Need help connecting Wii - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2013, 04:09 PM - Thread Starter
dasaboros's Avatar
I just bought a Sony STR-DH520 receiver and am trying to connect my Wii to it so we can have it thru the system. The PS3, XBOX, Cable are all connected and work fine (I saw a couple suggestions I'm going to try though for max performance on these forums already). I am attempting to book the Wii up via component cables. I hook them into the input and the audio into the input. I get the audio on the SA-CD/CD input, but no picture. I read thru the manual and it says go thru menu to this setting do this that....etc. I try to do and think I'm doing what the manual says, but to no avail. Thanks to any help I receive in advance. I really do appreciate it!
dasaboros is offline
Old 04-22-2013, 02:30 PM
davidinskem's Avatar
hi there
did you manage to connect it as I am having the same problem
cheers
david
davidinskem is offline
