Ned help with GPU choice. - AVS Forum
post #1 of 3 Old 02-17-2013, 06:25 AM - Thread Starter
steved1961's Avatar
My new all in one machine, Home Theater, Gaming and general all around machine. Need some help choosing my video card. I received the case from my kids for Christmas (It limits me to 10.5 (266 mm) for my graphics card).
System:
Antec One
Corsair TX750M
Intel Core i5-3570K
Asrock X77 Extreme 4
G.skill F3-1600C8D-8GAB
Intel SSD 330 Series 120GB
Seagate Barracuda 3TB 7200RPM (2X Total of 6TB)
Windows 8 Pro
Two graphics cards that will fit.
EVGA 670 FTW 02G-P4-2678-KR (10inches)
Powercolor AX7970 3GBBD5-2DHV3 (10.5 inches)
My gaming is done at 1920x1200 at the present but at some point I will get a higher res monitor. Mostly I play FPS. I use a Samsung 55 LCD for movies and TV. I will be gaming on only one monitor and I generally use XBMC for Home Theater duties. I'm leaning towards the 7970 ($20.00 cheaper and free games) at the moment unless someone came tell me the 670 is a better choice in my case. Any advice or options are appreciated.
steved61
steved1961 is offline
post #2 of 3 Old 02-20-2013, 09:15 PM
darklordjames's Avatar
Liked: 93
670. Better drivers give you a better user experience over the life of the product. Going with the 7970 saves you $20, but buys you headache.
darklordjames is offline
post #3 of 3 Old 03-19-2013, 04:48 AM - Thread Starter
steved1961's Avatar
Went with the 7970 so far no problems. Speed is great and image quality is excellent. No more annoying micro stutter playing MKV files.
SteveD61
Reply Home Theater Gaming
User Tag List
