HDMI switches for both XBOX and PS3 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-10-2012, 08:46 PM - Thread Starter
helljumper117's Avatar
Im after one but i heard some of them dont work with the xbox and ps3...what features do you have to look out for? Heres the features of a cheap one on ebay:
Features:
Support HDMI 1.3b.
Full HD 1080P.
Support 12-bit deep color.
High performance up to 2.5Gbps.
No power needed.
Multifunction on switching: intelligent or mechanical.
It is compatible well for HD-DVD, SKY-STB, PS3, Xbox 360, etc.
Maintain high resolution video-beautiful, sharp HDTV resolutions up to 1080p, 2k, 1440p graphics and computer resolutions up to 1920 * 1200 are easily achieved.
Specifications:
Input DDC Signal: 5 volts p-p(TTL)
Output Video: HDMI 1.3b
Maximum Single Link Range: 1920 * 1080p
Vertical Frequency Range: 50/60Hz
Video Amplifier Bandwidth: 2.5Gbps/250MHz
Resolutions: 480i, 480p, 576i, 576p, 720p, 1080i, 1080p
Operating Temperature: 0â to + 70â
Operating Humidity: 10% to 85% RH
Storage Temperature: -10â to + 80â
Storage Humidity: 5% to 90% RH
Item size: 6.5 * 6.5 * 1.5cm
Item weight: 39g
The feature that throws me off is that it only supports 12 bit deep color...will xbox and ps3 be compatible with a hdmi switch with these features?
http://www.ebay.com.au/itm/3-Port-1080P-HDMI-Switch-Switcher-Splitter-HDTV-PS3-DVD-/230675879239?pt=AU_Television_Accessories&hash=item35b55a9547#ht_3202wt_977
helljumper117 is offline
post #2 of 2 Old 12-07-2012, 08:51 AM
MooN77's Avatar
I purchased mine off Monoprice. Nice little unit that came with a remote, although I have the Harmony One programmed for it. It works well switching between my FIOS box, PS3, and Bluray player. I don't have a Xbox, but I don't see why it wouldn't work with one.
http://www.monoprice.com/products/subdepartment.asp?c_id=104&cp_id=10113
MooN77 is offline
Reply Home Theater Gaming
