PS2 cable ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-25-2004, 06:21 PM - Thread Starter
zeus75's Avatar
Just got new PS2. The supplied cable is not long enough to get from my HS20 to my component rack in wall. Do they make a longer multi cable? If they don't any other suggestions? I have 2" conduit ran through my ceiling. I need a cable run of 20'.
thanks
zeus75 is offline
post #2 of 3 Old 12-25-2004, 08:06 PM
b-mill's Avatar
I had the exact same problem when I built my dedicated theater room. The only solution I could come up with for my situation was to use a female-female RCA adapter and run 20' of DIY component cable. Out of curiousity, do you have a receiver or pre/pro that you're feeding other sources through? I assume not since you're looking for long cables, but it never hurts to ask. One other solution would be a component video switchbox that you could use to feed multiple sources like PS2, Xbox,GC, DVD player, etc. into. Hope that helps, take care.
b-mill is offline
post #3 of 3 Old 12-26-2004, 06:40 PM - Thread Starter
zeus75's Avatar
I do have pre\\pro. Would that make it easier?
zeus75 is offline
Closed Thread Home Theater Gaming
