Looking for USB Hub to charger multiple system controllers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-20-2017, 01:34 PM - Thread Starter
Quoted: 331 Post(s)
Liked: 155
Well I looked around and the only posts I found where from about 9 years ago so I started a new one. Situation is simple I have multiple systems, PS4, Wii U, PS3 and Switch. I would like to be able to just get something like a 12 or 15 port powered USB hub and use it to charge all my various controllers in one location. HAs anyone done this? Or does anyone have any suggestions of the best way to go about it like a specific brand hub that works best?
liffie420 is offline
post #2 of 6 Old 03-20-2017, 02:27 PM
lance466's Avatar
Quoted: 47 Post(s)
Liked: 90
Nothing to recommend but I'll throw this out there (although I'm sure you are already aware of this)...
You can charge your controllers using pretty much any USB port. So if you have 2 on your xbox, 2 on your PS, 2 on your Switch, 1 or 2 on your TV, 1 or 2 on your cable box, 1 or 2 on your AV receiver then you might be able to get away with that (clumsy) solution or maybe that can whittle your USB ports needed down a few if you find a really good 4-8 port device to compliment it.
Boredom's not a burden anyone should bear.
lance466 is offline
post #3 of 6 Old 03-20-2017, 02:33 PM - Thread Starter
Quoted: 331 Post(s)
Liked: 155
I would prefer to have them all in one area to declutter a little lol. I thought as long as I got a powered one it should be fine but just wanted to make sure. Between all the systems we have probably 8 to 10 controllers so having them centralized would be nice
post #4 of 6 Old 03-21-2017, 08:22 AM
LexInVA's Avatar
Quoted: 677 Post(s)
Liked: 280
There are 12 port USB hubs with AC adapters, but I do not know if any of them will provide the level of power that you want to have for charging that many devices, let alone several. Anker and other companies make USB charging stations that are designed for that.
LexInVA is online now
post #5 of 6 Old 03-21-2017, 08:39 AM - Thread Starter
Quoted: 331 Post(s)
Liked: 155
See that is kind of what I was worried about, I don't want to spend 30 bucks on a powered usb hub an have it not able to charge the controllers. Granted it would only be charging a few at a time as we don't use all the systems all the time, but it would be nice to have it all in a central location. I also wanted to avoid like the charging stands that hold like 2 controllers since we would need multiple, 1 for each system and those are not cheap. All together I think we have 3 ps4 controllers, with 1 being used regularly, 2 ps3 controllers used with my raspberry pi, and 2 wii u pro controllers. Then later on there will probably be 1 or 2 Switch pro controllers.
post #6 of 6 Old 06-23-2017, 07:30 AM
fishyguy's Avatar
I use one from Anker and it works great. I have 2 xbox one controllers and 2 PS4 controllers. this is the one I https://www.anker.com/products/A2124112
XBR75Z9d,Denon X6300H,OPPO UDP-203
ATV 4, XBOXONE S,PS4 PRO
Original XBOX turned MAGS
fishyguy is offline
Reply Home Theater Gaming
