Xbox Wireless setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-28-2004, 07:19 AM - Thread Starter
Myrtledog's Avatar
Quoted: 16 Post(s)
Liked: 110
I currently have a Linksys BEFSR41 with 2 computers and an Xbox hardwired to it. I want to bring my Xbox downstairs to hook up to my HT setup but it's going to be a pain in the arse to get a Cat5 down there. (wife hates to see wires!).
Is this all I need to get a wireless setup going?
Set up a Linksys WRT54G wireless router, in the same spot as my current Linksys, and connect the 2 computers with the Cat 5's. Then get a Microsoft Wireless adapter for the Xbox to be set up downstairs? I want the wireless setup for future plans. Will be moving everything into the basement whenever it gets finished. (Could be a while) The wireless router would allow us to put a comp in the kitchen if so desired. Or possibly getting laptops in the future and be able to surf the web out on the deck.
Thanks for any info!
M-Dog
Myrtledog is offline
post #2 of 3 Old 12-28-2004, 07:30 AM
shaneotool's Avatar
Sound like you got it figured out. Walmart has a linksys acess point for the xbox that is cheaper than the microsoft ones. I just hooked up a wireless network just like you described and it works great - I was suprised becuase I'm not real good with computers. All you have to do is just hook everything up and turn it on.
I like to watch video and listen to audio.
shaneotool is offline
post #3 of 3 Old 12-28-2004, 02:50 PM
Egret's Avatar
I used a Linksys router and wireless access point. It did the trick.
Egret is offline
Closed Thread Home Theater Gaming
