HD component video splitter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-06-2012, 09:53 AM - Thread Starter
mfurniss's Avatar
I would like to split the component signal from my Xbox 360 to a tv and a projector.
Does anyone know of a splitter that actually works for this?
mfurniss is offline
post #2 of 3 Old 11-10-2012, 07:53 AM
freekmccoy's Avatar
I'm trying to do this also..
freekmccoy is offline
post #3 of 3 Old 11-14-2012, 06:32 AM
ToneCmdr's Avatar
I bought a component switch with 2 outputs many years ago but It doesn't look like anyone makes these any more. Monoprice carries component splitters but I've never used them so I can't tell you if they would degrade your video signal.
There's a very inelegant way of switching where you output your signal to. You could attach a component coupler to the component cable coming out of your Xbox. Run component cables from your TV and your projector and hook them up according to which display you want to use. It's a pain but it works.
ToneCmdr is offline
Reply Home Theater Gaming
