Logitech Z906 speaker for gaming and bluray players - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-21-2017, 04:25 PM - Thread Starter
Liked: 0
Question Logitech Z906 speaker for gaming and bluray players
I have to connect a Gaming PC (HTPC) and my bluray player to a LED TV with HDMI cables. So I'm thinking Logitech Z906 would be a good solution since it has multiple inputs.... 3.5 mm jack and optical input (I have HDMI to optical output decoder)......
Would it be a good idea? how's the sound quality of Z906 for bluray movies? I have a small living room with distance from couch to TV about 9 feet......
TigerBoots is offline
post #2 of 6 Old 07-23-2017, 03:08 PM
Quoted: 20 Post(s)
Liked: 9
I've had mine for a while and they're great. For the price I think it's hard to beat. We use em for music/bluray/gaming in a 3.1 setup. Sound fills the room easily. Good clarity and balance and great detail when decoding DTS
Can you compare them to my buddy's Mystos STS? Of course not. Don't try. But I think they're significantly better than the Onkyo 7.1 system they replaced.
35mphgolf is offline
post #3 of 6 Old 07-24-2017, 10:03 AM - Thread Starter
Liked: 0
Logitech Z906 better than onkyo 7.1 system? Seriously? I was thinking to use the onkyo home theater package but nobody sells it locally. I have looked around.....
post #4 of 6 Old 07-24-2017, 01:52 PM
Quoted: 20 Post(s)
Liked: 9
Yup. I can't remember the model but it was their top HTIB. Got it on Craigslist and used it for a few years. Sound was soft and bass was non-existent.
The Z906 bass is waaaaay better (I don't mean louder --which it is-- but more range) and the clarity and volume on the Z series is fantastic.
I picked my Z up off Craigslist for $225 a few years ago and haven't looked back! Do I want the Mythos? Yes. Badly. But the Z is absolutely unregrettable for the money.
post #5 of 6 Old 07-24-2017, 10:54 PM - Thread Starter
Liked: 0
To test speakers, I usually use Pearl Harbor (2001) bluray movie. I plugged the Optical cable from the TV to the Active speakers (I have sound science 2.1 speakers now). The sound is actually above average for that cheapo speakers (priced $120). I play the movie with DTS sound. The explosion sound comes out but it's about 50% from what I think should have been. So I need something clear with a better sub for movies like this.
post #6 of 6 Old 07-26-2017, 03:49 PM
Quoted: 20 Post(s)
Liked: 9
Another option is to hookup the optical audio directly to the bluray source if possible (Z has 2 optical inputs)
I have 1 on TV (Sony A1E) and 1 for Bluray (Oppo-203). Blu-Ray sound is waaaaaay better and decodes properly. The TV doesn't decode DTS but the player does...
Spring for the Z - I think you'll love it
Reply Home Theater Gaming
