Best headset for chatting while using your HT? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-22-2013, 04:09 PM - Thread Starter
metallicaband's Avatar
Liked: 100
Since this is AVS, I assume many of you game using your home theater setups so using a headphone that covers both ears is pretty much out of the question.
I'm looking for something with these things in mind:
1- Will cover only one ear, would be great if it's transparent enough that would allow me to listen to my surroundings normally from that ear as well.
2- Has excellent noise cancelling so we can crank the volume up without annoying the hell out of your team mates.
3- Comfortable for long sessions
4- Must be On ear, in ear stuff are too annoying
- Price isn't an issue as long as it's worth it
- Wireless is a +, but definitely not a requirement
- Any input method is fine since I chat via Skype on PC, not through consoles, maybe Next gen consoles will be good enough to change that.
I've been using this Logitech Headset since 2009 till it stopped functioning properly recently, it was pretty good, my voice was loud and clear, but the noise cancelling plus earphone transparency could be better.
Any suggestions would be great.
KRP-500M | Kuro 9G 5020FD + e-lite mod | B&W 683 Fronts | B&W 685 Center | B&W DM601 S3 Rears | HSU VTF3 MK3 Sub | Yamaha RX-V663 AVR
metallicaband is offline
post #2 of 2 Old 06-22-2013, 05:41 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
I would think a headset used for telephone conversations would be the best bet. People wear them 40 hours a week at work. My girlfriend had to do this. Noise canceling should be good, bit I imagine this type would be expensive. Good luck, hope someone can help more.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
Reply Home Theater Gaming
