Need Help. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 12-29-2004, 06:44 AM - Thread Starter
raster's Avatar
I bought a pc game called "Return To Castle Wolfenstein" Loaded it, played ok, then started acting funny, couldn't shoot using the mouse etc.
Wanted to unistall it, then reinstall it.
Well the uninstaller doesn't work. can't find the file it says?
I go to the control panel and try to uninstall it from there, same thing, says it can't open install log??
I try to delete the files on my hard drive. It keeps saying another program is in use and won't let me delete the files.
How can I uninstall this darn game?? I use Windows xp Thanks
raster is offline
Closed Thread Home Theater Gaming
