007 everything or nothing 480p? - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 32 Old 02-12-2004, 10:05 PM - Thread Starter
davez82's Avatar
anyone know if the new james bond game is 480p on ps2?
davez82 is offline
post #2 of 32 Old 02-16-2004, 10:52 PM - Thread Starter
davez82's Avatar
anyone know ? comes out tomorrow i think, so hopefully someone will know by then
davez82 is offline
post #3 of 32 Old 02-17-2004, 07:43 AM
b-florida's Avatar
I'm sure it is. I also saw one review mention it was 16x9. This site is usually good but has no info on it yet... http://www.hdtvarcade.com/xboxlist.htm
b-florida is offline
post #4 of 32 Old 02-17-2004, 07:22 PM - Thread Starter
davez82's Avatar
hm.. anyone got this yet?
davez82 is offline
post #5 of 32 Old 02-17-2004, 08:07 PM
MrSquid's Avatar
I've got a copy coming in from EB on Thursday. I thought I'd seen somewhere that it was widescreen. I'm just hoping it's as good of a game as the reviews made it out to be! Too bad there's no online Xbox play - my reading points only to PS2 online play. :(
Xbox Live ID: MihmsMe
MrSquid is offline
post #6 of 32 Old 02-17-2004, 08:22 PM
dschroll's Avatar
Of course it's online only for PS2. It's made by EA. Right now all EA games are exclusively online for PS2.
dschroll is offline
post #7 of 32 Old 02-17-2004, 09:19 PM
MrSquid's Avatar
Got it - the devil is in the details! Still looking forward to the game though! :D
MrSquid is offline
post #8 of 32 Old 02-18-2004, 12:39 PM
Dean Martin's Avatar
It's 480p.
Dean Martin is offline
post #9 of 32 Old 02-18-2004, 02:40 PM
MrSquid's Avatar
It's 480p? I just played through the opening and the MI6 training - I flipped off of my HD input and then back on, and my set said 480i...
It seems like it's going to be a great game. I was a bit sketchy on the controls, but that's most likely because my wireless Logitech controller came today, so I played with that right away.
That "spider bomb" is going to be awesome! :D
MrSquid is offline
post #10 of 32 Old 02-18-2004, 03:53 PM
eroteme's Avatar
THIS GAME IS NOT 480P . I just picked it up, says 480p on the back of the box, put it in, all it is , is 480i, lm bringing it back and swapping it for the gamecube version which says Progressive Scan (which I hope isn't a lie) . This really turns me off to EA now!!!!
eroteme is offline
post #11 of 32 Old 02-18-2004, 04:30 PM
dschroll's Avatar
If you are playing this game on the PS2 and it's supposed to be in 480p, make sure you look at the instruction booklet on how to enable 480p on it. Typically PS2 games that are in 480p require the player to hold down the X, triangle, square, and circle buttons at the same time when the game is booting up on the PS2....from there it should ask if you want to enable it in 480p.
I'm not sure whether this game is 480p for Ps2 or not, but if it is, you probably need to go through the above procedure. Hope this helps!
dschroll is offline
post #12 of 32 Old 02-18-2004, 05:54 PM - Thread Starter
davez82's Avatar
for those who said it says 480p on the box, is that the ps2 box?
davez82 is offline
post #13 of 32 Old 02-18-2004, 09:06 PM
eroteme's Avatar
My post was in reference to the XBOX version it says 480p on the box, brought it home popped it in and its nothing . All it is is 480i, anyways I exchanged it and got it for Gamecube, it does support progressive scan (my TV lights up 480p) the game seems to be in widescreen (and if its not the images look totally fine in widescreen), so I will be holding onto this title for the NGC this time .
On another note I got the light gun for Silent Scope it works pretty decent on my CRT HDTV . And Silent Scope supports 480p even tho the box does not state it!
eroteme is offline
post #14 of 32 Old 02-19-2004, 06:17 AM
A.C
A.C's Avatar
accoring to IGN, the only version to do 480p is Xbox. but this probably wouldn't be the first time they were wrong.
http://cube.ign.com/articles/490/490225p4.html
XBL: HiFi Buckeye
PSN: hifibuckeye
A.C is offline
post #15 of 32 Old 02-19-2004, 07:33 AM
MrSquid's Avatar
Have any other Xbox players out there notice your set see the screen flicker between levels? (usually during the first step or two when the bond girl transition happens at the bottom of the screen) It's the same type of flicker you get when the set switches from the 480i dashboard to a 480p game...
MrSquid is offline
post #16 of 32 Old 02-19-2004, 09:51 AM
Shok's Avatar
I also got the XBOX version and so far I've noticed that the game is 480i in the 3rd person levels, but the screen flickers and changes to 480p in the driving levels.
Shok is offline
post #17 of 32 Old 02-19-2004, 10:11 AM
I'm totally sorry. I wasn't thinking about the other versions. I should have said XBOX specifically.
As far as the 'flickering' Medal of Honor Frontline also does this.
post #18 of 32 Old 02-19-2004, 11:25 AM
Neo2k2's Avatar
If you have the xbox version try turning off 1080i in the dashboard. That seems to enable 480p. It did for me.
Neo2k2 is offline
post #19 of 32 Old 02-19-2004, 12:00 PM
A.C
A.C's Avatar
can anyone else confirm that the Nintendo version of this game is 480p? asside from eroteme, every source i've seen has stated that the xbox version is the only one with progressive scan.
XBL: HiFi Buckeye
PSN: hifibuckeye
A.C is offline
post #20 of 32 Old 02-19-2004, 12:05 PM
dschroll's Avatar
Yes, the Nintendo version is also in 480p. This is a letter from the GC mailbag on IGN:
Bond Tech
So is 007:EoN 480P & Widescreen on GameCube??
Matt responds: Yes, the game supports both progressive scan and widescreen formats.
dschroll is offline
post #21 of 32 Old 02-19-2004, 12:23 PM
SCSI's Avatar
Thanks a lot Neo. That solve the 480p problem. Work great now on my monitor and HDTV.
You must be the "ONE" :D
Frank
SCSI is offline
post #22 of 32 Old 02-20-2004, 06:50 PM
bickle's Avatar
(Xbox version) I have 480p, 720p, and 1080i enabled, and only the menus are interlaced. On foot & driving sections show up as 480p.
bickle is offline
post #23 of 32 Old 02-20-2004, 10:14 PM
SCSI's Avatar
Bickle, if you disable 1080i on your Xbox as posted by Neo2k2, everything will be in progressive including the menus.
Frank
SCSI is offline
post #24 of 32 Old 02-20-2004, 10:49 PM
MrSquid's Avatar
Yep... that worked for me too!
MrSquid is offline
post #25 of 32 Old 02-21-2004, 07:15 AM
turls's Avatar
Quoted: 465 Post(s)
Liked: 194
Well, that's real brilliant EA. Of course, I can't even get to the screen to disable 1080i without using the menu that is only 480i, so I still need to swap cables on my Sammy DLP.
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is online now
post #26 of 32 Old 02-21-2004, 10:20 AM
NoThru22's Avatar
Quoted: 366 Post(s)
Liked: 169
If you have a Samsung DLP 1080i shouldn't be enabled on your Xbox anyway. My copy of Matrix was really choppy at 1080i and when I disabled 1080 and played at 720, it was much better. Your TV natively supports 720p so if a game supports both, yet plays at 1080 and your TV has to convert it, it won't look as good as just playing 720p.
NoThru22 is offline
post #27 of 32 Old 02-21-2004, 02:58 PM
bitTRL1000's Avatar
I played the Xbox version last night on my Toshiba 57HDX82, and although my TV doesn't say what mode it is in (480p/480i), the picture flickers for a split second when it switches. Like when I play Project Gotham 2, right after the "Xbox" screen goes away and it actually starts the game, there's a flicker. When I play 480i games like Halo there is no flicker. I noticed this flicker when I put in the new Bond. I posted this because I have all the settings enabled (1080i, 720p, 480p) and I seem to get it to run in 480p. I did notice that everything seems to be in widescreen except for the in-game cutscenes. The gameplay, so far of which I have only played on-foot, and the pre-rendered cutscenes seem to be in widescreen.
Joe
bitTRL1000 is offline
post #28 of 32 Old 02-22-2004, 12:33 PM
ArchieGates's Avatar
I think I know why it switches from level to level. It's because EA's internal studio developed the on foot levels, while the Need For Speed Team up in Canada did all the driving levels. So perhaps one of the teams didn't do something right, so the game only plays in 480i (unless you make the dashboard adjustment to 1080i, which seems to force all the levels to use 480p).
Listen to my songs about games at: www.archiegates.com
ArchieGates is offline
post #29 of 32 Old 02-22-2004, 01:42 PM
bickle's Avatar
All levels played in 480p on my Xbox without any adjustment.
-Dave
bickle is offline
post #30 of 32 Old 02-22-2004, 05:59 PM
bickle,
Does your TV display what the input resolution is? Otherwise how would you know it was 480p or 480i? The Bond graphics look pretty good so it's not easy to tell really. I have a Samsung DLP and with the faroujda processor I honestly didn't even realize there was a difference until I read about it here. I shut off 1080i and there was some improvement.
Closed Thread Home Theater Gaming
