Please help me adjust my HDTV for the best result when gaming with the PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-04-2012, 11:11 PM - Thread Starter
SeriousAccount's Avatar
I own a 32" Sony Bravia 1080p LCD HDTV
The model number is: KDL - 32S5100
Here's is its standard factory setting:
Back light: 8
Picture: 80
Brightness: 50
Color: 50
Hue: 0
Color Temperature: Neutral
Sharpness: 15
Advance Contrast Enhancer: Medium
Gamma: Low
Clear White: Off
Live Color: Low
Should I stick with the factory setting?
SeriousAccount is offline
post #2 of 3 Old 08-25-2012, 09:03 AM
NextGen's Avatar
Throw LCD in trash
Purchase a Sony crt with super fine pitch tubes
Disable all enhancements in the service menu (I have a list of settings)
Set sharpness to 0
Turn off velocity scan modulation
Use component cables not HDMI
Set proper grayscale
Set primaries and secondaries
Do a precision focus adjustment
Hire a tech, if needed, to fix convergence with magnets
On the ps3 set picture to limited with the super white level set to on
Optionally.
Replace components with military grade parts
Or pick up a crt projector
NextGen is offline
post #3 of 3 Old 08-31-2012, 06:57 AM
darthrsg's Avatar
Location: Barrel of Burning Trash On A Cold Skid Row Street
Quoted: 2325 Post(s)
Liked: 2868
OR take a look through here:
http://www.avsforum.com/t/1335891/official-sony-kdl-32bx420-40bx420-46bx420
I know it's not the same set but it will give you something to do this weekend.
darthrsg is offline
Reply Home Theater Gaming
