Need Help PS3- ONKYO or Samsung? - AVS Forum | Home Theater Discussions And Reviews
Old 05-26-2013, 01:12 PM - Thread Starter
Saif258's Avatar
Hey i am looking for a home theatre system,
My basic requirement is using home theatre for GAMING and MOVIES!
I hav Ps3 and Xbox 360 which i use,
I want a home theater which i can connect both of them and PC too sometimes, and get Dolby digital and DTS and true HD in movies and in games smile.gif
However i am confussed which one is good for me
Options:
Onkyo HTS3505
or
Samsung HT4550K
or
Samsung HT5550W
Also its good to have tall speakers smile.gif but what is main is audio smile.gif
Saif258 is offline
Old 05-26-2013, 03:48 PM
tlalotoani's Avatar
Quoted: 20 Post(s)
Liked: 37
I don´t know how the Samsung products sound, (neither the Onkyo tongue.gif ), buy I´d go for the Onkyo because you can upgrade the speakers in the future if you want.
The only problem with this Onkyo model is that the Sub woofer is not self powered, wich means that if you want to upgrade the subwoofer it would be a little more difficult to find a replacement. cool.gif
tlalotoani is offline
Old 05-27-2013, 08:21 AM - Thread Starter
Saif258's Avatar
m still confused frown.gif at one end i want those tall speakers of samsung at other end m worried that will those HDMI input get DTS and true HD and dolbby from my ps3 or not frown.gif
Saif258 is offline
Old 06-02-2013, 06:54 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
If you can steer away from a htib setup. Buying an AVR and speakers will result in better sound. Pioneer makes a fantastic low price speaker. Am AVR just needs to have the inputs you need. The speaker thread is a good place to start research. Good luck!
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
