X-Box component cables w/optical audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-09-2004, 02:56 PM - Thread Starter
DRG
DRG's Avatar
Hi,
First time poster...
We bought the whole X-Box thing for our kids, and me, for Christmas. It'll be played on new front projection through 5.1 audio.
We were stoked at the purchase point (B--- B-y) and even bought the Component video adapter and an optical audio cable to use with it. The cables were about $100.00 total.
I'm going to try to use the DVD player capabilities to replace an older DVD player in the HT system.
With that in mind...
Can anyone steer me towards a good source for cheaper cables that will fill this need?
I've seen some on E-Bay that would only come to about $18.00. But there was little documentation. I'd rather spend a little more if need be to be confident that they won't be the "weakest link" in the system.
DRG
DRG is offline
post #2 of 8 Old 12-09-2004, 03:20 PM
SCLlama's Avatar
Just go to your local retailer, where you can pick up the new official xbox component cables (not the monster cables). and grab a relatively cheap optical cable. You should be able to get them both for under $50.
BTW, i have both the microsoft and the monster cable component cables and i dont notice any difference. just that the monster one's suck because of their special optical hook-up.
-Ryan
SCLlama is offline
post #3 of 8 Old 12-09-2004, 06:13 PM
oktoberrust11's Avatar
Quoted: 69 Post(s)
Liked: 38
Yes, as Ryan said, go with the Microsoft HD cables. I grabbed mine from Gamestop, they're $20 now. Then, all you'll need is the Toslink fiber optic cable (Monster's is $35, but you can get them for much cheaper). Take them darn expensive cables back!
Matt
Xbox Live: oktober rust | Mii: 5207 2388 9861 4135 | Steam ID: detroit820 | Origin ID: oktoberrust11
oktoberrust11 is offline
post #4 of 8 Old 12-09-2004, 06:45 PM
Jordan420's Avatar
Since you have a new front projection system, do your self a favor and buy a decent DVD player
Jordan420 is offline
post #5 of 8 Old 12-09-2004, 07:43 PM
ChrisFB's Avatar
Liked: 34
Just make sure you don't buy generic Xbox cables that are sometimes seen on Ebay. Get the new version of the MSFT component cables (a 1 piece unit, no breakout box - you'd have a lot of problems finding the older unit). It is every bit as good as the Monster offering and quite a bit cheaper (note that the old version was cheaper but noticably not as good as the Monster offering - at least to a decent percentage of people).
Also, the Xbox DVD player sucks - as someone already aluded to. It is watchable but you wind up with odd color issues (macro), a set limit of 7 IRE, and no 480p output unless you mod and hex edit - and still at 480p the other issues make it suck. The majority of $100 range players will significantly outperform it and you get a lot more control also.
Panasonic 65" VT60 (calibrated by Jeff Meier), Marantz 6005, Kef Q towers/rears Kef Reference center, Win 7 Pro with XBMC, Harmony Ultimate One
Xbox Live: Arbitrage XXL
ChrisFB is offline
post #6 of 8 Old 12-09-2004, 08:16 PM
NoThru22's Avatar
Quoted: 366 Post(s)
Liked: 169
A $35 DVD player is better than the Xbox DVD player.
NoThru22 is offline
post #7 of 8 Old 12-09-2004, 09:12 PM - Thread Starter
DRG
DRG's Avatar
Thanks you guys,
I think that the "X-Box" name brand sounds like the answer. The optical cables can be found easily if they are standard plug-ends.
As for the DVD player, the one I'm using now is a 480i that's about 6 years old. Even though its also 480i I had hoped that the X-Box player would do as well or better just because it is new technology.
I had also read that my projector, a Panasonic AE700U, would deinterlace the picture as well as most "cheap" progressive scan players. And I thought it would be simpler to have one less machine plugged in due to the limited video switching capacities of my A/V Receiver (Panasonic SAXR10) as well as less cables, remotes etc.
I'll probably end up getting a new DVD player but I'll probably wait for the dust to settle from Christmas first.
Thanks again,
Dave
DRG is offline
post #8 of 8 Old 12-09-2004, 09:38 PM
ChrisFB's Avatar
Liked: 34
It's definitely watchable but nothing you want to use long-term if you have a decent setup or have a display that costs more than $300.
ChrisFB is offline
Closed Thread Home Theater Gaming
