Nevo Q50 Owners Thread - Page 27 - AVS Forum | Home Theater Discussions And Reviews
post #781 of 808 Old 05-25-2011, 11:23 AM
AngelEyes's Avatar
Originally Posted by progprog View Post
Do you have the option to learn them, say from a Pronto?
I am afraid not, no remote just the IR receiver and the PCF. I really thought I could work it out
Adam
AngelEyes is offline
post #782 of 808 Old 06-26-2011, 10:43 AM
NeSerge's Avatar
Hi
My client, who is set Nevo Q50 and Nevo Connect - Nevo Connect is behind the sofa, at a distance of 3 meters - in the line of sight. After 6 months, there were complaints about malfunctioning remote control. I came to update the firmware in the remote and Nevo Connect, a month later the client had the same complaint. I took the remote and Nevo Connect and the home they normally worked for me a week when I installed the client again, there were problems: during the macro periodically displays an exclamation point in a triangle. Again I took the console in my home - I have OK.
Help if someone encountered this problem.
Thank you, sorry for bad English.
NeSerge is offline
post #783 of 808 Old 06-26-2011, 02:59 PM
TWilly's Avatar
Does he have a baby? I see this almost exclusively when there is a baby monitor using the same spectrum as Z-Wave
TWilly is offline
post #784 of 808 Old 06-26-2011, 09:02 PM
NeSerge's Avatar
The room in which the AV system is in the basement. It is far enough from the children's rooms. Other Z-Wave devices I have not seen it.
NeSerge is offline
post #785 of 808 Old 06-27-2011, 06:19 AM
TWilly's Avatar
I'd bet you're getting interference from the monitor. Try having them unplug it for several hours and see what happens.
TWilly is offline
post #786 of 808 Old 06-27-2011, 01:39 PM
NeSerge's Avatar
Thanks, I'll try to do so.
Another take another Nevo Connect, will try to replace it. As reported on Friday.
NeSerge is offline
post #787 of 808 Old 07-01-2011, 12:26 PM
NeSerge's Avatar
Hi,
Replaced by new Nevo Connect - worked. Tested for about an hour - still a rare disconnection, it was 3 times.
TWilly, thanks for the tips. Monitor near there. We agreed that perhaps someone in the house next door set gsm repeater.
NeSerge is offline
post #788 of 808 Old 08-10-2011, 11:15 PM
ddarche's Avatar
AngelEyes - there is a lot of other traffic in this thread - so in response to your need to put Pronto hex commands into a Nevo file:
It is a bit tedious but you should be able to copy and paste each command into your NevoStudioPro file, for that particular device. Most pronto commands will work in Nevo. I recognize your post is from months ago and maybe you figured it out.
I think you can create a new device in NSP3 and then start adding commands manually and copy and paste the hex into each command.
Dave
RemoteQuest.com
Adam
ddarche is offline
post #789 of 808 Old 09-20-2011, 06:16 PM
Couchrack's Avatar
Has anyone seen a .net not loading error on the S70? It says that it can't find the storage card and to reload .net. It shows up on the loading screen. This happened after the remote ran out of battery (kids unplug the cradle).
Any help would be appreciated. I did get this from a dealer and I do have Nevo Pro 3.0.
Couchrack is offline
post #790 of 808 Old 12-22-2011, 04:50 AM
drogot's Avatar
I have several brand new(unopened) q50s I bought as backup to my ht remote several years ago. They have sat comfortably in a closet till now. I no longer feel the need to keep these. Anyone interested in purchasing one or more (make an offer) please pm me.
drogot is offline
post #791 of 808 Old 01-01-2012, 02:29 AM
AngelEyes's Avatar
Quick question, should the buttons be backlit? I am assuming so but can't remember... Doh! IIRC the motion sensor should activate the backlight?
I could be looking at purchasing one of those spare remotes if you still have them?
Adam
post #792 of 808 Old 07-23-2012, 09:55 PM
ddd9's Avatar
Does anyone have the NevoStudio Pro software? I have a remote but can not find the software download for it anywhere online. I understand that people are supposed to go to a dealer but I would honestly love to tinker with it myself, I love gadgets and the computer tech stuff. Any help would be much appreciated. These remotes are awesome!
ddd9 is offline
post #793 of 808 Old 03-19-2013, 04:20 PM
AngelEyes's Avatar
Has anyone tried using Nevo Serial control with a recent Marantz Receiver/Pre?
I can't seem to get it to work and am wondering if the Hex code is incompatible with Nevo, e.g.
Mute On 0000 0071 0000 0022 0020 0020 0020 0020 0020 0020 0040 0020 0020 0020 0020 0020 0020 00A1 0020 0020 0020 0040 0020 0020 0040 0040 0040 0020 0020 0020 0020 0020 0020 0020 0020 0020 0020 0AAB 0020 0020 0020 0020 0020 0020 0040 0020 0020 0020 0020 0020 0020 00A1 0020 0020 0020 0040 0020 0020 0040 0040 0040 0020 0020 0020 0020 0020 0020 0020 0020 0020 0020 04B0
Mute Off 0000 0071 0000 0020 0020 0020 0040 0040 0040 0020 0020 0020 0020 0020 0020 00A1 0020 0020 0020 0040 0020 0020 0040 0040 0040 0020 0020 0020 0020 0020 0020 0020 0020 0040 0020 0AAB 0020 0020 0040 0040 0040 0020 0020 0020 0020 0020 0020 00A1 0020 0020 0020 0040 0020 0020 0040 0040 0040 0020 0020 0020 0020 0020 0020 0020 0020 0040 0020 04B0
Most other Hex I have used on my Nevo has been very different, more like this:
Volume Up FF 03 00 01 5A 5E FF
Any help appreciated, thanks!
post #794 of 808 Old 03-19-2013, 04:51 PM
ddarche's Avatar
It has been awhile, so I hope I am on the right track....
Those mute commands are IR commands. You can't use those you need the actual RS-232 serial commands from Marantz
First, you need to add a new device and choose "Add a Serial Device". You cannot use the current device for the receiver that you might have setup for IR previously.
You will need to define all of the codes for the device as serial commands and paste them all into the new device.
Go to the Marantz website and you will need to find your model and then go to downloads and find the doc which tells you the RS-232 specifications/protocol. There are several #'s which you must put into this new device in Nevo Studio Pro such as baud rate, # bits, etc.
Then you need to download the Marantz RS-232 serial codes doc and you will need to start setting those up for the serial device. You may be able to paste them in or possibly import from a spreadsheet or you will be in for a long time of typing each code in by hand. Plus they are cryptic codes and easy to make mistakes, so go for pasting each one in. (I just looked at the Marantz site and they are available in an Excel spreadsheet so you can import or paste them all together into Nevo Studio Pro which should greatly reduce time and effort.) Just import/paste the name of the code and the actual serial code into the import code area of the serial device. You may need to modify the spreadsheet so that the import goes in as Nevo Studio Pro is expecting.
Then you will need to have the NC50 setup for that device as "Data In" on what ever port you have the serial cable plugged into.
A lot of people seems to think RS-232 codes are so perfect and trouble free, which they might be just a little bit but IR usually works just as well and the codes are available and done for you and a few hours less work, for sure. I think they are over-rated actually unless you are having significant issues with the IR codes. Or just have some time on your hands and want to mess with it ;>)
DD
ddarche is offline
post #795 of 808 Old 03-20-2013, 02:14 AM
AngelEyes's Avatar
DD
Thanks, I couldn't find a rs232 spreadsheet for the device I have (AV8801) but there was one for an older model and I have been trying their codes. They appear to be ASCII so I have set the Nevo to that setting:
Power Toggle @ PWR:0 \r
I still don't get any thing happen, NC50 is set to correct in/out so I am a bit stumped.
I found this in the PDF about the RS232 config:
2-2-1-1. Form1: Command
Command is a data that requests some status change.
Start character : ’@’
COMMAND : see “Command list”
End character (CR) : 0Dh
Should I add 0Dh to the end of each command?
So fo the example above:
Power Toggle @ PWR:0 \r0Dh
Or do I add that last string to the 'End Delimiter' box?
Thanks very much for your help.
post #796 of 808 Old 03-20-2013, 07:46 AM
ddarche's Avatar
There are several things with 232 codes deployment:
1. Did you get the baud rate, bit rate, parity and stop bit settings from Marantz and get those in ok in the new device?
2. Are the spaces in their samples? ie: @ PWR:0 (space after @?
3. The command name is not part of the code, just wanted to make sure you didn't have it in there with the code.
4. I would put the CR into the end delimiter box. It is there to help with less code work for every code.
5. You may have to experiment with the form of CR in the delimiter box. I think Nevo offers one on a button which is the \r version. The receiver seems to want the CR to be 0Dh which means 0d in hex form. That's a zero just to clarify, not O. Try converting 0d to hex with a calculator online and put that number in the delimiter box.
6. Lastly you have to figure out what cable for 232 the receiver wants. It may want straight thru or it may want null modem connector on the connector which swaps pin 2 and 3. You may have to call their support for this or it is in the 232 spec doc. I think the Nevo 232 wire is straight thru, meaning pin 2 and 3 are not swapped.
7. Lastly on the NC50 can you just choose in or when chosen, it is automatically the red and green combo circle?
DD
ddarche is offline
post #797 of 808 Old 03-20-2013, 09:03 AM
AngelEyes's Avatar
DD
Hi chaps,
Thanks for all the advice, I managed to get hold of the actual codes for this model from a kind forum member and that solved my problems after a little tweaking with delimiters.
Cheers,
post #798 of 808 Old 01-14-2014, 10:15 AM
ruva's Avatar
Hello,
I just charged my Q50, after a couple of years; I downloaded the NevoStudioPro latest release, hoping to set it up for my newly changed components.
I was hoping to make it learn a few commands from a couple of remotes, but I completely forgot how did it work.
Can someone refresh my memory, if possible ? I don't feel like trying to download ccf, nvj, nvo, pcf, etc. etc....
thanks,
Ruva
ruva is offline
post #799 of 808 Old 04-10-2014, 09:09 PM - Thread Starter
sharkshark's Avatar
crap... my (spare) Q50 has a cracked screen, and despite taking it apart and checking all ribbons the calibration is way off. I did the setup calibration and the arrows would never stop circling, looks like it's pooched.
So, anybody with a spare one they've got lying in a cabinet somewhere? I'd like one as a backup, I adore this remote and don't want to have my primary one die suddenly and not have a replacement.
sharkshark is offline
post #800 of 808 Old 04-11-2014, 06:49 AM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
fmzip is offline
post #801 of 808 Old 04-11-2014, 10:50 AM
lovebohn's Avatar
I have one that is just collecting dust. I bought it awhile back tried to program things and just ran out of time to mess with my HT with two young kids. Like new and never really used I just have never put it on ebay yet. PM me if your interested.
Dave
lovebohn is offline
post #802 of 808 Old 04-11-2014, 05:05 PM - Thread Starter
sharkshark's Avatar
cheers, thanks guys... yeah, I saw the Ebay ones, amused that some seller clearly got a truckload.
post #803 of 808 Old 04-14-2014, 10:48 AM - Thread Starter
sharkshark's Avatar
So, looking for a spare, so if someone does want to get rid of one literally sitting around doing nothing, lemme know. Other option, anyone know if I could actually get a replacement screen for it without too much hassle?
post #804 of 808 Old 04-20-2014, 05:12 PM - Thread Starter
sharkshark's Avatar
...hey, anyone know if there's a way of replacing just the screen in a cost effective way?
post #805 of 808 Old 02-28-2015, 11:44 AM
DaveL17's Avatar
Originally Posted by Spacer View Post
Hey everyone:
Just wanted to let folks know that the broken backlight problem is definitely fixable. Mine stopped working about a year ago, and has been bugging me ever since. My battery was finally going, so while I had the unit open, I decided to look into the problem, and it is indeed a “loose connection” issue.
[snip]
Hope this helps others stuck in the no mans land between UEI and an out of business dealer.
This thread was invaluable. Thank you.
Something that I encountered that might help others: with age, the plastic may have become brittle. I had two screw posts (the ones that hold the base to the front), one snap tab on the side, and the ribbon cable lock (under the battery) all break on me. And I was very careful.
Super glue and electrical tape to the rescue and I'm back in business.
Dave
DaveL17 is offline
post #806 of 808 Old 10-28-2015, 01:13 PM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
I have a Q50 remote in which the touchscreen isn't working, ie no touch commands, its illuminated just doesn't perform any functions. I am wondering if it's the screen or the board that it plugs into.
If someone needs a Q50 for parts, let me know
fmzip is offline
post #807 of 808 Old 12-23-2015, 05:06 PM
fmzip's Avatar
Quoted: 47 Post(s)
Liked: 102
Anyone have experience using a Nevo Connect as a secondary controller with Vera?
I got the remote to function and controller Z-wave devices but it can't find my Nevo connect.
I tried adding the Nevo Connect like i add any other Z-wave device to the Vera with no luck. Any Z-wave gurus out there??
fmzip is offline
post #808 of 808 Old 01-15-2017, 02:27 PM
Liked: 0
I know this is old and it's been a while since i add my Nevo devices to Vera. I believe i added the Nevo Connect by pressing the button on the NC-50 and then adding a generic zwave device to Vera. It shows up and also a "1" and "2" show up for the two ir emitters. Now I wish I could send zwave command from Vera to control the TV through the ir emmiter.
dmacias72 is offline
Reply Remote Control Area
