Will this cause additional input lag? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-06-2013, 08:55 PM - Thread Starter
theaero's Avatar
http://www.amazon.com/ViewHD-1080P-Output-Upscaling-Converter/product-reviews/B0050RKH2Y/ref=cm_cr_pr_hist_1?ie=UTF8&filterBy=addOneStar&showViewpoints=0
Using my wii at 480p causes much more input lag on my e6500 than a 1080p source. Does anyone know if this unit adds additional input lag? I'd like to use an HDMI input so I can use the PC-label trick to get 16ms input with my e6500. Right now, using the composite cables from my wii to my e6500, the input lag is unbearable.
Thanks!!
theaero is offline
post #2 of 3 Old 02-07-2013, 11:39 PM - Thread Starter
theaero's Avatar
Bump. Can't seem to find an answer anywhere.
theaero is offline
post #3 of 3 Old 02-11-2013, 12:09 AM
darklordjames's Avatar
Liked: 94
I would trust your display to do a much better quality job of scaling 480p to 1080p than a $20 dongle. Simple internal scaling should not cause much lag. Does 480p over HDMI also lag as bad at 480p over component? For example, if you set your Xbox 360 to 480p instead of 1080p over HDMI, is it measurably slower when doing a Rock Band 2 auto-calibration?
At a minimum this thing will likely add 16ms of additional lag to capture a frame for HDMI transcoding. You could probably expect another 16ms for scaling and transmission. A simple 480p Wii2HDMI dongle is more likely to be in the 16ms range, but really none of these things are designed with lag in mind. They much more of a convenience item.
Order one from a retailer with a great return policy and find out.
darklordjames is offline
Reply Home Theater Gaming
