Panasonic st50 or Samsung UN50ES6500 for gaming/movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-07-2012, 05:22 PM - Thread Starter
gamingzone6912's Avatar
I am mostly going to be doing gaming on this tv however there will be times of watching movies and sports on this tv. Iplay all sorts of games so i want a fast tv with low input lag the panasonic seems good however it requires 100 + hours of break and the led i can just plug and play. please help me decide, if you have personal experience with these please share your thoughts. Thanks in advance
http://www.amazon.com/Samsung-UN50ES6500-50-Inch-1080p-120Hz/dp/B0077SBPPM/ref=pd_ybh_6
http://www.amazon.com/Panasonic-VIERA-TC-P50ST50-50-Inch-Plasma/dp/B00752VKW8/ref=pd_rhf_dp_p_t_3
gamingzone6912 is offline
post #2 of 3 Old 10-24-2012, 05:25 PM
gomess023's Avatar
Personal preference both has great input lag results. Samsung needs to be on pc mode to handle lag better st50 game mode will do and even custom mode is good. Panny is brighter with better blacks. Samsung handles ir a little better. It's personal preferences. I personally will go
For the st50
gomess023 is offline
post #3 of 3 Old 11-25-2012, 12:41 AM - Thread Starter
awesome thanks for the info i will hopefully be getting mine in a week or two. How did you or would you go about breaking in the st50
Reply Home Theater Gaming
