Help with Xbox digital audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-29-2004, 08:39 AM - Thread Starter
Five28's Avatar
Quoted: 47 Post(s)
Liked: 37
I just hooked up the Xbox to a Denon AVR3300 receiver. The receiver has both DD and DTS decoders. I purchased a Monster Cable Lightwave 100 fiber optic audio cable along with a Gamelink 200X AV pack. I hooked the new cables up to the Xbox and ran the fiber optic cable to the receiver where I plugged it in to "optical 2" digital input. Then I set up the receiver to default to optical 2 audio input when switched to VDP, which is the input that I'm using for the game. Trouble is that I get no audio.
I'm using fiber optic digital audio for my hi-def cable box using the "optical 1" audio input and it works fine. Lastly, the Xbox preferences have been set to DTS and DD enabled mode. I could understand if I wasn't getting DD sound and would assume that the game didn't offer dolby digital, but not getting any sound at all has me stumped. Any ideas?
BenQ W1070 front projector, Definitive Technology BP2002 towers, Def Tech CLR2002 center, Def Tech BP2X surrounds, Def Tech PF15 subwoofer, Denon AVR3300 receiver, Panasonic Blu-Ray player, Apple TV, Roku device, Monoprice HDMI switcher
Five28 is offline
post #2 of 2 Old 12-29-2004, 09:18 AM - Thread Starter
Five28's Avatar
Quoted: 47 Post(s)
Liked: 37
I swapped out the fiber optic cables and still had no luck. One thing that I did was to disconnect a DVD adapter from the Xbox. I then noticed that I was getting the red light coming from the fiber optic connection so I knew that the Xbox was outputting the digital audio. I turned on the receiver and switched to DVP and now I have sound. Don't know what changed, but the problem is solved.
Five28 is offline
Closed Thread Home Theater Gaming
