Cusatomer Service an E-mail saying I had the receipt but Logitech hadn't given my a Coupon number when I registered it. In their reply they gave me the Code - HAR100 . No proof-of-purchase needed.
Could you double check that website address?
post #9 of 57 Old 01-08-2008, 02:31 PM
bryansj's Avatar
Liked: 619
Looks like I don't qualify since I didn't buy mine through Logitech.
post #10 of 57 Old 01-10-2008, 03:43 PM
Andy Evans's Avatar
Just ordered my FREE Zwave module - you pay the $12.41 Shipping. I went to Zwaveproducts.com and saw the offer - sent Zwave Customer Service an E-mail saying I had the receipt but Logitech hadn't given my a Coupon number when I registered it. In their reply they gave me the Code - HAR100 . No proof-of-purchase needed.
EDIT: Corrected www address
You're talking about the "890 PRO", correct, not the basic "890"? I thought the "890 PRO" was only available through custom installers.
Update: I saw your later post saying you got it from Amazon. I see Crutchfield has a listing via Amazon.com, but I wonder whether that really is an 890 Pro - i.e. the black version (that's what their picture shows, but that's no guarantee!), with the 2 extra keys that the 890 doesn't have, and no RF extender included?
Andy Evans is offline
post #11 of 57 Old 01-10-2008, 04:35 PM
BellyRat's Avatar
ok...so now I know alll about the price of the 890 and the discounts....I appreciate the info...can anyone answer the original question....will the 890 control multiple dimmer switches? Do you have to use Z-wave dimmers or can you use the cheaper IR switches? I want to be able to start a movie and dim/shut off several different lights (spots, sconces and rope) all at once....is this possible with this remote?
BellyRat is offline
post #12 of 57 Old 01-10-2008, 10:15 PM
BEAR-AvHistory's Avatar
I had originally set up the software to have the TV controlled via IR and the rest of it RF, but that didn't work. It's my understanding that the reason for this is that once you pair it with an RF Extender in the System Options on the remote's soft screen, it disables the IR. Does yours do both IR and RF simultaneously?
I have a large wall unit & my Samsung widescreen is out in the open & all the other components are inside the wall unit.
The TV is IR controlled & all the other units are RF controlled through a blaster & a PS3IR running off the blaster for a PS3 Bluetooth.
Was a straight setup of the 890 using the Logitech online software.
BEAR-AvHistory is offline
post #13 of 57 Old 01-11-2008, 03:47 AM
SaltiDawg's Avatar
Originally Posted by BellyRat View Post
ok...so now I know alll about the price of the 890 and the discounts.... ...
You're absolutely right. Sorry, Artcon. I deleted my off-topic posts.
SaltiDawg is offline
post #14 of 57 Old 01-11-2008, 02:43 PM
SaltiDawg's Avatar
Andy,
I actually got my 890 PRO from Crutchfield. The Amazon link connected to Crutchfield but there was a sales incentive that caused me to chose Crutchfield directly and also made the Hijack Police get riled.
I just set up my two HA03 Lamp Modules in my living room - each can be controlled independent of the other or they may be teamed as a pair. (The number of lamps/devices that may be controlled is apparently limitless.)
The setup was easy, except I could not get the lights to come back on if I turned the system off directly following viewing a BD or DVD. Customer Service from Canada to the rescue. Those guys are good.
post #15 of 57 Old 01-12-2008, 08:49 AM
chucky08016's Avatar
Guys,
Yes, the 890 and the pro can control multiple Z-Wave dimmers. I have a total of 6 dimmers connected to the 890...
(2) Intermatic HA03C - Z-Wave Lamp Module
(4) Leviton RZCZ1-1LX - Vizia-RF 1-Zone In-Wall Controller
3 more HA03C's are going to installed for the star ceiling, ceiling rope light (indirect lighting), and walkway lights.
The HA03C's control the Berkline LED cupholders. (1) RZCZ1-1LX is in the equipment room and the other 3 are in the theater itself. Once programed to your remote, you can control them individually or together as "scene".
Example: When I go into the theater I turn on the main lights by physically pressing the switch for the main lights. While the main lights are on, if I goto RF controls on the 890 and press a scene I configured called "Movie Time", the main lights dim to off, the directly above the seating dim on to 50%, and the equipment room light turns on... ALL at the same time.
Really easy to configure.
chucky08016 is offline
post #16 of 57 Old 01-12-2008, 10:31 AM
lseguy's Avatar
As stated above, the 890 can control multiple dimmers simultaneously and individually. Its totally up to you.
as an FYI, if you search on Ha03C, you can find them on ebay for a really good price. New.
lseguy is offline
post #17 of 57 Old 01-12-2008, 12:13 PM
blefadts's Avatar
Free Zwave Lamp Module Use Promo Code HAR100 www.zwaveproducts.com
blefadts is offline
post #18 of 57 Old 01-12-2008, 01:17 PM
SaltiDawg's Avatar
Of course!
post #19 of 57 Old 01-12-2008, 04:27 PM
BellyRat's Avatar
Thanks Chucky
BellyRat is offline
post #20 of 57 Old 01-14-2008, 04:18 AM - Thread Starter
Artcon's Avatar
Thanks guys,
I am assuming that the 890 will control the in wall switch directly and no other base controller is required, is this correct?
Bob
Artcon is offline
post #21 of 57 Old 01-14-2008, 04:38 AM
VTPete's Avatar
Quoted: 16 Post(s)
Guys,
I had never heard of z-wave until now. I use some RF based Zenith products I purchased at home depot for light control. (Heath/Zenith) They go by the name "wireless command".
IE: http://www.homedepot.com/webapp/wcs/...ctId=100031603
I don't suppose they're any way of knowing if the 890 support these, is there? I downloaded the Harmony software, but it won't let me do anything without a device connected.
-Pete
VTPete is offline
post #22 of 57 Old 01-14-2008, 07:53 AM
Originally Posted by Artcon View Post
Thanks guys,
Bob
That's correct. It's a very simple install and configure.
post #23 of 57 Old 01-14-2008, 07:58 AM
Originally Posted by VTPete View Post
Guys,
-Pete
The H890 will only control Z-Wave based products. I don't think that the Zenith products that you are using are Z-Wave... it would have said so. Good news is that you can dump the ones that you currently have and buy the Intermatic HA03C - Z-Wave Lamp Module and use that with the H890. They can be picked up at your local Lowes center.
post #24 of 57 Old 01-14-2008, 12:13 PM
VTPete's Avatar
Quoted: 16 Post(s)
Thanks Chucky!
Actually, I'm happy with my light controls because I have a set of "his and hers" remotes that I don't mind being separate from all of my AV stuff. "His" controls the house lights and his chair's spot, and "hers" controls the house lights and HER chair's spot. So, honestly, I don't NEED the lights controlled by a single remote. It just is good to know there's NO reason to spend the extra cash now. THANKS!
VTPete is offline
post #25 of 57 Old 01-15-2008, 04:28 PM
Sucubus's Avatar
Andy,
I actually got my 890 PRO from Crutchfield. The Amazon link connected to Ctrutchfield but there was a sales incentive that caused me to chose Crutchfield directly and also made the Hijack Police get riled.
SaltiDawg, how do you get your lights to come back on after exiting an Activity?
I would like to actually do the opposite: turn lights off when I exit any TV viewing activity.
I am very interested in your answer. I have an 890 with a Z-wave compatible lamp module.
Sucubus is offline
post #26 of 57 Old 01-16-2008, 10:48 AM
SaltiDawg's Avatar
Originally Posted by Sucubus View Post
SaltiDawg, how do you get your lights to come back on after exiting an Activity? ...
I said:
"The setup was easy, except I could not get the lights to come back on if I turned the system off directly following viewing a BD or DVD. Customer Service from Canada to the rescue. Those guys are good."
Again, I was unable to get the lights to turn on if I hit the master "Off" button at the center top of the 890 PRO while watching a DVD with the lights off. I would not be able to turn the lights Off if I pushed the master 'Off" button either.
To turn the lights off after leaving any individual activity to go to another:
From the Home Page, click on Modify Settings. Now Click on Modify Scenes.
Click on Map Scene to Activity.
Again, call Logitech if you want a Scene to occur when you hit the Main Power Off button - I don't know how to do it, but they do!
post #27 of 57 Old 01-17-2008, 03:20 AM
gsulliva's Avatar
Really? Don't see them on the Lowes website.
gsulliva is offline
post #28 of 57 Old 01-17-2008, 06:00 AM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
hey guys I entered my code on the zwave products website, and it gave me a 40 credit but when I look at my final price it says
Sub-Total: $40.00
Shipping: $0.00
Tax: $0.00
Discount Coupons (HAR100): -$40.00
Total: $123.90
where the hell is it getting 123.90 from
space2001 is offline
post #29 of 57 Old 01-17-2008, 06:25 AM
Sucubus's Avatar
Shipping...
Ship it to someone in the US and let them re-ship it to you.
May cost 10 to 15$.
Sucubus is offline
post #30 of 57 Old 01-17-2008, 07:38 AM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
wow 123.90 for shipping are they insane.
Reply Remote Control Area
