9800 Pro out to Sony 32 HDTV in ?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-21-2004, 02:32 PM - Thread Starter
cra2's Avatar
Hello all, just joined.
Alot of info here - a bit overwhelmed.
Can anyone help please? (I'll gladly tip via paypal or amazon)
I have ATI 9800 Pro graphics card
- dvi out, s-vid out, vga out
I want to continue using my monitor, but also run a line out to my tv for watching downloaded movies and image slideshows and screensavers.
The tv is a Sony KV-32HS420 HDTV
- HDMI in, component in, composite in, coax in, RCA in and s-vid in
The only direct connection would be s-video.
But I've read somewhere on here that s-vid would be a low res, crappy image ?
ATI makes an adapter from DVI to component - but I read something about overscanning (cropping) ?
Then there are options like DVI to VGA or RCA or whatever, but then you have to know what resolution you're outputting vs. what resolution your TV can accept, etc, etc.
Does someone else have this same setup working?
If so, what connection? What settings?
thanks,
cra2 "at" mindspring "dot" com
__________________________
Strong Lisa - lisastrong "dot" org
cra2 is offline
post #2 of 8 Old 12-21-2004, 04:34 PM
StreetPreacher's Avatar
Well if you can't use the DVI output on the video card, then your best bet is to pick up the ATI component video adapter (dongle).
It's possible that overscan could be a problem with the default settings, but with some tweaking you should be fine.
Oh, and you shouldn't download movies :)
StreetPreacher is offline
post #3 of 8 Old 12-21-2004, 04:38 PM
chris5977's Avatar
Your TV is not ideal for hookup with a PC, but it wouldn't hurt to try. First off, just go ahead and hook up S-video. If you're perfectly happy with the image, then fine, problem solved.
Your other option would be a DVI to HDMI cable or a VGA to component cable. I have idea if this would work. Let us know what you find out.
PSN Gamertag: chris5977
In War: Resolution
In Defeat: Defiance
In Victory: Magnanimity
In Peace: Good Will
Winston Spencer Churchill
chris5977 is offline
post #4 of 8 Old 12-22-2004, 09:42 AM - Thread Starter
cra2's Avatar
well, I can use the DVI output on the card.
I have to, unless I use the S-vid.
But I can't go directly from DVI to DVI as there is no DVI input on the tv.
So yes, I'd have to use the DVI to Component dongle (which I just ordered). Then connect the component output of the dongle to the component input on the TV.
But the question is, "has anyone done this with these items before?"
I keep reading about all kinds of adjustments and settings and resolutions.
The TV has 1080i, but you get overscan with that, or something, right?
"Oh, and you shouldn't download movies :) "
There ARE sites where you can download movies legally ya know. :P
cra2 is offline
post #5 of 8 Old 12-22-2004, 09:44 AM - Thread Starter
cra2's Avatar
what makes you say that?
"First off, just go ahead and hook up S-video. If you're perfectly happy with the image, then fine, problem solved."
well, what's the resolution of S-vid?
480 or something?
"Your other option would be a DVI to HDMI cable or a VGA to component cable. I have idea if this would work. Let us know what you find out."
arrrghhh.. I was hoping someone on here WOULD know whether or not it would work BEFORE I spent a bunch of time experimenting, and spent money on various cables. lol.
cra2 is offline
post #6 of 8 Old 12-23-2004, 08:23 AM
MandoMan's Avatar
I had ordered an ATI VGA to Component adapter for my AIW card several months ago. It came with a disc that added the HDTV resolutions. That worked well.
The computer I'm using now (not my HTPC) has a 9800 Pro. Looking through the resolution list, it already has the HD interlaced modes. I would guess just update your drivers, use the adapter/dongle, enable the DVI display (connected to your TV), and select your resolution "1920x1080, True Color (32bit), 30 Hertz (Interlaced)".
Good luck,
Armando
Edit - My things are currently in storage (moving) so I can't look at my HTPC. There are dip switches on the adapter/dongle. Set them to 1080i and the card will do the rest as I recall. Sorry, but that's the best I can do.
MandoMan is offline
post #7 of 8 Old 12-23-2004, 11:01 AM
dice65's Avatar
if your TV supports 1080i , get the dongle , use 1776x1000 and you will be good to go, with my set {panasonic 47in RPTV } i use radge3D tweak to add a refresh rate of 60, so i can play games,lol, i also have a ati 9800pro, your movies will look very good with the dongle and component cables
dice
dice65 is offline
post #8 of 8 Old 12-25-2004, 03:31 PM
HoodedSoldier's Avatar
i have the same television as the poster but i have a nvidia 6800 vanilla card and the only resolution that i can use and see everything on my screen for games is 1177x662 it seems to be the perfect resolution for the tv as the menu's and ammo are aligned perfect to the 16x9 black bars. I would like to play at a higher resolution and be able to see everything like i do now anyone have any suggestions?
HoodedSoldier is offline
Closed Thread Home Theater Gaming
